• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 6.1
• TensorRT Version 11.4
im using reference of deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
You can refer to this for resnet18 output layer parsing under
sources/libs/nvdsinfer_customparser/
after buidling the parser, im getting below error during inference
Warning: gst-library-error-quark: Configuration file batch-size reset to: 1 (5): gstnvinferserver_impl.cpp(287): validatePluginConfig (): /GstPipeline:pipeline0/GstNvInferServer:primary-inference
Could not find bbox layer buffer while parsing
ERROR: infer_postprocess.cpp:1043 Failed to parse bboxes using custom parse function
ERROR: infer_postprocess.cpp:378 detection parsing output tensor data failed, uid:5, nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
ERROR: infer_postprocess.cpp:265 Infer context initialize inference info failed, nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
Did you change these properties in infer configuration file?
parse-classifier-func-name=NvDsInferClassiferParseCustomSoftmax
custom-lib-path=/path/to/this/directory/libnvds_infercustomparser.so
system
Closed
August 2, 2022, 5:06am
8
