Hi @jafeth.garcia
Thanks for the clarification
Could you confirm this is the case?>
We had the same device ID and name property for i2c node in the imx335 driver, which is attached below
static const struct i2c_device_id imx335_id = {
{ “imx335”, 0 },
MODULE_DEVICE_TABLE(i2c, imx335_id);
static struct i2c_driver imx335_i2c_driver = {
.driver = {
.name = “imx335”,
.owner = THIS_MODULE,
.of_match_table = of_match_ptr(imx335_of_match),
.probe = imx335_probe,
.remove = imx335_remove,
.id_table = imx335_id,
It is possible to have a device node without having the working camera driver so it isn’t a good confirmation.>
But our imx335 driver is probed successfully, and we are able to capture frame with v4l2 application as well, so can we confirm that issue is still with camera driver?
Also, are you using a custom board for this?
Yes @jafeth.garcia we have a custom board and can capture 4-lane
We have enabled the debug logs for camera. Here is the syslog
- When running v4l2 application
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.774421] imx335 power on function
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.774431] imx335 2-001a: imx335_power_on: power on
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.803373] imx335 imx335_set mode = 0
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.803384] imx335 imx335_write_table
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.835854] imx335 imx335_set mode writing = 0
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.835866] imx335 imx335_write_table
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.837484] imx335 imx335_set mode writing complete= 0
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.837504] imx335 imx335_start_streaming
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.837512] imx335 imx335_write_table
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.848901] imx335 imx335_stop_streaming
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.848913] imx335 imx335_write_table
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.900803]
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.900803] imx335 power off function
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.900850] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.909334]
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.909334] imx335 power on function
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.909364] imx335 2-001a: imx335_power_on: power on
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.969628] imx335 imx335_set mode = 0
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.969632] imx335 imx335_write_table
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.993004] imx335 imx335_set mode writing = 0
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.993008] imx335 imx335_write_table
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.994019] imx335 imx335_set mode writing complete= 0
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.994026] imx335 imx335_start_streaming
Jan 18 12:22:53 tegra-ubuntu kernel: [ 578.994028] imx335 imx335_write_table
Jan 18 12:22:54 tegra-ubuntu kernel: [ 579.359524] video4linux video0: tegra_channel_capture_done: MW_ACK_DONE syncpoint time out!0
Jan 18 12:22:54 tegra-ubuntu kernel: [ 579.368566] imx335 imx335_stop_streaming
Jan 18 12:22:54 tegra-ubuntu kernel: [ 579.368575] imx335 imx335_write_table
Jan 18 12:22:54 tegra-ubuntu kernel: [ 579.450204]
Jan 18 12:22:54 tegra-ubuntu kernel: [ 579.450204] imx335 power off function
Jan 18 12:22:54 tegra-ubuntu kernel: [ 579.450213] imx335 2-001a: imx335_power_off: power off turning off camera
- When running gstreamer with nvargsucamerasrc pipeline
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: Acquiring SCF Camera device source via index 0 has failed. === gst-launch-1.0[7689]: CameraProvider initialized (0x7fadbd9ac0)=== gst-launch-1.0[7689]: CameraProvider destroyed (0x7fadbd9ac0)=== gst-launch-1.0[7689]: Connection closed (7FB106B1D0)=== gst-launch-1.0[7689]: Connection cleaned up (7FB106B1D0)=== gst-launch-1.0[7747]: Connection established (7FB106B1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.564575]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.564575] imx335 power on function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.564583] imx335 2-001a: imx335_power_on: power on
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.592828] imx335 imx335_set mode = 0
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.592832] imx335 imx335_write_table
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.617478] imx335 imx335_set mode writing = 0
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.617487] imx335 imx335_write_table
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.618643] imx335 imx335_set mode writing complete= 0
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.618753] imx335 imx335_start_streaming
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.618763] imx335 imx335_write_table
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.629785] vi 54080000.vi: Calibrate csi port 2
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.629953] imx335 imx335_stop_streaming
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.629958] imx335 imx335_write_table
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.681557]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.681557] imx335 power off function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.681580] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.689155]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.689155] imx335 power on function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.689171] imx335 2-001a: imx335_power_on: power on
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.718559]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.718559] imx335 power off function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.718581] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.737566]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.737566] imx335 power on function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.737579] imx335 2-001a: imx335_power_on: power on
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.766386]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.766386] imx335 power off function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.766418] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: ---- imager: No override file found. ----
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.809181]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.809181] imx335 power on function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.809188] imx335 2-001a: imx335_power_on: power on
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.837463]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.837463] imx335 power off function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.837470] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.845675]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.845675] imx335 power on function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.845679] imx335 2-001a: imx335_power_on: power on
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.874130]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.874130] imx335 power off function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.874137] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.881284]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.881284] imx335 power on function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.881289] imx335 2-001a: imx335_power_on: power on
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.909644]
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.909644] imx335 power off function
Jan 18 12:48:09 tegra-ubuntu kernel: [ 2094.909652] imx335 2-001a: imx335_power_off: power off turning off camera
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: (NvOdmDevice) Error SymbolNotFound: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function loadModeProperties(), line 780)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: (NvOdmDevice) Error SymbolNotFound: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function loadModeList(), line 578)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: (NvOdmDevice) Error SymbolNotFound: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 124)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: NvPclStartPlatformDrivers: Failed to start module drivers
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0x30009)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: NvPclOpen: PCL Open Failed. Error: 0xf
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 593)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 305)
Jan 18 12:48:09 tegra-ubuntu nvargus-daemon[4814]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 471)
Could you please give as some insights about what may be causing the issue in argsus level so that we can proceed further?
