Hi ctichenor,nVConan,
I have the same problem.After running the following command
sudo service nvcamera-daemon stop
sudo /usr/sbin/nvcamera-daemon &
and then run
gst-launch-1.0 nvcamerasrc ! ‘video/x-raw(memory:NVMM),width=1920, height=1080, format=(string)I420’ ! nvhdmioverlaysink -e
print:
Setting pipeline to PAUSED …
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingNvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_focuser_stub)
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_soc_sensor)
NvPclDriver_V4L2_Focuser_Stub_Initialize WARNING: No focuser object, allocating for lens
NvPclDriver_V4L2_Focuser_Stub_Initialize: Loaded focuser static properties--------------
OFDPropertyGetString: could not read property [devnode]
V4L2 Sensor Driver: Sensor_InitializeDevNode: devnode missing in device-tree
Sensor_InitializeDevNode: Failed to open dev node ‘/dev/camera/video0’, trying alternate location
Sensor_InitializeDevNode: Failed. Unable to locate dev node ‘video0’
NvPclDriver_V4L2_Sensor_Initialize: Failure ---------------------
NvPclDriverInitializeData: Unable to initialize driver v4l2_soc_sensor
SCF: Error BadParameter: (propagating) (in src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 116)
SCF: Error BadParameter: (propagating) (in src/services/capture/CaptureServiceDeviceSensor.cpp, function listOdmSensors(), line 400)
SCF: Error BadParameter: (propagating) (in src/services/capture/CaptureServiceDeviceSensor.cpp, function listRealSensors(), line 472)
SCF: Error BadParameter: (propagating) (in src/services/capture/CaptureServiceDeviceSensor.cpp, function listSensors(), line 509)
SCF: Error BadParameter: (propagating) (in src/services/capture/CaptureService.cpp, function getSources(), line 568)
SCF: Error BadParameter: (propagating) (in src/api/CameraDriver.cpp, function enumerateSources(), line 429)
SCF: Error BadParameter: Error enumerating CameraDriver sources (in src/api/CameraDriver.cpp, function numSources(), line 466)
SCF: Error BadParameter: index out of range (in src/api/CameraDriver.cpp, function getSource(), line 497)
Socket read error. Camera Daemon stopped functioning…
gst_nvcamera_open() failed ret=0
ERROR: Pipeline doesn’t want to pause.
Setting pipeline to NULL …
But when run following command
rmmod nvhost_vi
modprobe tegra_camera
./yavta /dev/video0 -c1 -n1 -s1920x1080 -fSRGGB10 -Fov.raw
I can capture data with yavta.
Can you help to solve the problem?
