ncu --target-processes all -k regex:"xmma" -o profile_ncu python3 application.py
However, I am getting the following error.
==ERROR== Unknown Error on device 4.
==ERROR== Failed to profile "sm90_xmma_fprop_implicit_gemm..." in process 12601
==PROF== Trying to shutdown target application
==ERROR== The application returned an error code (9).
==ERROR== An error occurred while trying to profile.
==WARNING== No kernels were profiled.
make: *** [Makefile:46: run_harness] Error 9
It is exactly the Nvidia’s submission of DLRM workload in MLPerf Inference 4.1. This entire run is from via the docker image provided by Nvidia. The above run is DLRM inference workload in Offline mode : This is the repo
Regarding 1) I have tried profiling a helloworld program using ncu. Following is the code:
#include <stdio.h>
__global__ void helloWorld() {
printf("Hello, World from GPU!\n");
int main() {
printf("Hello, World from CPU!\n");
helloWorld<<<1, 1>>>();
cudaDeviceSynchronize();
return 0;
The code is compiled with nvcc helloworld.cu -o helloworld
$ ./helloworld
However when running with ncu
$ ncu ./helloworld
==PROF== Connected to process 21957 (/work/helloworld)
==ERROR== Failed to prepare kernel for profiling
==ERROR== Unknown Error on device 0.
==ERROR== Failed to profile "helloWorld()" in process 21957
I am running the helloworld program inside docker. The machine is DGX H200x8, Ubuntu 22.04.4 LTS (Jammy Jellyfish)
Inside the docker ncu is Version 2024.1.1.0 (build 33998838) (public-release)
I tried the ncu ./helloworld program outside the docker and it seemed to work fine. The ncu version on the system (outside the docker) is 2024.3.1.0 (build 34702747) (public-release)
Thanks for provoking this discussion. I installed 2024.3 version of ncu also with in the docker image. Now I am able to profile the kernels with ncu inside the docker.
The purpose of this task to get to know the input matrix sizes passed to the kernel. I have posted a question here.
Can you help me if we can get input matrix size info with ncu?
The interactive profiling activity shows the api parameters for each CUDA function call and kernel launch, but there is no option to capture and export these from the non-interactive activity or command line.
