I’m working on a seminar paper about potential of GPUs at performing image processing related algorithms. I’ve wrote a simple testing program, but I do not have resources to test it. All I have is a laptop with GeForce 9500M GS, and its not enough. I need help from someone with a good GPU. Program is written in C++ for Unix platform (tested on Mac and Ubuntu). Program also requires libpng, png++ and OpenCL dev files. If there is someone with those requirements (or willing to install those few libs) and a little of goodwill, I would really appreciate it. All you need to do is run ‘make’, then ‘make run’ and post results here (with your CPU/GPU specs). Try testing few times to get average results. Once again, I would really appreciate if someone could help.
Here is source. For more info consult README. https://www.dropbox.com/s/hyush0uci9m1wuz/seminar.zip
I run your codes on my desktop with GTX 570 and i5-2500K. The OS is OpenSUSE 12.1 64bit and OpenCL driver is 302.06.03.
OpenCL device:
NVIDIA Corporation GeForce GTX 570
Compute units: 15
Global memory size: 1279 MB
Local memory size: 48 KB
Constant memory size: 64 KB
Max work group size: 1024 work-items
Max number of work items per dimension: [1024, 1024, 64]
Data transfer to the OpenCL device memory completed in 0.61 ms
Starting Non-Maximum Suppression algorithm test (n = 3)
Performing operations on the CPU and on the OpenCL device
CPU running time: 1.424 ms
OpenCL device running time: 0.177 ms
Starting Convolution 2D algorithm test
CPU running time: 3.854 ms
OpenCL device running time: 0.353 ms
zhaopeng@linux-q1vg:~/Downloads/seminar> make run
Executing: ./bin/seminar ./resources/test_image.png 3
OpenCL device:
Compute units: 15
Data transfer to the OpenCL device memory completed in 0.602 ms
CPU running time: 1.466 ms
OpenCL device running time: 0.18 ms
CPU running time: 5.81 ms
OpenCL device running time: 0.34 ms
OpenCL device:
Compute units: 15
Data transfer to the OpenCL device memory completed in 0.945 ms
CPU running time: 1.918 ms
OpenCL device running time: 0.184 ms
CPU running time: 6.92 ms
OpenCL device running time: 0.342 ms
OpenCL device:
Compute units: 15
Data transfer to the OpenCL device memory completed in 0.607 ms
CPU running time: 1.356 ms
OpenCL device running time: 0.155 ms
CPU running time: 4.002 ms
OpenCL device:
Compute units: 15
Data transfer to the OpenCL device memory completed in 0.592 ms
CPU running time: 1.297 ms
OpenCL device running time: 0.188 ms
CPU running time: 4.1 ms
OpenCL device running time: 0.343 ms
OpenCL device:
Compute units: 15
Data transfer to the OpenCL device memory completed in 0.604 ms
CPU running time: 1.373 ms
OpenCL device running time: 0.224 ms
CPU running time: 4.066 ms
OpenCL device running time: 0.341 ms
