Two below seems impossible to install through pip, but to build from sources.
pip3 install onnxruntime sentencepiece
However, excluded them from all requirements.txt files and installed the package as a python module also
Does below relative?
exactly!
it runs in a container, natively;
However, the container is for x86_64, as I understand, isnāt it?
I am trying to install it system-wide on Xavier
now I got to build onnx wheel from source
export ONNX_ML=1
python3 setup.py bdist_wheel
pip3 install --upgrade dist/*.whl
Have a check this topic.
However, I will try to assemble it at Xavier manually; From the thread, you pointed to it appears that docker scenario wonāt work.
Building LLVM 9.01:
wget https://github.com/llvm/llvm-project/releases/download/llvmorg-9.0.1/llvm-9.0.1.src.tar.xz
tar -xzf llvm-9.0.1.src.tar.xz
cd llvm-9.0.1.src/
mkdir build
cd build
cmake ../ -DCMAKE_BUILD_TYPE=Release -DLLVM_TARGETS_TO_BUILD="ARM;X86;AArch64"
make -j8
sudo make install
sudo ldconfig
To be continued;
pip3 install git+https://github.com/jschueller/llvmlite.git@patch-1
the patch removes version check and installs lvmlite that wouldnāt otherwise install due to 9 version of LLVM
Some references just in case some other folks will decide to try doing that:
https://github.com/microsoft/onnxruntime/blob/master/BUILD.md
https://github.com/microsoft/onnxruntime/blob/master/BUILD.md#ARM
https://github.com/google/sentencepiece/blob/master/python/README.md
https://github.com/google/sentencepiece#c-from-source
https://devtalk.nvidia.com/default/topic/1049071/jetson-nano/pytorch-for-jetson-nano-version-1-4-0-now-available/post/5428628/#5428628
https://github.com/microsoft/onnxruntime/issues/2684#issuecomment-568548387
Done? It will require to check if it works;
nvidia@nvidia-desktop:~/NeMo$ ./reinstall.sh
Uninstalling stuff
WARNING: Skipping nemo-toolkit as it is not installed.
WARNING: Skipping nemo-asr as it is not installed.
WARNING: Skipping nemo-nlp as it is not installed.
WARNING: Skipping nemo-tts as it is not installed.
WARNING: Skipping nemo-simple-gan as it is not installed.
Installing stuff
Defaulting to user installation because normal site-packages is not writeable
Obtaining file:///home/nvidia/NeMo
Requirement already satisfied: onnx in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (1.6.0)
Requirement already satisfied: pandas in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (1.0.1)
Requirement already satisfied: python-dateutil in /usr/lib/python3/dist-packages (from nemo-toolkit==0.9.0) (2.6.1)
Requirement already satisfied: tensorboardX in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (2.0)
Requirement already satisfied: tensorboard in /usr/local/lib/python3.6/dist-packages (from nemo-toolkit==0.9.0) (2.0.2)
Requirement already satisfied: torch in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (1.4.0)
Requirement already satisfied: torchvision in /usr/local/lib/python3.6/dist-packages/torchvision-0.5.0a0+85b8fbf-py3.6-linux-aarch64.egg (from nemo-toolkit==0.9.0) (0.5.0a0+85b8fbf)
Requirement already satisfied: wget in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (3.2)
Requirement already satisfied: wrapt in /usr/local/lib/python3.6/dist-packages (from nemo-toolkit==0.9.0) (1.11.2)
Requirement already satisfied: boto3 in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (1.11.17)
Requirement already satisfied: frozendict in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (1.2)
Requirement already satisfied: h5py in /usr/local/lib/python3.6/dist-packages (from nemo-toolkit==0.9.0) (2.9.0)
Requirement already satisfied: html2text in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (2020.1.16)
Requirement already satisfied: inflect in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (4.1.0)
Requirement already satisfied: ipdb in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (0.12.3)
Requirement already satisfied: ipython[all] in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (7.12.0)
Requirement already satisfied: jupyterlab in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (1.2.6)
Requirement already satisfied: kaldi-io in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (0.9.1)
Processing /home/nvidia/.cache/pip/wheels/cb/1d/15/a479fa740849128d481333d2f354f97691be3e2c82480a3e00/librosa-0.7.2-py3-none-any.whl
Collecting marshmallow
Using cached marshmallow-3.4.0-py2.py3-none-any.whl (45 kB)
Processing /home/nvidia/.cache/pip/wheels/13/89/ba/ad289fefcfcaa2cab16402f7dedfb96b7015bcb338fc8a8853/matplotlib-3.1.3-cp36-cp36m-linux_aarch64.whl
Processing /home/nvidia/.cache/pip/wheels/e3/c9/b0/ed26a73ef75a53145820825afa8e2d2c9b30fe9f6c10cd3202/nltk-3.4.5-py3-none-any.whl
Collecting num2words
Using cached num2words-0.5.10-py3-none-any.whl (101 kB)
Requirement already satisfied: pillow>=4.3.0 in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (7.0.0)
Processing /home/nvidia/.cache/pip/wheels/bc/13/93/a9bf6b3d3966e4af014b0dbef027fdea47393faf47e990349f/progressbar-2.5-py3-none-any.whl
Requirement already satisfied: requests in /usr/local/lib/python3.6/dist-packages (from nemo-toolkit==0.9.0) (2.22.0)
Collecting ruamel.yaml
Using cached ruamel.yaml-0.16.10-py2.py3-none-any.whl (111 kB)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from nemo-toolkit==0.9.0) (1.11.0)
Collecting sox
Using cached sox-1.3.7-py2.py3-none-any.whl (34 kB)
Requirement already satisfied: tqdm in /home/nvidia/.local/lib/python3.6/site-packages (from nemo-toolkit==0.9.0) (4.41.1)
Collecting unidecode
Using cached Unidecode-1.1.1-py2.py3-none-any.whl (238 kB)
Processing /home/nvidia/.cache/pip/wheels/12/12/87/7c733c4b31d9929b1ba04b70a4fbb73e7e026ac2364475c5d5/youtokentome-1.0.6-cp36-cp36m-linux_aarch64.whl
Collecting parameterized
Using cached parameterized-0.7.1-py2.py3-none-any.whl (24 kB)
Collecting pytest
Using cached pytest-5.3.5-py3-none-any.whl (235 kB)
Collecting pytest-runner
Using cached pytest_runner-5.2-py2.py3-none-any.whl (6.8 kB)
Collecting black
Using cached black-19.10b0-py36-none-any.whl (97 kB)
Collecting isort[requirements]
Using cached isort-4.3.21-py2.py3-none-any.whl (42 kB)
Collecting soundfile
Using cached SoundFile-0.10.3.post1-py2.py3-none-any.whl (21 kB)
Collecting torch-stft
Using cached torch_stft-0.1.4-py3-none-any.whl (6.2 kB)
Collecting torchtext
Using cached torchtext-0.5.0-py3-none-any.whl (73 kB)
Collecting transformers
Using cached transformers-2.4.1-py3-none-any.whl (475 kB)
Collecting pypinyin
Using cached pypinyin-0.37.0-py2.py3-none-any.whl (779 kB)
Requirement already satisfied: scipy in /home/nvidia/.local/lib/python3.6/site-packages/scipy-1.5.0.dev0+566ce19-py3.6-linux-aarch64.egg (from nemo-toolkit==0.9.0) (1.5.0.dev0+566ce19)
Requirement already satisfied: numpy in /usr/local/lib/python3.6/dist-packages (from onnx->nemo-toolkit==0.9.0) (1.16.1)
Requirement already satisfied: typing-extensions>=3.6.2.1 in /home/nvidia/.local/lib/python3.6/site-packages (from onnx->nemo-toolkit==0.9.0) (3.7.4.1)
Requirement already satisfied: protobuf in /usr/local/lib/python3.6/dist-packages (from onnx->nemo-toolkit==0.9.0) (3.11.2)
Requirement already satisfied: pytz>=2017.2 in /usr/lib/python3/dist-packages (from pandas->nemo-toolkit==0.9.0) (2018.3)
Requirement already satisfied: wheel>=0.26; python_version >= "3" in /home/nvidia/.local/lib/python3.6/site-packages (from tensorboard->nemo-toolkit==0.9.0) (0.34.2)
Requirement already satisfied: setuptools>=41.0.0 in /home/nvidia/.local/lib/python3.6/site-packages (from tensorboard->nemo-toolkit==0.9.0) (45.2.0)
Requirement already satisfied: absl-py>=0.4 in /usr/local/lib/python3.6/dist-packages (from tensorboard->nemo-toolkit==0.9.0) (0.9.0)
Requirement already satisfied: werkzeug>=0.11.15 in /usr/local/lib/python3.6/dist-packages (from tensorboard->nemo-toolkit==0.9.0) (0.16.0)
Requirement already satisfied: grpcio>=1.24.3 in /usr/local/lib/python3.6/dist-packages (from tensorboard->nemo-toolkit==0.9.0) (1.26.0)
Requirement already satisfied: google-auth-oauthlib<0.5,>=0.4.1 in /usr/local/lib/python3.6/dist-packages (from tensorboard->nemo-toolkit==0.9.0) (0.4.1)
Requirement already satisfied: google-auth<2,>=1.6.3 in /usr/local/lib/python3.6/dist-packages (from tensorboard->nemo-toolkit==0.9.0) (1.10.1)
Requirement already satisfied: markdown>=2.6.8 in /usr/local/lib/python3.6/dist-packages (from tensorboard->nemo-toolkit==0.9.0) (3.1.1)
Requirement already satisfied: botocore<1.15.0,>=1.14.17 in /home/nvidia/.local/lib/python3.6/site-packages (from boto3->nemo-toolkit==0.9.0) (1.14.17)
Requirement already satisfied: jmespath<1.0.0,>=0.7.1 in /home/nvidia/.local/lib/python3.6/site-packages (from boto3->nemo-toolkit==0.9.0) (0.9.4)
Requirement already satisfied: s3transfer<0.4.0,>=0.3.0 in /home/nvidia/.local/lib/python3.6/site-packages (from boto3->nemo-toolkit==0.9.0) (0.3.3)
Requirement already satisfied: importlib-metadata; python_version < "3.8" in /home/nvidia/.local/lib/python3.6/site-packages (from inflect->nemo-toolkit==0.9.0) (1.5.0)
Requirement already satisfied: traitlets>=4.2 in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (4.3.3)
Requirement already satisfied: jedi>=0.10 in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (0.16.0)
Requirement already satisfied: prompt-toolkit!=3.0.0,!=3.0.1,<3.1.0,>=2.0.0 in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (3.0.3)
Requirement already satisfied: decorator in /usr/lib/python3/dist-packages (from ipython[all]->nemo-toolkit==0.9.0) (4.1.2)
Requirement already satisfied: pickleshare in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (0.7.5)
Requirement already satisfied: pygments in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (2.5.2)
Requirement already satisfied: pexpect; sys_platform != "win32" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (4.8.0)
Requirement already satisfied: backcall in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (0.1.0)
Requirement already satisfied: ipyparallel; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (6.2.4)
Requirement already satisfied: ipykernel; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (5.1.4)
Requirement already satisfied: nbformat; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (5.0.4)
Requirement already satisfied: nose>=0.10.1; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (1.3.7)
Requirement already satisfied: nbconvert; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (5.6.1)
Requirement already satisfied: testpath; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (0.4.4)
Requirement already satisfied: qtconsole; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (4.6.0)
Requirement already satisfied: notebook; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (6.0.3)
Requirement already satisfied: Sphinx>=1.3; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (2.4.1)
Requirement already satisfied: ipywidgets; extra == "all" in /home/nvidia/.local/lib/python3.6/site-packages (from ipython[all]->nemo-toolkit==0.9.0) (7.5.1)
Requirement already satisfied: tornado!=6.0.0,!=6.0.1,!=6.0.2 in /home/nvidia/.local/lib/python3.6/site-packages (from jupyterlab->nemo-toolkit==0.9.0) (6.0.3)
Requirement already satisfied: jinja2>=2.10 in /home/nvidia/.local/lib/python3.6/site-packages (from jupyterlab->nemo-toolkit==0.9.0) (2.11.1)
Requirement already satisfied: jupyterlab-server~=1.0.0 in /home/nvidia/.local/lib/python3.6/site-packages (from jupyterlab->nemo-toolkit==0.9.0) (1.0.6)
Requirement already satisfied: scikit-learn!=0.19.0,>=0.14.0 in /home/nvidia/.local/lib/python3.6/site-packages (from librosa->nemo-toolkit==0.9.0) (0.22.1)
Processing /home/nvidia/.cache/pip/wheels/ba/34/a2/cd1e28caa8e3eda2f77247fcca9c7cf7676800a8807dfe6468/numba-0.48.0-cp36-cp36m-linux_aarch64.whl
Requirement already satisfied: audioread>=2.0.0 in /home/nvidia/.local/lib/python3.6/site-packages (from librosa->nemo-toolkit==0.9.0) (2.1.8)
Requirement already satisfied: joblib>=0.12 in /home/nvidia/.local/lib/python3.6/site-packages (from librosa->nemo-toolkit==0.9.0) (0.14.1)
Processing /home/nvidia/.cache/pip/wheels/cf/d4/04/49d8824a42bd9f9b11d502727965b9997f0d41d2b22ae4f645/resampy-0.2.2-py3-none-any.whl
Processing /home/nvidia/.cache/pip/wheels/60/f6/85/a8b74867c7215481350c351dfe89ce9ee50ac603a37e4e10fa/kiwisolver-1.1.0-cp36-cp36m-linux_aarch64.whl
Requirement already satisfied: pyparsing!=2.0.4,!=2.1.2,!=2.1.6,>=2.0.1 in /home/nvidia/.local/lib/python3.6/site-packages (from matplotlib->nemo-toolkit==0.9.0) (2.4.6)
Collecting cycler>=0.10
Using cached cycler-0.10.0-py2.py3-none-any.whl (6.5 kB)
Processing /home/nvidia/.cache/pip/wheels/3f/2a/fa/4d7a888e69774d5e6e855d190a8a51b357d77cc05eb1c097c9/docopt-0.6.2-py2.py3-none-any.whl
Requirement already satisfied: idna<2.9,>=2.5 in /usr/lib/python3/dist-packages (from requests->nemo-toolkit==0.9.0) (2.6)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/lib/python3/dist-packages (from requests->nemo-toolkit==0.9.0) (1.22)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests->nemo-toolkit==0.9.0) (2018.1.18)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/lib/python3/dist-packages (from requests->nemo-toolkit==0.9.0) (3.0.4)
Processing /home/nvidia/.cache/pip/wheels/e2/b8/ea/62fbbd3e532ea67717f7b561bdb57717515f288f83cdf93065/ruamel.yaml.clib-0.2.0-cp36-cp36m-linux_aarch64.whl
Collecting Click>=7.0
Using cached Click-7.0-py2.py3-none-any.whl (81 kB)
Collecting py>=1.5.0
Using cached py-1.8.1-py2.py3-none-any.whl (83 kB)
Collecting pluggy<1.0,>=0.12
Using cached pluggy-0.13.1-py2.py3-none-any.whl (18 kB)
Requirement already satisfied: packaging in /home/nvidia/.local/lib/python3.6/site-packages (from pytest->nemo-toolkit==0.9.0) (20.1)
Requirement already satisfied: attrs>=17.4.0 in /home/nvidia/.local/lib/python3.6/site-packages (from pytest->nemo-toolkit==0.9.0) (19.3.0)
Requirement already satisfied: wcwidth in /home/nvidia/.local/lib/python3.6/site-packages (from pytest->nemo-toolkit==0.9.0) (0.1.8)
Collecting more-itertools>=4.0.0
Using cached more_itertools-8.2.0-py3-none-any.whl (43 kB)
Collecting appdirs
Using cached appdirs-1.4.3-py2.py3-none-any.whl (12 kB)
Collecting toml>=0.9.4
Using cached toml-0.10.0-py2.py3-none-any.whl (25 kB)
Processing /home/nvidia/.cache/pip/wheels/cc/53/f6/421b969c48a5d993073f7188983e8d26e73871f5ba8c7812d6/typed_ast-1.4.1-cp36-cp36m-linux_aarch64.whl
Processing /home/nvidia/.cache/pip/wheels/6d/21/14/8d92aa843fb7e938385fb3b4386a43b4b9b9375001f59ddd57/regex-2020.1.8-cp36-cp36m-linux_aarch64.whl
Collecting pathspec<1,>=0.6
Using cached pathspec-0.7.0-py2.py3-none-any.whl (25 kB)
Collecting pip-api; extra == "requirements"
Using cached pip_api-0.0.13-py3-none-any.whl (103 kB)
Collecting pipreqs; extra == "requirements"
Using cached pipreqs-0.4.10-py2.py3-none-any.whl (25 kB)
Processing /home/nvidia/.cache/pip/wheels/6c/6b/5c/30ce64a958139dc1f16109f1393d258aa13057d266b58cb486/cffi-1.14.0-cp36-cp36m-linux_aarch64.whl
Requirement already satisfied: sentencepiece in /usr/local/lib/python3.6/dist-packages/sentencepiece-0.1.85-py3.6-linux-aarch64.egg (from torchtext->nemo-toolkit==0.9.0) (0.1.85)
Collecting filelock
Using cached filelock-3.0.12-py3-none-any.whl (7.6 kB)
Processing /home/nvidia/.cache/pip/wheels/03/e9/be/8b52f6e7e8c333b56f9440575b4c5eb4d96d27b5d22df5a71e/sacremoses-0.0.38-py3-none-any.whl
Processing /home/nvidia/.cache/pip/wheels/b4/75/5e/3ea8687989c4678f5bdcc3b64fd832c93f36d9bc27dd6f9577/tokenizers-0.0.11-cp36-cp36m-linux_aarch64.whl
Requirement already satisfied: requests-oauthlib>=0.7.0 in /usr/local/lib/python3.6/dist-packages (from google-auth-oauthlib<0.5,>=0.4.1->tensorboard->nemo-toolkit==0.9.0) (1.3.0)
Requirement already satisfied: cachetools<5.0,>=2.0.0 in /usr/local/lib/python3.6/dist-packages (from google-auth<2,>=1.6.3->tensorboard->nemo-toolkit==0.9.0) (4.0.0)
Requirement already satisfied: pyasn1-modules>=0.2.1 in /usr/local/lib/python3.6/dist-packages (from google-auth<2,>=1.6.3->tensorboard->nemo-toolkit==0.9.0) (0.2.8)
Requirement already satisfied: rsa<4.1,>=3.1.4 in /usr/local/lib/python3.6/dist-packages (from google-auth<2,>=1.6.3->tensorboard->nemo-toolkit==0.9.0) (4.0)
Requirement already satisfied: docutils<0.16,>=0.10 in /home/nvidia/.local/lib/python3.6/site-packages (from botocore<1.15.0,>=1.14.17->boto3->nemo-toolkit==0.9.0) (0.15.2)
Requirement already satisfied: zipp>=0.5 in /home/nvidia/.local/lib/python3.6/site-packages (from importlib-metadata; python_version < "3.8"->inflect->nemo-toolkit==0.9.0) (2.2.0)
Requirement already satisfied: ipython-genutils in /home/nvidia/.local/lib/python3.6/site-packages (from traitlets>=4.2->ipython[all]->nemo-toolkit==0.9.0) (0.2.0)
Requirement already satisfied: parso>=0.5.2 in /home/nvidia/.local/lib/python3.6/site-packages (from jedi>=0.10->ipython[all]->nemo-toolkit==0.9.0) (0.6.1)
Requirement already satisfied: ptyprocess>=0.5 in /home/nvidia/.local/lib/python3.6/site-packages (from pexpect; sys_platform != "win32"->ipython[all]->nemo-toolkit==0.9.0) (0.6.0)
Requirement already satisfied: jupyter-client in /home/nvidia/.local/lib/python3.6/site-packages (from ipyparallel; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (5.3.4)
Requirement already satisfied: pyzmq>=13 in /home/nvidia/.local/lib/python3.6/site-packages (from ipyparallel; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (18.1.1)
Requirement already satisfied: jsonschema!=2.5.0,>=2.4 in /home/nvidia/.local/lib/python3.6/site-packages (from nbformat; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (3.2.0)
Requirement already satisfied: jupyter-core in /home/nvidia/.local/lib/python3.6/site-packages (from nbformat; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (4.6.2)
Requirement already satisfied: defusedxml in /home/nvidia/.local/lib/python3.6/site-packages (from nbconvert; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.6.0)
Requirement already satisfied: mistune<2,>=0.8.1 in /home/nvidia/.local/lib/python3.6/site-packages (from nbconvert; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.8.4)
Requirement already satisfied: bleach in /home/nvidia/.local/lib/python3.6/site-packages (from nbconvert; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (3.1.0)
Requirement already satisfied: entrypoints>=0.2.2 in /home/nvidia/.local/lib/python3.6/site-packages (from nbconvert; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.3)
Requirement already satisfied: pandocfilters>=1.4.1 in /home/nvidia/.local/lib/python3.6/site-packages (from nbconvert; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.4.2)
Requirement already satisfied: Send2Trash in /home/nvidia/.local/lib/python3.6/site-packages (from notebook; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.5.0)
Requirement already satisfied: terminado>=0.8.1 in /home/nvidia/.local/lib/python3.6/site-packages (from notebook; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.8.3)
Requirement already satisfied: prometheus-client in /home/nvidia/.local/lib/python3.6/site-packages (from notebook; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.7.1)
Requirement already satisfied: snowballstemmer>=1.1 in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (2.0.0)
Requirement already satisfied: sphinxcontrib-qthelp in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.0.2)
Requirement already satisfied: sphinxcontrib-devhelp in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.0.1)
Requirement already satisfied: sphinxcontrib-applehelp in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.0.1)
Requirement already satisfied: alabaster<0.8,>=0.7 in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.7.12)
Requirement already satisfied: imagesize in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.2.0)
Requirement already satisfied: babel!=2.0,>=1.3 in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (2.8.0)
Requirement already satisfied: sphinxcontrib-jsmath in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.0.1)
Requirement already satisfied: sphinxcontrib-serializinghtml in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.1.3)
Requirement already satisfied: sphinxcontrib-htmlhelp in /home/nvidia/.local/lib/python3.6/site-packages (from Sphinx>=1.3; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (1.0.2)
Requirement already satisfied: widgetsnbextension~=3.5.0 in /home/nvidia/.local/lib/python3.6/site-packages (from ipywidgets; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (3.5.1)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/lib/python3/dist-packages (from jinja2>=2.10->jupyterlab->nemo-toolkit==0.9.0) (1.0)
Requirement already satisfied: json5 in /home/nvidia/.local/lib/python3.6/site-packages (from jupyterlab-server~=1.0.0->jupyterlab->nemo-toolkit==0.9.0) (0.9.1)
Requirement already satisfied: llvmlite<0.32.0,>=0.31.0dev0 in /home/nvidia/.local/lib/python3.6/site-packages (from numba>=0.43.0->librosa->nemo-toolkit==0.9.0) (0.31.0.dev0+1.g7c14ef0)
Requirement already satisfied: pip in /home/nvidia/.local/lib/python3.6/site-packages (from pip-api; extra == "requirements"->isort[requirements]->nemo-toolkit==0.9.0) (20.0.2)
Collecting yarg
Using cached yarg-0.1.9-py2.py3-none-any.whl (19 kB)
Processing /home/nvidia/.cache/pip/wheels/c6/6b/83/2608afaa57ecfb0a66ac89191a8d9bad71c62ca55ee499c2d0/pycparser-2.19-py2.py3-none-any.whl
Requirement already satisfied: oauthlib>=3.0.0 in /usr/local/lib/python3.6/dist-packages (from requests-oauthlib>=0.7.0->google-auth-oauthlib<0.5,>=0.4.1->tensorboard->nemo-toolkit==0.9.0) (3.1.0)
Requirement already satisfied: pyasn1<0.5.0,>=0.4.6 in /usr/local/lib/python3.6/dist-packages (from pyasn1-modules>=0.2.1->google-auth<2,>=1.6.3->tensorboard->nemo-toolkit==0.9.0) (0.4.8)
Requirement already satisfied: pyrsistent>=0.14.0 in /home/nvidia/.local/lib/python3.6/site-packages (from jsonschema!=2.5.0,>=2.4->nbformat; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.15.7)
Requirement already satisfied: webencodings in /usr/lib/python3/dist-packages (from bleach->nbconvert; extra == "all"->ipython[all]->nemo-toolkit==0.9.0) (0.5)
Installing collected packages: numba, pycparser, cffi, soundfile, resampy, librosa, marshmallow, kiwisolver, cycler, matplotlib, nltk, docopt, num2words, progressbar, ruamel.yaml.clib, ruamel.yaml, sox, unidecode, Click, youtokentome, parameterized, py, pluggy, more-itertools, pytest, pytest-runner, appdirs, toml, typed-ast, regex, pathspec, black, pip-api, yarg, pipreqs, isort, torch-stft, torchtext, filelock, sacremoses, tokenizers, transformers, pypinyin, nemo-toolkit
Running setup.py develop for nemo-toolkit
Successfully installed Click-7.0 appdirs-1.4.3 black-19.10b0 cffi-1.14.0 cycler-0.10.0 docopt-0.6.2 filelock-3.0.12 isort-4.3.21 kiwisolver-1.1.0 librosa-0.7.2 marshmallow-3.4.0 matplotlib-3.1.3 more-itertools-8.2.0 nemo-toolkit nltk-3.4.5 num2words-0.5.10 numba-0.48.0 parameterized-0.7.1 pathspec-0.7.0 pip-api-0.0.13 pipreqs-0.4.10 pluggy-0.13.1 progressbar-2.5 py-1.8.1 pycparser-2.19 pypinyin-0.37.0 pytest-5.3.5 pytest-runner-5.2 regex-2020.1.8 resampy-0.2.2 ruamel.yaml-0.16.10 ruamel.yaml.clib-0.2.0 sacremoses-0.0.38 soundfile-0.10.3.post1 sox-1.3.7 tokenizers-0.0.11 toml-0.10.0 torch-stft-0.1.4 torchtext-0.5.0 transformers-2.4.1 typed-ast-1.4.1 unidecode-1.1.1 yarg-0.1.9 youtokentome-1.0.6
All done!
python3
Python 3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import nemo
~/NeMo$ python3
>>> import nemo
>>> import torch
>>> import amp_C
Apex also seems to function:
python3
>>> import nemo
>>> import torch
>>> import amp_C
>>> import argparse
>>> import os
>>> from apex import amp
>>> # FOR DISTRIBUTED: (can also use torch.nn.parallel.DistributedDataParallel instead)
... from apex.parallel import DistributedDataParallel
>>> parser = argparse.ArgumentParser()
>>> # FOR DISTRIBUTED: Parse for the local_rank argument, which will be supplied
... # automatically by torch.distributed.launch.
... parser.add_argument("--local_rank", default=0, type=int)
_StoreAction(option_strings=['--local_rank'], dest='local_rank', nargs=None, const=None, default=0, type=<class 'int'>, choices=None, help=None, metavar=None)
>>> args = parser.parse_args()
>>> # FOR DISTRIBUTED: If we are running under torch.distributed.launch,
... # the 'WORLD_SIZE' environment variable will also be set automatically.
... args.distributed = False
>>> if 'WORLD_SIZE' in os.environ:
... args.distributed = int(os.environ['WORLD_SIZE']) > 1
>>> if args.distributed:
... # FOR DISTRIBUTED: Set the device according to local_rank.
... torch.cuda.set_device(args.local_rank)
>>> # FOR DISTRIBUTED: Initialize the backend. torch.distributed.launch will provide
... # environment variables, and requires that you use init_method=`env://`.
... torch.distributed.init_process_group(backend='nccl',
File "<stdin>", line 3
IndentationError: unexpected indent
>>> init_method='env://')
File "<stdin>", line 1
>>> torch.backends.cudnn.benchmark = True
>>> N, D_in, D_out = 64, 1024, 16
>>> # Each process receives its own batch of "fake input data" and "fake target data."
... # The "training loop" in each process just uses this fake batch over and over.
... # https://github.com/NVIDIA/apex/tree/master/examples/imagenet provides a more realistic
... # example of distributed data sampling for both training and validation.
... x = torch.randn(N, D_in, device='cuda')
>>> y = torch.randn(N, D_out, device='cuda')
>>> model = torch.nn.Linear(D_in, D_out).cuda()
>>> optimizer = torch.optim.SGD(model.parameters(), lr=1e-3)
>>> model, optimizer = amp.initialize(model, optimizer, opt_level="O1")
Selected optimization level O1: Insert automatic casts around Pytorch functions and Tensor methods.
Defaults for this optimization level are:
enabled : True
opt_level : O1
cast_model_type : None
patch_torch_functions : True
keep_batchnorm_fp32 : None
master_weights : None
loss_scale : dynamic
Processing user overrides (additional kwargs that are not None)...
After processing overrides, optimization options are:
enabled : True
opt_level : O1
... # FOR DISTRIBUTED: After amp.initialize, wrap the model with
... # apex.parallel.DistributedDataParallel.
... model = DistributedDataParallel(model)
... # torch.nn.parallel.DistributedDataParallel is also fine, with some added args:
... # model = torch.nn.parallel.DistributedDataParallel(model,
... # device_ids=[args.local_rank],
... # output_device=args.local_rank)
>>> loss_fn = torch.nn.MSELoss()
>>> for t in range(500):
... optimizer.zero_grad()
... y_pred = model(x)
... loss = loss_fn(y_pred, y)
... with amp.scale_loss(loss, optimizer) as scaled_loss:
... scaled_loss.backward()
... optimizer.step()
>>> if args.local_rank == 0:
... print("final loss = ", loss)
final loss = tensor(0.2006, device='cuda:0', grad_fn=<MseLossBackward>)
~/NeMo/examples/start_here$ python3 simplest_example.py
[NeMo W 2020-02-14 08:28:16 deprecated:66] Function ``_get_trainer`` is deprecated. It is going to be removed in the future version.
[NeMo I 2020-02-14 08:28:18 callbacks:177] Starting .....
[NeMo I 2020-02-14 08:28:18 callbacks:188] Starting epoch 0
[NeMo I 2020-02-14 08:28:19 callbacks:212] Step: 0
[NeMo I 2020-02-14 08:28:19 simplest_example:23] Train Loss: 137.61636352539062
[NeMo I 2020-02-14 08:28:19 callbacks:227] Step time: 0.521796464920044 seconds
[NeMo I 2020-02-14 08:28:19 callbacks:212] Step: 25
[NeMo I 2020-02-14 08:28:19 simplest_example:23] Train Loss: 5.390845775604248
[NeMo I 2020-02-14 08:28:19 callbacks:227] Step time: 0.0047686100006103516 seconds
[NeMo I 2020-02-14 08:28:20 callbacks:212] Step: 50
[NeMo I 2020-02-14 08:28:20 simplest_example:23] Train Loss: 0.513081431388855
[NeMo I 2020-02-14 08:28:20 callbacks:227] Step time: 0.0037953853607177734 seconds
[NeMo I 2020-02-14 08:28:20 callbacks:212] Step: 75
[NeMo I 2020-02-14 08:28:20 simplest_example:23] Train Loss: 0.14851737022399902
[NeMo I 2020-02-14 08:28:20 callbacks:227] Step time: 0.004103422164916992 seconds
[NeMo I 2020-02-14 08:28:20 callbacks:195] Finished epoch 0 in 1.2237584590911865
[NeMo I 2020-02-14 08:28:20 callbacks:188] Starting epoch 1
[NeMo I 2020-02-14 08:28:20 callbacks:212] Step: 100
[NeMo I 2020-02-14 08:28:20 simplest_example:23] Train Loss: 0.09763915836811066
[NeMo I 2020-02-14 08:28:20 callbacks:227] Step time: 0.005318403244018555 seconds
[NeMo I 2020-02-14 08:28:20 callbacks:212] Step: 125
[NeMo I 2020-02-14 08:28:20 simplest_example:23] Train Loss: 0.06433030962944031
[NeMo I 2020-02-14 08:28:20 callbacks:227] Step time: 0.0040569305419921875 seconds
[NeMo I 2020-02-14 08:28:20 callbacks:212] Step: 150
[NeMo I 2020-02-14 08:28:20 simplest_example:23] Train Loss: 0.07112766802310944
[NeMo I 2020-02-14 08:28:20 callbacks:227] Step time: 0.003978252410888672 seconds
[NeMo I 2020-02-14 08:28:20 callbacks:195] Finished epoch 1 in 0.5387179851531982
[NeMo I 2020-02-14 08:28:20 callbacks:188] Starting epoch 2
[NeMo I 2020-02-14 08:28:20 callbacks:212] Step: 175
[NeMo I 2020-02-14 08:28:20 simplest_example:23] Train Loss: 0.05760573223233223
[NeMo I 2020-02-14 08:28:20 callbacks:227] Step time: 0.004065036773681641 seconds
[NeMo I 2020-02-14 08:28:21 callbacks:212] Step: 200
[NeMo I 2020-02-14 08:28:21 simplest_example:23] Train Loss: 0.04851408302783966
[NeMo I 2020-02-14 08:28:21 callbacks:227] Step time: 0.0040225982666015625 seconds
[NeMo I 2020-02-14 08:28:21 callbacks:212] Step: 225
[NeMo I 2020-02-14 08:28:21 simplest_example:23] Train Loss: 0.046431295573711395
[NeMo I 2020-02-14 08:28:21 callbacks:227] Step time: 0.004041910171508789 seconds
[NeMo I 2020-02-14 08:28:21 callbacks:195] Finished epoch 2 in 0.5276029109954834
[NeMo I 2020-02-14 08:28:21 callbacks:184] Done in 2.291908025741577
Thanks for providing this build recipe. Unfortunately my attempts to install Nemo fail at pip-install of package ātokenizers 0.0.11ā with some error from rustc/cargo (these are tools used internally for building tokenizers).
May I ask you to run ārustc -Vā and ācargo -Vā in your environment and provide me the output? Thanks in advance.
[rust] it needs first to be installed and then path to it needs to be maintained;
Thanks for the reply. I already have Rust/Cargo installed. As I told the Rust/Cargo compiler fails in the middle of the build process. After some googling I suspect some version incompatibilty. I have Rust/Cargo version 1.37.0.
rustc -V
rustc 1.41.0 (5e1a79984 2020-01-27)
how did you end up getting 1.37 version?
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
I have installed Rust/Cargo from the apt package. Uninstalled them, then ran Rustup, now tokenizers builds without errors. Thanks for the help.
Yet I wasnāt able to build onnxruntime-gpu whl with cuda support cudnn and tensorrt, but just onnxruntime CPU, but folks reported it to work for jetson nano , and tx2. Thus it should be a matter of time to sort out cuda support on Xavier, in my opinion
I have build a onnx-runtime wheel with GPU/Cuda and TensorRT support for Xavier: Release onnxruntime GPU TensorRT Ā· domcross/Jetson-Xavier-AGX-stuff Ā· GitHub
Thank you for sharing!
did you use the command like the below to build the wheel?
/build.sh --config Release --update --build --build_wheel --use_tensorrt --cuda_home /usr/local/cuda --cudnn_home /usr/lib/aarch64-linux-gnu --tensorrt_home /usr/lib/aarch64-linux-gnu
Unfortunately I did not document how I have done the wheel-build. I remember following the CUDA section of the build instructions.
So most likely it was something like
./build.sh --use_cuda --cudnn_home <cudnn home path> --cuda_home <cuda home path> --build_wheel
Donāt remember if I have added ohter flags like --config, --update or --build etc.
Thank you both for this discussion. Iām making progress a little at a time. Iām trying to install NeMo in Xavier/Jetpack. Failure is occuring when I run NeMo/reinstall.sh. The associated discussions are:
I first got around the onnxruntime issue by removing the requirements.txt entries but was also able to build the wheel at Release onnxruntime GPU TensorRT Ā· domcross/Jetson-Xavier-AGX-stuff Ā· GitHub. Havenāt hit any new onnx or the rustc/cargo issue yet but expect to hit rustc/cargo at some point.
My current issue is with sentencepiece. In discussion 1 above, it seems you were able to build sentencepiece. No matter how I try to build it I get this error: FileNotFoundError: [Errno 2] No such file or directory: āā¦/VERSIONā
GitHub topics seem to say thereās some python version compatibility problem. I think reinstall.sh is running 3.6 but Iām not sure - that is installed. Any way to un-block me on that? Thanks!
