Hello everybody,
i have a foreach call function that is getting nested zip(tuple(zip(tuple()),zip(tuple()))) iterators because the tuples. THis is becuase i have more than ten in- and output vectors. WHen i trry to modify the output vectors it has no effect tho when doping it like
thrust::tuple<double,double,double,double> outputs=get<0>(thewholeinputtoforeach);
thrust::get<0>(output)= SOMEFUNCTION OF OTHER STUFF
I believe this doesnt work because the first line creates a deep copy of the output and changes the copy, not the output.
Trying it like this
thrust::get<0>(thrust::get<0>(thewholeinputtoforeach)= SOMEFUNCTION OF OTHER STUFF
errors with “error: expression must be a modifiable lvalue”
SO somehow i guess i have to create reference to the output iterator with pointers, but i don’t manage to.
Nay tips and ideas are highly appreciated.
best regards
Franz
It’s not clear what the problem is. The following seems to work for me:
$ cat t687.cu
#include <thrust/iterator/zip_iterator.h>
#include <thrust/device_vector.h>
#include <thrust/for_each.h>
#include <iostream>
#define DSIZE 10
#define ZIP(X,Y) thrust::make_zip_iterator(thrust::make_tuple(X,Y))
struct incr
template <typename T>
__host__ __device__
void operator()(T d1){
thrust::get<0>(thrust::get<0>(d1))++;
thrust::get<1>(thrust::get<0>(d1))++;
thrust::get<0>(thrust::get<1>(d1))++;
thrust::get<1>(thrust::get<1>(d1))++;
int main(){
thrust::device_vector<int> d1(DSIZE);
thrust::device_vector<int> d2(DSIZE);
thrust::device_vector<int> d3(DSIZE);
thrust::device_vector<int> d4(DSIZE);
std::cout << d1[0] << std::endl;
thrust::for_each(ZIP(ZIP(d1.begin(),d2.begin()), ZIP(d3.begin(),d4.begin())), ZIP(ZIP(d1.end(), d2.end()), ZIP(d3.end(), d4.end())), incr());
$ nvcc -o t687 t687.cu
$ ./t687
0
1
ok, thanks for the reply.
apperently my problem was that i didnt use a template functor but gave the types myself instead. ANd probably i messed up references and copies somewhere around there.
Thanks again, now it works.
best regards
Franz
