NemoClaw on Jetson Orin Family – Setup Guide
System Info
| Component | Version |
| Board | NVIDIA Jetson Orin |
| JetPack | 6.2.2 (L4T R36.5.0) |
| Kernel | 5.15.185-tegra |
| OS | Ubuntu 22.04.5 LTS (aarch64) |
| Docker | with iptables-legacy needed |
| OpenShell | 0.0.13 |
| Node.js | v22.22.1 |
Problems Encountered
The stock NemoClaw installer (curl -fsSL ``https://www.nvidia.com/nemoclaw.sh`` | bash)
hits three issues on Jetson Orin that must be fixed before running it.
Problem 1: iptables nf_tables not supported by Tegra kernel
The OpenShell cluster image uses iptables v1.8.10 (nf_tables) by default.
The Tegra 5.15 kernel does not have full nf_tables support, causing k3s (inside
the cluster container) to panic:
iptables v1.8.10 (nf_tables): RULE_INSERT failed (No such file or directory)
Extension conntrack revision 0 not supported, missing kernel module?
Fix: Patch the cluster image to use iptables-legacy before running the installer.
Problem 2: br_netfilter kernel module not loaded
Without br_netfilter, bridged pod-to-pod traffic inside k3s bypasses iptables.
This breaks Kubernetes ClusterIP service routing, specifically DNS resolution.
The sandbox pod crashes in a loop with:
failed to connect to OpenShell server: dns error: Temporary failure in name resolution
Root cause: DNAT rewrites the destination on outbound packets, but without
br_netfilter, reply packets traverse the Linux bridge at L2 and skip the
reverse-NAT in conntrack. The client sees replies from the wrong source IP and
drops them.
Fix: Load br_netfilter and enable bridge-nf-call-iptables.
Problem 3: Ollama listens on 127.0.0.1 only
If using local Ollama for inference, it defaults to 127.0.0.1:11434 which is
unreachable from inside the OpenShell sandbox container. The onboarding fails at
step [5/7] with:
containers cannot reach http://host.openshell.internal:11434
Fix: Configure Ollama to listen on 0.0.0.0:11434.
Prerequisites
Step 0a: Install curl
sudo apt install curl
Step 0b: Install Docker
Remove any old Docker packages:
sudo apt-get remove docker docker-engine docker.io containerd runc
Add Docker’s official GPG key and repository:
sudo apt-get update
sudo apt-get install ca-certificates curl
sudo install -m 0755 -d /etc/apt/keyrings
sudo curl -fsSL https://download.docker.com/linux/ubuntu/gpg -o /etc/apt/keyrings/docker.asc
sudo chmod a+r /etc/apt/keyrings/docker.asc
echo \
"deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/ubuntu \
$(. /etc/os-release && echo "$VERSION_CODENAME") stable" | \
sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin
Step 0c: Install NVIDIA Container Toolkit
curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey \
| sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg
curl -s -L https://nvidia.github.io/libnvidia-container/stable/deb/nvidia-container-toolkit.list \
| sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' \
| sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
sudo apt-get update
sudo apt-get install -y nvidia-container-toolkit
Configure the toolkit for all runtimes:
sudo nvidia-ctk runtime configure --runtime=docker
sudo nvidia-ctk runtime configure --runtime=containerd
sudo nvidia-ctk runtime configure --runtime=crio
sudo systemctl restart docker
sudo systemctl restart containerd
sudo systemctl restart crio
Step 0d: Add user to the docker group
sudo chmod 666 /var/run/docker.sock
sudo groupadd docker
sudo usermod -aG docker $USER
newgrp docker
Step 0e: Set NVIDIA as default Docker runtime
This is needed so that the NVCC compiler and GPU are available during
docker build operations. Edit /etc/docker/daemon.json:
sudo nano /etc/docker/daemon.json
Set the contents to:
"runtimes": {
"nvidia": {
"path": "nvidia-container-runtime",
"runtimeArgs": []
"default-runtime": "nvidia"
Then reconfigure and restart:
sudo systemctl enable docker.service
sudo systemctl enable containerd.service
NemoClaw Setup Steps
Run these steps in order before launching the NemoClaw installer.
Step 1: Load br_netfilter kernel module
sudo modprobe br_netfilter
sudo sysctl -w net.bridge.bridge-nf-call-iptables=1
Make it persistent across reboots:
echo br_netfilter | sudo tee /etc/modules-load.d/k8s.conf
echo 'net.bridge.bridge-nf-call-iptables = 1' | sudo tee /etc/sysctl.d/k8s.conf
Step 2: Patch the OpenShell cluster image to use iptables-legacy
The installer pulls ghcr.io/nvidia/openshell/cluster:0.0.13 and uses it
directly. We patch it in-place so the installer picks up the fixed version.
IMAGE_NAME="ghcr.io/nvidia/openshell/cluster:0.0.13"
docker run --entrypoint sh --name fix-iptables "$IMAGE_NAME" -c '
update-alternatives --set iptables /usr/sbin/iptables-legacy
update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
ln -sf /usr/sbin/iptables-legacy /usr/sbin/iptables
ln -sf /usr/sbin/ip6tables-legacy /usr/sbin/ip6tables
iptables --version
docker commit \
--change 'ENTRYPOINT ["/usr/local/bin/cluster-entrypoint.sh"]' \
docker rm fix-iptables
You should see iptables v1.8.10 (legacy) in the output.
Important: If the installer re-pulls the image (e.g., on a retry after
cleanup), this patch is lost. Re-run this step before each installer attempt.
Step 3: Configure Ollama to listen on all interfaces
Skip this step if using NVIDIA cloud inference (build.nvidia.com) instead of local Ollama.
sudo mkdir -p /etc/systemd/system/ollama.service.d
echo -e '[Service]\nEnvironment="OLLAMA_HOST=0.0.0.0:11434"' \
| sudo tee /etc/systemd/system/ollama.service.d/override.conf
sudo systemctl daemon-reload
sudo systemctl restart ollama
Verify:
ss -tlnp | grep 11434
# Should show 0.0.0.0:11434, NOT 127.0.0.1:11434
Step 4: Run the NemoClaw installer
curl -fsSL https://www.nvidia.com/nemoclaw.sh | bash
During onboarding, you will be prompted for:
- Sandbox name: accept the default
my-assistantor choose your own - Inference option: choose
2for local Ollama - Ollama model: choose from available models (e.g.,
qwen3.5:2b)
The Docker image build at step [3/7] takes ~10 minutes on Orin (first run, no
cache). Subsequent runs are faster due to layer caching.
Verification
After successful onboarding, the dashboard should be accessible at:
http://127.0.0.1:18789/
The OpenShell gateway runs at:
https://127.0.0.1:8080
Troubleshooting
Check if the sandbox pod is healthy
docker exec openshell-cluster-nemoclaw kubectl get pods -n openshell
Check sandbox pod logs
docker exec openshell-cluster-nemoclaw kubectl logs -n openshell my-assistant
Test DNS inside the cluster
docker exec openshell-cluster-nemoclaw kubectl run dns-test \
--namespace=openshell \
--image=rancher/mirrored-library-busybox:1.37.0 \
--restart=Never \
-- nslookup openshell.openshell.svc.cluster.local
sleep 10
docker exec openshell-cluster-nemoclaw kubectl logs -n openshell dns-test
docker exec openshell-cluster-nemoclaw kubectl delete pod -n openshell dns-test
Check iptables version inside the cluster
docker exec openshell-cluster-nemoclaw iptables --version
# Must say "(legacy)", NOT "(nf_tables)"
Check br_netfilter is active
lsmod | grep br_netfilter
cat /proc/sys/net/bridge/bridge-nf-call-iptables
# Must output: 1
Clean up and start fresh
# Stop and remove everything
source ~/.bashrc
nemoclaw destroy 2>/dev/null
docker rm -f openshell-cluster-nemoclaw 2>/dev/null
docker volume prune -f
# Then re-run from Step 2 above
