I wrote a camera driver for OV9734 and am trying to get it to capture images. It passes all the v4l2 tests.
When I try to record even a single image using gstreamer, the whole camera subsystem locks up and produces errors and no image. This is the command line I’m using:
gst-launch-1.0 -v nvcamerasrc num-buffers=1 ! 'video/x-raw(memory:NVMM),width=(i)1280,height=(i)720' ! nvjpegenc ! filesink location=sample.jpg
Similar behavior happens when I try to record video. However, I found one way to make the camera work—when I first run v4l2-ctl and stream a some frames, then afterwards everything works!
v4l2-ctl --set-fmt-video=width=1280,height=720,pixelformat=RG10 --stream-mmap --stream-count=100 -d /dev/video0
When I run the first command and it fails, here are the logs:
Command line: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-failed-command-line-log
dmesg: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-failed-dmesg-log
trace: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-failed-trace-log
argus-daemon and nvcamera-daemon: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-failed-argus-daemon-nvcamera-daemon-log
When I run both command and it succeeds, here are the logs:
Command line: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-succeeded-command-line-log
dmesg: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-succeeded-dmesg-log
trace: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-succeeded-trace-log
argus-daemon and nvcamera-daemon: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-succeeded-argus-daemon-nvcamera-daemon-log
Here’s the part of the DTSI file that describes the mode, in case it helps: https://gist.github.com/nsabovic/f5149de33a8d4416000a0c7bfe73ae9f#file-dts-mode-excerpt-dtsi
What is going on here? What do I need to change in the driver to have it work reliably?
