• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 6.4 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
i have 2 Resnets and a Yolo is my pipeline. While i define custom lib path in Yolo’s config, Deepstream doesn’t load libnvds_infer.so from that path.
It loads from /opt/nvidia/deepstream/deepstream-6.4/lib.
I want it to load from my own path. because 2 Resnets will use this standard lib and my Yolo will use the custom one.
I compiled my lib for Yolo here:
parse-bbox-func-name=parseBoundingBox
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.4/sources/libs/nvdsinfer/libnvds_infer.so
// Find the output layer by name ("output0")
for (unsigned int i = 0; i < outputLayersInfo.size(); i++)
if (strstr(outputLayersInfo[i].layerName, "output0") != nullptr)
outputLayerIndex = i;
break;
when i compile it, and paste and replace the libnvds_infer.so file in /opt/nvidia/deepstream/deepstream-6.4/lib, my code executes
but if i give path directly to libnvds_infer.so in any other folder except lib, it doesn’t work and the default libnvds_infer.so loads
