NeMo Tookit Intent Slot Example not working
Hi, I setup the NVIDIA nvcr.io/nvidia/nemo:23.06 container, started jupyter, I can go through all steps of the notebook Joint Intent and Slot Filling, GPU is recognized
but if I run training then only 1 epoch there are any changes, all other epoches the same test result and even after 50 epochs nothing new!, nothing comparable with results mentioned in the notebook.
how should I proceed to find the issue? Thank you in advance
Hello @rickyy
You might have better luck getting a response in the NeMo Github discussion area. NVIDIA/NeMo · Discussions · GitHub
Cheers,
Tom
