Hi all,
I am developing an application on the Nvidia TX2. I embedded the TX2 with the J100 and M100 from Auvidea.
I am using 2 IMX219 cameras, I compiled 4.4 linux kernel (from Jetpack 3.2.1) with RidgeRun patch and GStreamer 1.8 with the other Ridgerun patch.
But when I execute the Gstreamer command, the capture stream is just green picture sometimes. The command is:
gst-launch-1.0 nvcamerasrc sensor-id=0 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=(int)1640, height=(int)1232, format=(string)I420, framerate=(fraction)30/1' ! nvegltransform ! nveglglessink nvcamerasrc sensor-id=1 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=(int)1640, height=(int)1232, format=(string)I420, framerate=(fraction)30/1' ! nvegltransform ! nveglglessink -e
And logs from GStreamer show:
launchCC abort cc 9044 session 0
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 830)
I can’t figure whether the problem is hardware or software.
I have another board same hardware, same software, the only difference is in file /etc/X11/xorg.conf
Option "TegraReserveDisplayBandwidth" "false"
I add this line because we had the problem described here : https://devtalk.nvidia.com/default/topic/1046527/csi-camera-red-screen-with-quot-vid_rend-syncpoint-wait-timeout-quot-/
I saw that Auvidea released a 4.9 kernel. Do you think it is worth trying?
Anyone had this problem before ?
Nvcamera-daemon logs when problem appears are :
---- Imager: Calibration blob file handling supported in this build ----
NvPclHwGetModuleList: OFParserListModules Succeeded
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition -- Name: e3322_front_A819P2
NvPclHwPrintModuleDefinition -- Position: 1
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx219 0-0010
NvPclHwPrintModuleDefinition -- Name: e3322_rear_A819P2
NvPclHwPrintModuleDefinition -- Position: 0
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx219 2-0010
NvPclModuleListInitialize: NvPclModule list[0]: e3322_front_A819P2 position1
NvPclModuleListInitialize: NvPclModule list[1]: e3322_rear_A819P2 position0
NvPclHwScanExternalCameras -- adding video1 to discover list
NvPclHwScanExternalCameras -- adding video0 to discover list
initialize: /dev/video0
queryControls: 10100736 control Frame Length
queryControls: 10100737 control Coarse Time
queryControls: 10100739 control Group Hold
queryControls: 10100740 control HDR enable
queryControls: 10100743 control Fuse ID
queryControls: 10100745 control Gain
queryControls: 10100836 control Bypass Mode
queryControls: 10100837 control Override Enable
queryControls: 10100838 control Height Align
queryControls: 10100839 control Size Align
queryControls: 10100840 control Write ISP format
queryControls: 10100841 control Sensor Signal Properties
queryControls: 10100842 control Sensor Image Properties
queryControls: 10100843 control Sensor Control Properties
queryControls: 10100844 control Sensor DV Timings
queryControls: 10100866 control Sensor Modes
Ioctl failed: Invalid argument
initialize: /dev/video1
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
addWatch: Watch added wd='1'
hotPlugfunc ++ CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 1 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb75dc0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb75e50
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb75ee0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb75f70
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb76000
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb76090
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16CheckOverridesPermissions: cannot stat file [/Calib/camera_override.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16CheckOverridesPermissions: cannot stat file [/data/nvcam/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/e3322_front_A819P2.isp] 6/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/e3322_front_A819P2.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3322_front_A819P2.isp] 7/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/e3322_front_A819P2.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3322_front_A819P2.isp] 8/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/e3322_front_A819P2.isp]
---- imager: No override file found. ----
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/nvcam/settings/e3322_front_A819P2.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/e3322_front_A819P2.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/e3322_front_A819P2.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
initialize: imx219 0-0010
OFDPropertyGetString: could not read property [use_decibel_gain]
OFDPropertyGetString: could not read property [use_sensor_mode_id]
OFDPropertyGetString: could not read property [delayed_gain]
OFDPropertyCopyToLong: could not read property [has-eeprom]
Control OTP Data not found
Control Frame Rate not found
Control Exposure not found
Control Coarse Time Short not found
findCustomCids: calculated MaxCoarseDiff 4
queryPixelFormats: type: 1, pixelformat 0x30314752 "RG10"
queryFormatSizes: Discrete frameSize 3280x2464
queryFormatSizes: Discrete frameSize 1920x1080
queryFormatSizes: Discrete frameSize 1640x1232
queryFormatSizes: Discrete frameSize 1280x720
queryFormatSizes: Discrete frameSize 820x616
loadBinaryBlob: Binary read 0
OFDPropertyGetString: could not read property [type]
loadSubType: Sensor type missing in DT, 199
OFDPropertyCopyToLong: could not read property [mode0.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode0.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode0.mode_type]
mode 0: Failed to load mode type
OFDPropertyGetString: could not read property [mode0.pixel_phase]
mode 0: Failed to load pixel phase
OFDPropertyCopyToLongLong: could not read property [mode0.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode0.gain_step_pitch]
OFDPropertyGetString: could not read property [mode0.x_start]
OFDPropertyGetString: could not read property [mode0.y_start]
OFDPropertyGetString: could not read property [mode0.x_end]
OFDPropertyGetString: could not read property [mode0.y_end]
OFDPropertyGetString: could not read property [mode0.h_scaling]
OFDPropertyGetString: could not read property [mode0.v_scaling]
OFDPropertyCopyToLong: could not read property [mode1.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode1.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode1.mode_type]
mode 1: Failed to load mode type
OFDPropertyGetString: could not read property [mode1.pixel_phase]
mode 1: Failed to load pixel phase
OFDPropertyCopyToLongLong: could not read property [mode1.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode1.gain_step_pitch]
OFDPropertyGetString: could not read property [mode1.dpcm_enable]
OFDPropertyGetString: could not read property [mode1.x_start]
OFDPropertyGetString: could not read property [mode1.y_start]
OFDPropertyGetString: could not read property [mode1.x_end]
OFDPropertyGetString: could not read property [mode1.y_end]
OFDPropertyGetString: could not read property [mode1.h_scaling]
OFDPropertyGetString: could not read property [mode1.v_scaling]
OFDPropertyCopyToLong: could not read property [mode2.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode2.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode2.mode_type]
mode 2: Failed to load mode type
OFDPropertyGetString: could not read property [mode2.pixel_phase]
mode 2: Failed to load pixel phase
OFDPropertyCopyToLongLong: could not read property [mode2.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode2.gain_step_pitch]
OFDPropertyGetString: could not read property [mode2.dpcm_enable]
OFDPropertyGetString: could not read property [mode2.x_start]
OFDPropertyGetString: could not read property [mode2.y_start]
OFDPropertyGetString: could not read property [mode2.x_end]
OFDPropertyGetString: could not read property [mode2.y_end]
OFDPropertyGetString: could not read property [mode2.h_scaling]
OFDPropertyGetString: could not read property [mode2.v_scaling]
OFDPropertyCopyToLong: could not read property [mode3.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode3.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode3.mode_type]
mode 3: Failed to load mode type
OFDPropertyGetString: could not read property [mode3.pixel_phase]
mode 3: Failed to load pixel phase
OFDPropertyCopyToLongLong: could not read property [mode3.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode3.gain_step_pitch]
OFDPropertyGetString: could not read property [mode3.dpcm_enable]
OFDPropertyGetString: could not read property [mode3.x_start]
OFDPropertyGetString: could not read property [mode3.y_start]
OFDPropertyGetString: could not read property [mode3.x_end]
OFDPropertyGetString: could not read property [mode3.y_end]
OFDPropertyGetString: could not read property [mode3.h_scaling]
OFDPropertyGetString: could not read property [mode3.v_scaling]
OFDPropertyCopyToLong: could not read property [mode4.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode4.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode4.mode_type]
mode 4: Failed to load mode type
OFDPropertyGetString: could not read property [mode4.pixel_phase]
mode 4: Failed to load pixel phase
OFDPropertyCopyToLongLong: could not read property [mode4.exp_time_1h]
OFDPropertyCopyToFloat: could not read property [mode4.gain_step_pitch]
OFDPropertyGetString: could not read property [mode4.dpcm_enable]
OFDPropertyGetString: could not read property [mode4.x_start]
OFDPropertyGetString: could not read property [mode4.y_start]
OFDPropertyGetString: could not read property [mode4.x_end]
OFDPropertyGetString: could not read property [mode4.y_end]
OFDPropertyGetString: could not read property [mode4.h_scaling]
OFDPropertyGetString: could not read property [mode4.v_scaling]
initialize: Loaded Driver: 5 Modes Available--------------
NvPclInitializeDrivers: v4l2_sensor ------------------
NvPclOpen: ----------------------
LSC: LSC surface is not based on full res!
NvPclStateControllerOpen: Found GUID 0 match at index[1]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb4b2f0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb4b380
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb4b410
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb4b4a0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb4b530
NvPclHwInitializeModule: allocate overrides pathname @ 0x7facb4b5c0
LoadOverridesFile: looking for override file [/data/nvcam/settings/e3322_rear_A819P2.isp] 6/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/e3322_rear_A819P2.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3322_rear_A819P2.isp] 7/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/e3322_rear_A819P2.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3322_rear_A819P2.isp] 8/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/e3322_rear_A819P2.isp]
Imager: looking for override file [/data/nvcam/settings/e3322_rear_A819P2.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/e3322_rear_A819P2.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/e3322_rear_A819P2.bin] 4/16
initialize: imx219 2-0010
NvPclPowerOn: +++++++++++
NvPclPowerOn: -----------
NvPclSettingsUpdate: Sending Updated Settings through PCL
NvPclSettingsApply: Applying last settings through PCL
apply:+++++++++++++++++++++++
writeMode: Target mode Id(3): Resolution 1280x720
setActiveBufferMemory: 2
INPUT: Width 1280 Height 720 pixelformat RG10
writeFrameRate: INPUT frameLength:1591, frameRate:30.000000
writeGain: INPUT gainCtrl:100 analogGain:1.000000
writeExposure: INPUT coarseTime:1587, expTime:0.033234
Ioctl failed: Remote I/O error
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlValMultiple(), line 781)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1618)
updateOutputSettings: Set Control failed. Use cached values
updateOutputSettings: OUTPUT frameLength:1591, frameRate:30.014336
updateOutputSettings: OUTPUT analogGain:1.000000
updateOutputSettings: OUTPUT coarseTime:2499, expTime:0.052332
apply:-----------------------
NvPclSettingsApply: Reading PCL settings
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147483647 Set = 3925327 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function streamControl(), line 1642)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 202)
PowerServiceCore:handleRequests: timePassed = 1216
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 104 session 0
launchCC abort cc 105 session 0
launchCC abort cc 106 session 0
launchCC abort cc 107 session 0
launchCC abort cc 108 session 0
Error: waitCsiFrameStart timeout guid 0
SCF: Error Timeout: VI SOF timed out! (in src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCsiFrameStart(), line 948)
VI Stream Id = 1 Virtual Channel = 0
