External Image Hi, could you help me in debugging this program, this is about parallel sum reduction. if i take a array of 10 numbers, i will compute the sum of these numbers in parallel. heres the logic
1 2 3 4 5 6 7 8
(1+5) (2+6) (3+7) (4+8)
6 8 10 12
(6+10) (8+12)
16 20
(16+20)
36 — this is the answer
following is the code
#include <stdio.h>
#include <cuda.h>
#include <math.h>
global void redsum(int *a, int n)
for(int strid=n; strid>1 ; strid=strid/2) // used to divide size of array in each iteration
int t = blockIdx.x * blockDim.x + threadIdx.x;
if(t<strid/2) //makes sure to find sum upto middle of array in each iteration
a[t]+=a[t+(strid/2)]; //adding first half of array elements to second half of array elemets
// printf(" %d", a[t]); this line could be used in emulation mode
__syncthreads();
main()
int n,i,*a_h,*a_d;
printf(“Enter array size: “);
scanf(”%d”,&n);
size_t size = sizeof(int)*n;
a_h=(int *)malloc(size);
for(i=0;i<n;i++)
a_h[i]=i+1; // initializing array 1,2,3,4...
printf(“\nThe array is: “);
for(i=0;i<n;i++)
printf(”%d “,a_h[i]);
printf(”\n”);
cudaMalloc((void**)&a_d,size);
cudaMemcpy(a_d,a_h,size,cudaMemcpyHostToDevice);
int nb=n/4 + ((n%4==0)?0:1); // i simply took 4 threads in a block, no reason
redsum<<<nb,4>>>(a_d,n);
cudaMemcpy(a_h,a_d,size,cudaMemcpyDeviceToHost);
printf(“\n the sum is: %d”, a_h[0]); //final sum will be in a[0]
return 0;
This program works correctly if u give input as 8. try giving odd numbers like 5 or 9, it doesnt give correct sum for odd numbers. Please help me in debugging this program.
Regards
Sharath
