edit_or
September 21, 2020, 3:13am
1
I am implementing custom_parse_bbox_func in AGXXavier with Jetpack4.4.
Can’t find custom_parse_bbox_func.
So how to parse custom function in object detection?
In configuration file,
network-type=0
num-detected-classes=48
custom_parse_bbox_func=NvDsInferParseCustomCTCGreedy
custom_lib=/opt/nvidia/deepstream/deepstream-5.0/sources/libs/nvdsinfer_customparser/libnvds_infercustomparser.so
But the default resnet parsing function is always called.
edit_or
September 21, 2020, 3:55am
3
Then when I changed to
parse-bbox-func-name=NvDsInferParseCustomCTCGreedy
parse-bbox-lib-name=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infercustomparser.so
I have errors as
0:00:03.346315954 15786 0x55b6e14490 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initResource() <nvdsinfer_context_impl.cpp:681> [UID = 2]: Detect-postprocessor failed to init resource because dlsym failed to get func NvDsInferParseCTCGreedy pointer
ERROR: Infer Context failed to initialize post-processing resource, nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
ERROR: Infer Context prepare postprocessing resource failed., nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
0:00:03.349646996 15786 0x55b6e14490 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<secondary1-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:03.349746200 15786 0x55b6e14490 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<secondary1-nvinference-engine> error: Config file path: dstest2_sgie1_config.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
edit_or
September 21, 2020, 4:24am
4
I tried custom classifier function implementation as
network-type=1
parse-classifier-func-name=NvDsInferClassiferCTCGreedyParser
also failed with
0:00:03.096188290 16232 0x5585a12c90 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initResource() <nvdsinfer_context_impl.cpp:809> [UID = 2]: Failed to init classify-postprocessor because dlsym failed to get func NvDsInferClassiferCTCGreedyParser pointer
I put CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE(NvDsInferClassiferCTCGreedyParser); for custom classifier and
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomCTCGreedy); for detector inside nvdsinfer_custombboxparser.cpp file and nvdsinfer_customclassifierparser.cpp file.
edit_or
September 21, 2020, 6:06am
5
Any suggestions for this. I need to finish this custom output implementation in this week.
edit_or
September 21, 2020, 6:53am
6
Tested all provided custom classifier and detection parser, all can’t be loaded.
edit_or
September 21, 2020, 7:08am
7
Is it Deepstream has some issues or do I have any missing in implementation?
edit_or
September 21, 2020, 9:47am
8
Found out that deepstream-app can load
parse-bbox-func-name=NvDsInferParseCustomResnet
custom-lib-path=libnvds_infercustomparser.so
But I can’t load in my application.
This deepstream-app is hard to understand.
Can somebody help how this deepstream-app can load custom function?
edit_or
September 21, 2020, 1:24pm
9
Now I know. I have
custom-lib-path=/usr/src/tensorrt/CTCGreedyDecoder_Plugin/build/libCTCGreedyDecoder.so
used for my custom layer plugin.
parse-bbox-func-name’s custom parsing also looked for the function in the same lib and can’t find.
How can I set library path if I have both custom layer plugin using IPluginV2DynamicExt and custom parser function for parsing network output?
edit_or
September 21, 2020, 1:41pm
10
Solved the issue by putting custom parser inside custom layer plugin and make a lib for both. Solved.
