Nemotron-3-Super 120B on GB10 — llama.cpp sm_121 build + Ollama GGUF incompatibility fix
Running Nemotron-3-Super 120B on DGX Spark GB10 (sm_121) — build recipe,
benchmarks, and a non-obvious GGUF compatibility fix. Sharing in case
useful while native sm_121 support matures.
Key findings:
  • llama.cpp built natively for sm_121 (commit 463b6a963, CUDA 13.0,
    Driver 580.126.09) runs at ~14.4 t/s — effectively identical to
    Ollama’s 14.2 t/s at this scale (memory-bandwidth bound)
  • Ollama’s MoE GGUF blobs are NOT compatible with upstream llama.cpp:
    blk.1.ffn_down_exps.weight has wrong shape; expected 4096 got 1024
    Ollama packs expert weights differently — must use ggml-org GGUF separately
  • ggml-org Q4_K (66GB) saves ~20GB vs Ollama’s Q4_K_M (86GB)
  • OOM pitfall on load: drop page cache first (sudo sh -c ‘sync; echo 3 > /proc/sys/vm/drop_caches’)
Full package:
Files:
  • BUILD_RECIPE.md — exact build steps, environment, errors encountered
  • BENCHMARK_RESULTS.md — honest analysis, no inflated claims
  • run_server.sh — drop-in LAN server script
  • nemotron_super.modelfile — Ollama config with reasoning params
  • COMMUNITY_POST.md — full writeup
Hardware: DGX Spark GB10, 128GB unified memory, Ubuntu 24.04, CUDA 13.0
Thank you for the fix, I will move this to GB10 projects
How’s the quality of Q4_K? Any chance of getting Q5_K_M to run?
thank you Kidtronic for the question, it inspired me to run some tests as I have been on other projects but heres is what I found ..
[earlier post] about running Nemotron-3-Super 120B with a native sm_121 llama.cpp build. Several people asked about the official NVFP4 checkpoint — can you run it on Spark? How does quality compare? We spent a full session trying to find out.
**Short answer:** The GGUF is the only path that works on Spark today. The NVFP4 checkpoint cannot load — blocked at the kernel level, not just config.
## The Practical Reality: GGUF vs NVFP4 on DGX Spark
The GGUF path requires building llama.cpp from source (see [original post](COMMUNITY_POST.md) for the full recipe), but once you have the binary it’s straightforward:
1. Build llama.cpp targeting sm_121 (~3 min compile, one-time)
2. Download one file — the [ggml-org Q4_K GGUF]( https://huggingface.co/ggml-org/nemotron-3-super-120b-GGUF ) (66 GB)
3. Run `llama-server -m model.gguf`
The NVFP4 path requires a compatible vLLM build with CUDA 13 support, the right Docker image, correct quantization config handling, and NemotronH-specific MoE kernels. As of March 2026, none of these pieces fully exist for sm_121. We hit three separate layers of failure trying to make it work — details below.
## What Happened When We Tried NVFP4
### Layer 1: Config validation (fixable)
The community `avarok/vllm-dgx-spark` Docker image (vLLM 0.14, built Jan 2026) doesn’t recognize the NVFP4 model’s `MIXED_PRECISION` quantization config. The model was released March 11 — two months after the image was built. The model uses a mix of NVFP4 (40,961 layers) and FP8 (139 layers), which the older vLLM doesn’t expect.
ValueError: ModelOpt currently only supports: [‘FP8’, ‘FP8_PER_CHANNEL_PER_TOKEN’,
‘FP8_PB_WO’, ‘NVFP4’] quantizations in vLLM.
We patched the ModelOpt quantization module to accept `MIXED_PRECISION` and route it to the NVFP4 handler. Config validation passed.
### Layer 2: MoE kernel incompatibility (not fixable today)
NotImplementedError: No NvFp4 MoE backend supports the deployment configuration.
All 5 available NVFP4 MoE backends (FLASHINFER_TRTLLM, FLASHINFER_CUTEDSL, FLASHINFER_CUTLASS, VLLM_CUTLASS, MARLIN) require fused `act_and_mul` MLP layers. NemotronH uses `relu2` activation with separate projections in its LatentMoE — a different architecture than standard MoE models like Mixtral or DeepSeek. We force-selected Marlin specifically and got:
ValueError: NvFp4 MoE backend ‘MARLIN’ does not support the deployment
configuration since kernel does not support no act_and_mul MLP layer.
This is a kernel-level limitation. No config change or patch fixes it.
### Layer 3: No pip escape hatch either
Tried installing vLLM 0.18.0 natively (the version the model README recommends). The pip wheels are compiled against CUDA 12 — Spark runs CUDA 13. Immediate import failure on `libcudart.so.12`.
### What would unblock NVFP4
- vLLM 0.18+ built for CUDA 13 + sm_121 with NemotronH-compatible MoE kernels
- CUDA 13.2+ (may bring native NVFP4 dispatch for Blackwell)
- An updated `avarok/vllm-dgx-spark` image with these fixes
## GGUF Quality: What We Actually Tested
**Important caveat:** This is not a rigorous benchmark. We ran 8 prompts and checked responses for basic correctness (keyword presence, correct answers). We have no BF16 or NVFP4 baseline to compare against, so we cannot make claims about how much quality the Q4_K quantization loses. We can only say whether the responses are correct and coherent.
We used temperature=1.0 and top_p=0.95 — these are NVIDIA’s recommended settings for the NVFP4 model. We applied the same settings to the GGUF for consistency, though NVIDIA does not publish recommended settings for the GGUF specifically.
| Task | Tokens | Speed | Result |
| Code Generation (Fibonacci w/ memoization) | 882 | 16.9 t/s | Correct implementation with input validation and complexity analysis |
| Lateral Thinking (Monopoly riddle) | 189 | 16.7 t/s | Correct answer (Monopoly) with explanation |
| General Knowledge (photosynthesis vs respiration) | 1,605 | 17.2 t/s | Accurate, well-organized comparison |
| Math (sum of odds 1-100) | 337 | 17.0 t/s | Correct answer (2500) with step-by-step arithmetic sequence formula |
| Instruction Following (5 Asian countries with ‘I’) | 224 | 16.9 t/s | Exactly 5 items, numbered as requested |
| Creative (haiku about GPU) | 340 | 17.0 t/s | Valid 5-7-5 syllable structure |
| Technical Analysis (TCP vs UDP) | 1,669 | 17.3 t/s | Accurate comparison with use-case recommendations |
| Multi-step Reasoning (“all but 9” trick) | 290 | 16.9 t/s | Correct answer (9) with reasoning about the phrasing |
**Average: 16.99 t/s across 5,536 total tokens generated.**
All responses were factually correct for the prompts we tested. The model handled a reasoning trick question (“all but 9”) and a lateral thinking puzzle (Monopoly) without stumbling. Whether this holds up on harder benchmarks (MMLU-Pro, LiveCodeBench, etc.) — we don’t know. NVIDIA’s model card shows NVFP4 scores ~0.4% below BF16 on MMLU-Pro (83.33 vs 83.73); the GGUF Q4_K would likely lose more since it’s post-training quantized rather than trained at lower precision, but we haven’t measured this.
## How to Reproduce
### Prerequisites
- DGX Spark with llama.cpp built for sm_121 (see [original post](COMMUNITY_POST.md) for build recipe — requires cmake, CUDA toolkit 13.0)
- The ggml-org GGUF: [ggml-org/nemotron-3-super-120b-GGUF]( ggml-org/Nemotron-3-Super-120B-GGUF · Hugging Face ) (Q4_K, 66 GB)
### Step 1: Clear the system
The 66 GB model needs ~71 GB at runtime. You need a clean memory state.
```bash
# Stop anything holding GPU memory ( For Example )
sudo systemctl stop ollama
pkill -f llama-server
# Drop page cache
# Verify you have headroom
free -g # check the “available” column, should show 110+ GB
### Step 2: Start the server
```bash
llama-server \
-m /path/to/Nemotron-3-Super-120B-Q4_K.gguf \
--port 8090 \
–host 0.0.0.0 \
-ngl 99 \
-fa on \
-c 8192 \
–metrics
Model load takes ~6 minutes (mmap’ing 66 GB). Wait until you see `HTTP server listening` in the output.
### Step 3: Test it
```bash
curl -s http://localhost:8090/v1/chat/completions \
-H “Content-Type: application/json” \
-d '{
"messages": \[{"role": "user", "content": "What is the sum of all odd numbers from 1 to 100?"}\],
"max_tokens": 2048,
"temperature": 1.0,
"top_p": 0.95
}’ | python3 -m json.tool
Or use the benchmark script which runs all 8 prompts and captures full responses + speed metrics:
```bash
git clone https://gist.github.com/ nemo3_super_benchmarks
cd nemo3_super_benchmarks
python3 quality_compare.py gguf
### Memory breakdown
| Component | Size |
| Model weights (mmap) | 66 GB |
| KV cache (8192 context) | ~4 GB |
| CUDA context + buffers | ~1 GB |
| **Total runtime** | **~71 GB** |
The `free` command may show low “free” but check the “available” column — Linux page cache is reclaimable. You should have ~50 GB available for other processes.
## Speed comparison across our tests
| Date | Build | max_tokens | Prompts | Avg t/s |
| March 22 | llama.cpp build 924 (01d8eaa) | 2048 | 8 | **16.99** |
| March 14 | llama.cpp 463b6a963 | 512 | 4 | 14.43 |
| March 13 | Ollama (sm_120) | default | 4 | 14.18 |
The March 22 test used a newer llama.cpp build, higher max_tokens, and more prompts than the March 14 test — multiple variables changed, so we can’t attribute the speed difference to any single factor. The takeaway is that this model runs at roughly 14-17 t/s on Spark depending on build and settings.
## Bottom Line
If you’re on DGX Spark and want to run Nemotron-3-Super 120B today, the GGUF is the only working path. It requires a one-time llama.cpp build, a 66 GB download, and a single command to serve. Responses were correct across the prompts we tested, and generation runs at ~17 t/s.
The NVFP4 checkpoint is blocked by missing MoE kernel support in vLLM for NemotronH’s architecture. This isn’t a config issue — the kernels need to be updated for the LatentMoE layer structure. We’ll update when this changes.
*Tested on DGX Spark (GB10, Ubuntu 24.04, CUDA 13.0, Driver 580.126.09), llama.cpp build 924 (01d8eaa), March 2026.*
I have nemotron3 super 120B running on ollama v0.24 with 512K context window stably, on my dgx spark.
It breaks if you upgrade to ollama v0.30 or above as it switches to llama.cpp under the covers.
Tested on DGX Spark (GB10, Ubuntu 24.04.4 LTS, aarch64, kernel 6.17.0-1021-nvidia, 128 GB unified memory, CUDA 13.0, Driver 580.159.03), Ollama 0.24.0, nemotron-3-super-512k (nemotron_h_moe, 123.6B-A12B MoE, Q4_K_M ~87 GB, 524288 context), July 2026.
Any particular reason you wanted to run with with llamacpp rather than native nvfp4 in vllm? Just curious.
hi,
that was back in march where kernel , nvfp4 support etc were not as well developed but quickly evolving for the better.
Just use the Puzzle-75B.
It’s faster, tool calling actually works well, and it’s specifically tuned for agents. The full 120B via GGUF is slower and more annoying for what you’re doing. I am currently getting 19 tok/s but am using it on my own app i built, working to optimize it, but try it, this is my current recipe:
recipe_version: “1”
description: Fast vLLM config for Nemotron-Labs-3-Puzzle-75B-A9B-NVFP4 on DGX Spark (recommended)
model: nvidia/NVIDIA-Nemotron-Labs-3-Puzzle-75B-A9B-NVFP4
container: vllm-node
env:
VLLM_MEMORY_PROFILER_ESTIMATE_CUDAGRAPHS: “0”
defaults:
port: 8000
host: 0.0.0.0
tensor_parallel: 2
gpu_memory_utilization: 0.82
max_model_len: 24576
max_num_batched_tokens: 16384
max_num_seqs: 8
command: |
vllm serve nvidia/NVIDIA-Nemotron-Labs-3-Puzzle-75B-A9B-NVFP4 \
–tensor-parallel-size {tensor_parallel} \
–host {host} \
–port {port} \
–trust-remote-code \
–enable-expert-parallel \
–mamba-backend flashinfer \
–mamba_ssm_cache_dtype float16 \
–enable-mamba-cache-stochastic-rounding \
–mamba-cache-philox-rounds 5 \
–async-scheduling \
–kv-cache-dtype fp8 \
–gpu-memory-utilization {gpu_memory_utilization} \
–max-model-len {max_model_len} \
–max-num-batched-tokens {max_num_batched_tokens} \
–max-num-seqs {max_num_seqs} \
–enable-chunked-prefill \
–enable-prefix-caching \
–tool-call-parser qwen3_coder \
–reasoning-parser nemotron_v3 \
–enable-auto-tool-choice \
–generation-config vllm
