since camera drivers are functional, it may be the issue with gst plugins.
could you please enable the nvcamera-daemon manually to enable background logs to gather more details.
for example,
Thank you for the suggestion, I indeed tried that and I get the below error
OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree
LoadOverridesFile: looking for override file [/Calib/camera_override.isp]
1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/e3326_front_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3326_front_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3326_front_P5V27C.isp] 8/16---- imager: No override file found. ----
Since I am not familiar with internals of nvcam, what could this error mean?
I am trying to use the IMX219 sensor with TX2 on L4T 28.1
This is the backgroung logs for nvcamera daemon:
NvPclHwGetModuleList: No module data found
PCLHW_DTParser
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/e3326_bottom_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3326_bottom_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3326_bottom_P5V27C.isp] 8/16---- imager: No override file found. ----
(NvOdmDevice) Error ModuleNotPresent: V4L2Device not available (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function findDevice(), line 231)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function initialize(), line 54)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 97)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 596)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 781)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 276)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 439)
