The v4l2 instruction captures images, but gstreamer does not
I ran into a weird issue where I could provide the raw data captured to the camera by v4l2 as follows:
root@blst-pz-desktop:/home/blst_pz# v4l2-ctl --set-fmt-video=width=4000,height=3000,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --set-ctrl=sensor_mode=0 --stream-to=camera.raw -d /dev/video0
However, when I tried to capture the camera data through gstreamer, it failed, as follows:
root@blst-pz-desktop:/home/blst_pz# gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)4000,height=(int)3000, framerate=25/1, pixelformat=NV12' ! nvvidconv flip-method=0 ! pngenc ! multifilesink location=%05u.png -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. gstnvarguscamerasrc.cpp, execute:780 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.005476002
Setting pipeline to NULL ...
Freeing pipeline ...
This is true for both photos and videos, which give the following error:
root@blst-pz-desktop:/home/blst_pz# gst-launch-1.0 -v nvarguscamerasrc sensor-mode=1 sensor-id=0  ! nvvidconv ! 'video/x-raw(memory:NVMM), width=4000, height=3000, format=(string)NV12, framerate=25/1' ! nvv4l2h265enc ! h265parse ! qtmux ! filesink location=test_h265.mp4 -e
Opening in BLOCKING MODE
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/nvv4l2h265enc:nvv4l2h265enc0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)4000, height=(int)3000, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
NvMMLiteOpen : Block : BlockType = 8
/GstPipeline:pipeline0/GstH265Parse:h265parse0.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)4000, height=(int)3000, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
Redistribute latency...
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
/GstPipeline:pipeline0/nvv4l2h265enc:nvv4l2h265enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, framerate=(fraction)25/1, format=(string)NV12
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = video/quicktime, variant=(string)apple
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/quicktime, variant=(string)apple
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = video/quicktime, variant=(string)apple, streamheader=(buffer)< 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 >
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/quicktime, variant=(string)apple, streamheader=(buffer)< 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 >
Execution ended after 0:00:00.091428503
I was using jetson 4.6.1 and it worked fine for a long time, now I upgraded it to jetson 5.1.4. I ported the camera driver and it didn’t work.
I hope I can get your help. How can I solve this problem?
Hello @darius-yuan
Let’s try a simpler pipeline, such as:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)4000,height=(int)3000, framerate=25/1, pixelformat=NV12' ! nvvidconv flip-method=0 ! fakesink silent=false -v
Could you share the sensor driver device tree, especially the tegra-camera-platform node?
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Thank you for your reply.
I tried it, but it still got an error.
root@blst-pz-desktop:/home/blst_pz# v4l2-ctl --set-fmt-video=width=4000,height=3000,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --set-ctrl=sensor_mode=0 --stream-to=camera.raw -d /dev/video1
root@blst-pz-desktop:/home/blst_pz# gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM), width=(int)4000,height=(int)3000, framerate=25/1, pixelformat=NV12' ! nvvidconv flip-method=0 ! fakesink silent=false -v
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event   ******* (fakesink0:sink) E (type: stream-start (10254), GstEventStreamStart, stream-id=(string)ca84d63d2906058d36ae674f946a09ea, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)1;) 0xaaaaee3aa4f0
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)25/1, pixelformat=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)25/1, pixelformat=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)25/1, pixelformat=(string)NV12
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event   ******* (fakesink0:sink) E (type: caps (12814), GstEventCaps, caps=(GstCaps)"video/x-raw\(memory:NVMM\)\,\ width\=\(int\)4000\,\ height\=\(int\)3000\,\ format\=\(string\)NV12\,\ framerate\=\(fraction\)25/1\,\ pixelformat\=\(string\)NV12";) 0xaaaaee3aa640
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)25/1, pixelformat=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)25/1, pixelformat=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)4000, height=(int)3000, format=(string)NV12, framerate=(fraction)25/1, pixelformat=(string)NV12
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event   ******* (fakesink0:sink) E (type: eos (28174), ) 0xaaaaee3aa6b0
Execution ended after 0:00:00.006505195
This is tegra-camera-platform node and mode1:
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <8>;
		max_lane_speed = <2144607>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <5>;
		vi_bw_margin_pct = <2>;
		max_pixel_rate = <1715686>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <2>;
		modules {
			//imx586s
			cam_module0: module0 {
				badge = "imx586_rear_BS";
				position = "rear";
				orientation = "1";
				cam_module0_drivernode0: drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "imx586 2-001a";
					//proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/imx586_a@34";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@3180000/imx586_a@34";
				cam_module0_drivernode1: drivernode1 {
					pcl_id = "v4l2_lens";
					proc-device-tree = "/proc/device-tree/lens_imx586@RBPCV2/";
			//imx586_8
			cam_module1: module1 {
				badge = "imx586_front_BS";
				position = "front";
				orientation = "1";
				cam_module1_drivernode0: drivernode0 {
					/* Declare PCL support driver (classically known as guid)  */
					/* Driver v4l2 device name */
					devname = "imx586_8 8-001a";
					/* Declare the device-tree hierarchy to driver instance */
					//proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/imx586_c@34";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@31e0000/imx586_c@34";
				cam_module1_drivernode1: drivernode1 {
mode1 {/*mode IMX586_MODE_4000X3000_NOR_35FPS*/
					mclk_khz = "24000";
					num_lanes = "4";
					phy_mode = "DPHY";
					discontinuous_clk = "no";
					dpcm_enable = "false";
					cil_settletime = "0";
					dynamic_pixel_bit_depth = "10";
					csi_pixel_bit_depth = "10";
					mode_type = "bayer";
					pixel_phase = "rggb";
					active_w = "4000";
					active_h = "3000";
					readout_orientation = "0";
					line_length = "7872";
					inherent_gain = "1";
					mclk_multiplier = "625";
					pix_clk_hz = "864000000";
					//gain
					gain_factor = "10";
					min_gain_val = "10";
					max_gain_val = "360";
					step_gain_val = "1";
					default_gain = "10";
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
                    //framerate
					framerate_factor = "1000000";
					min_framerate = "1000000";
					max_framerate = "35868005";
					step_framerate = "1";
					default_framerate = "35868005";
					//exposure
					exposure_factor = "1000000";
					min_exp_time = "56";
					max_exp_time = "28571";
					step_exp_time = "2";
					default_exp_time = "28571";
					embedded_metadata_height = "0";
Does jetson 5.1.4 have Settings to update the device tree?
This all works on jetson 4.6.1, I don’t understand why?
Hello @darius-yuan
From the following definitions, I see some inconsistencies.
You are using the i2c camera mux. This enables the i2c buses 9 and 10 in the Xavier NX and you are defining the buses 2 and 8. I suggest you checking the imx477 device tree in the Xavier NX sources at hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-camera-rbpcv3-imx477.dtsi. The tegra-camera-platform for two cameras support is defined as:
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <4>;
		max_lane_speed = <1500000>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <7500000>;
		isp_bw_margin_pct = <25>;
		 * The general guideline for naming badge_info contains 3 parts, and is as follows,
		 * The first part is the camera_board_id for the module; if the module is in a FFD
		 * platform, then use the platform name for this part.
		 * The second part contains the position of the module, ex. "rear" or "front".
		 * The third part contains the last 6 characters of a part number which is found
		 * in the module's specsheet from the vendor.
		modules {
			module0 {
				badge = "jakku_front_IMX477";
				position = "front";
				orientation = "1";
				drivernode0 {
					devname = "imx477 9-001a";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/rbpcv3_imx477_a@1a";
			module1 {
				badge = "jakku_rear_IMX477";
				position = "rear";
				orientation = "1";
				drivernode0 {
					devname = "imx477 10-001a";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/rbpcv3_imx477_c@1a";
Please, use that device tree as a reference and compare yours with the imx477 device tree.
Hope this helps!
Regards!
That’s the problem.
Now the camera can stream normally.
