hi every one,
i’m trying to get sony imx219 working on tx2(R32).and now,i can use the below command to capture stream,it’s ok:
v4l2-ctl --set-fmt-video=width=3280,height=2464,pixelformat=RG10 --stream-mmap --set-ctrl=sensor_mode=0 --stream-count=3 -d /dev/video0
but,when i use gstreamer, it was failed.
root@tek:~# gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=3280, height=2464, format=(string)NV12, framerate=(fraction)30/1' ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:521 No cameras available
log:
# tracer: nop
# entries-in-buffer/entries-written: 146/146 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
nvargus-daemon-7978 [005] .... 368.293127: tegra_channel_open: vi-output, imx219 2-0010
nvargus-daemon-7978 [000] .... 368.294164: tegra_channel_set_power: imx219 2-0010 : 0x1
nvargus-daemon-7978 [000] .... 368.294175: camera_common_s_power: status : 0x1
nvargus-daemon-7978 [000] .... 368.323346: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-7978 [000] .... 368.323352: csi_s_power: enable : 0x1
nvargus-daemon-7978 [000] .... 368.325063: tegra_channel_close: vi-output, imx219 2-0010
nvargus-daemon-7978 [000] .... 368.325069: tegra_channel_set_power: imx219 2-0010 : 0x0
nvargus-daemon-7978 [000] .... 368.325076: camera_common_s_power: status : 0x0
nvargus-daemon-7978 [000] .... 368.325533: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-7978 [000] .... 368.325535: csi_s_power: enable : 0x0
nvargus-daemon-7978 [000] .... 368.330041: tegra_channel_open: vi-output, imx219 2-0010
nvargus-daemon-7978 [000] .... 368.330054: tegra_channel_set_power: imx219 2-0010 : 0x1
nvargus-daemon-7978 [000] .... 368.330061: camera_common_s_power: status : 0x1
nvargus-daemon-7978 [000] .... 368.361808: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-7978 [000] .... 368.361814: csi_s_power: enable : 0x1
nvargus-daemon-7978 [000] .... 368.362142: tegra_channel_close: vi-output, imx219 2-0010
nvargus-daemon-7978 [000] .... 368.362148: tegra_channel_set_power: imx219 2-0010 : 0x0
nvargus-daemon-7978 [000] .... 368.362156: camera_common_s_power: status : 0x0
nvargus-daemon-7978 [000] .... 368.362696: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-7978 [000] .... 368.362699: csi_s_power: enable : 0x0
nvargus-daemon-7978 [004] .... 368.399030: tegra_channel_open: vi-output, imx219 2-0010
nvargus-daemon-7978 [004] .... 368.399039: tegra_channel_set_power: imx219 2-0010 : 0x1
nvargus-daemon-7978 [004] .... 368.399045: camera_common_s_power: status : 0x1
nvargus-daemon-7978 [004] .... 368.428290: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-7978 [004] .... 368.428296: csi_s_power: enable : 0x1
nvargus-daemon-7978 [004] .... 368.428331: tegra_channel_close: vi-output, imx219 2-0010
nvargus-daemon-7978 [004] .... 368.428336: tegra_channel_set_power: imx219 2-0010 : 0x0
nvargus-daemon-7978 [004] .... 368.428342: camera_common_s_power: status : 0x0
nvargus-daemon-7978 [004] .... 368.428792: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-7978 [004] .... 368.428794: csi_s_power: enable : 0x0
