Closes #29488.
## Motivation
DeepSeek shipped `DeepSeek-V4-Flash-DSpark` and `…DeepSeek-V4-Pro-DSpark`: the V4 checkpoints with a built-in speculative module ("DSpark") under the `mtp.*` namespace. SGLang already serves DeepSeek-V4 and already has block-draft speculative decoding, but not the DSpark drafter. This PR adds it.
DSpark is a block drafter. Each decode step it proposes a block of `block_size` tokens (default 5) in one draft forward, and the target verifies the whole block in one pass. The drafter is a three-stage MTP stack with a Markov head (refines the block autoregressively) and a confidence head (scores each position). It runs off the target's fused hidden states rather than its own token KV, so there is no separate draft model to download and the extra memory is small. Verification is greedy and lossless: the accepted output is identical to the target's greedy decoding for any block size or confidence threshold.
## Modifications
### Core implementation
- `python/sglang/srt/models/deepseek_v4_dspark.py` (new, 261 lines): the DSpark draft model (three-stage MTP backbone, Markov head, confidence head).
- `python/sglang/srt/speculative/dspark_worker_v2.py` (new, 573 lines): block draft, target verify, longest greedy-matching prefix plus bonus token.
- `python/sglang/srt/speculative/dspark_info.py` (new, 328 lines): `DSparkDraftInputV2` and `DSparkVerifyInput` with filter/merge for batching and the overlap scheduler.
- `python/sglang/srt/models/deepseek_v4.py` (+102): target hidden-state capture seam and the per-layer draft KV materialization (`MQALayer.kv_from_hidden`). Draft and target share the embedding and lm_head; the checkpoint has no draft-private copies.
### Registration and dispatch
- `python/sglang/srt/speculative/spec_info.py` (+37): registers `SpeculativeAlgorithm.DSPARK`, the `is_dspark()` predicate, and the DSpark draft/verify input types.
- `python/sglang/srt/speculative/spec_registry.py` (+3): conformance stub.
- `python/sglang/srt/speculative/spec_utils.py` (+5): skip the hidden-states placeholder indexing for DSpark under the overlap scheduler.
- `python/sglang/srt/arg_groups/speculative_hook.py` (+101): `_handle_dspark` (pins topk and num-steps to 1, defaults the draft path to the target, validates block size and confidence threshold).
- `python/sglang/srt/configs/model_config.py` (+18), `configs/deepseek_v4.py` (+5), `arg_groups/deepseek_v4_hook.py`: draft architecture swap and config wiring.
- `python/sglang/srt/model_executor/model_runner.py` (+42), `model_executor/pool_configurator.py` (+21), `model_executor/runner/{decode,prefill}_cuda_graph_runner.py`, `layers/attention/{deepseek_v4_backend,flashinfer_backend}.py`, `managers/overlap_utils.py`: dispatch sites, draft KV pool sizing, and CUDA graph capture.
- `python/sglang/srt/server_args.py` (+8): the DSpark CLI flags.
### Configuration parameters
- `--speculative-algorithm DSPARK`: enable DSpark. The draft path defaults to the target checkpoint.
- `--speculative-dspark-block-size` (default 5): draft block length; alias of `--speculative-num-draft-tokens` for DSpark.
- `--speculative-dspark-confidence-threshold` (default 0.0, range [0, 1]): truncate the draft block at the first position whose confidence-head probability falls below the threshold; 0 verifies the full block.
- `--speculative-eagle-topk` and `--speculative-num-steps` are pinned to 1.
### Documentation
- `docs/advanced_features/dspark_speculative_decoding.md` (new): user guide (how it works, launch command, request example, parameters, confidence-threshold tuning, accuracy and performance, constraints).
- `docs/advanced_features/speculative_decoding.md`: DSpark added to the quick-guidance list and the method comparison table.
- `docs/advanced_features/server_arguments.md`: DSPARK added to the algorithm options plus the two DSpark flags.
- `docs/index.rst`: the new doc wired into the Advanced Features toctree.
### Tests
- `test/registered/unit/spec/test_dspark.py` (new, 187 lines): predicate truth table, `_handle_dspark` arg handling (block-size alias conflict, bounds, dp-attention and pipeline-parallel rejection, draft-path defaulting), and a `DSparkDraftInputV2` filter/merge regression (the asymmetric merge that previously left a stale-sized array for `filter_batch` to index out of bounds, plus the overlap placeholder fields). Registered on `base-a-test-cpu`.
## Accuracy Tests
Greedy (temperature 0), 200 examples each, `DeepSeek-V4-Flash-DSpark` on 8x B200. Accuracy matches the no-speculation target within run-to-run noise (FP4 MoE is not byte-exact across runs, so greedy accuracy match is the correctness bar):
| Eval | No spec | DSpark |
| GSM8K | 0.985 | 0.990 |
| MMLU | 0.900 | 0.895 |
MMLU no-spec category breakdown: stem 0.952, humanities 0.839, social sciences 0.918, other 0.915.
## Benchmarking and Profiling
### Configuration
- Model: `deepseek-ai/DeepSeek-V4-Flash-DSpark` (284B, FP4 MoE)
- Hardware: 8x B200, tp8 ep8
- MoE backend: `flashinfer_mxfp4` (target and draft)
- Sampling: greedy (temperature 0)
- Acceptance length: mean accepted tokens per target forward, bonus included; no spec equals 1.00
- The no-spec baseline runs at `--mem-fraction-static 0.78 --max-running-requests 16 --cuda-graph-max-bs 16`; without a draft model it does not fit at the DSpark memory settings, which is also why the no-spec sweep stops at concurrency 16. The single-stream and low-concurrency rows are unaffected; treat the concurrency 8 and 16 rows as indicative.
### Commands
Launch (DSpark):
```bash
python3 -m sglang.launch_server \
--model-path deepseek-ai/DeepSeek-V4-Flash-DSpark \
--trust-remote-code --tp 8 --ep-size 8 \
--moe-runner-backend flashinfer_mxfp4 \
--speculative-moe-runner-backend flashinfer_mxfp4 \
--speculative-algorithm DSPARK \
--speculative-eagle-topk 1 --speculative-num-steps 1 \
--mem-fraction-static 0.85 --context-length 4096 \
--cuda-graph-max-bs 32 --max-running-requests 32 \
--disable-overlap-schedule
Launch (no spec baseline): the same command without the `--speculative-*` flags and `--disable-overlap-schedule`, with `--mem-fraction-static 0.78 --max-running-requests 16 --cuda-graph-max-bs 16`.
Accuracy:
```bash
python3 -m sglang.test.run_eval --port 30000 --eval-name gsm8k --num-examples 200
python3 -m sglang.test.run_eval --port 30000 --eval-name mmlu --num-examples 200
Throughput and latency sweep (per concurrency `cc`):
```bash
python3 -m sglang.bench_serving --backend sglang --port 30000 \
--dataset-name random --random-input-len 1024 --random-output-len 1024 \
--random-range-ratio 1.0 --num-prompts $((cc*6)) \
--max-concurrency $cc --request-rate inf
Acceptance length by domain: averaged the per-request `meta_info.spec_accept_length` returned by the server over 40 greedy prompts per dataset.
### Results
Acceptance length by domain (tokens per target forward, bonus included; no spec equals 1.00):
| | GSM8K | MATH500 | HumanEval | MBPP | MT-Bench | Alpaca |
| DSpark | 3.21 | 3.53 | 3.61 | 3.43 | 2.91 | 3.09 |
Per-domain mean: math 3.37, code 3.52, chat 3.00.
Single-stream speedup (same server, with and without DSpark):
| Input / output | No spec (tok/s) | DSpark (tok/s) | Speedup |
| 512 / 256 | 154 | 228 | 1.48x |
| 1024 / 1024 | 164 | 297 | 1.81x |
Throughput and latency across concurrency (random 1024/1024, request-rate inf):
| Concurrency | No spec (tok/s) | DSpark (tok/s) | Speedup | DSpark median TPOT (ms) | DSpark accept len |
| 1 | 164.7 | 297.6 | 1.81x | 2.93 | 3.41 |
| 4 | 585.6 | 607.8 | 1.04x | 4.65 | 3.54 |
| 8 | 608.4 | 735.1 | 1.21x | 6.75 | 3.74 |
| 16 | 601.8 | 788.3 | 1.31x | 5.11 | 4.01 |
| 32 | n/a | 761.3 | n/a | 5.16 | 4.25 |
DSpark gives the largest gain on single-stream and low-to-mid concurrency. As the batch fills and decode becomes compute-bound, the no-spec baseline plateaus around 600 tok/s while DSpark keeps climbing to roughly 790 tok/s at concurrency 16.
<details>
<summary>Raw benchmark output</summary>
Accuracy (`sglang.test.run_eval`, 200 examples, greedy):
GSM8K no-spec : Score: 0.985
GSM8K DSpark : Score: 0.990
MMLU no-spec : Score: 0.900 (stem 0.952, humanities 0.839, social_sciences 0.918, other 0.915)
MMLU DSpark : Score: 0.895
Acceptance length by domain (DSpark, greedy, n=40 per dataset):
gsm8k [math] 3.214
math500 [math] 3.531
humaneval [code] 3.608
mbpp [code] 3.431
mtbench [chat] 2.913
alpaca [chat] 3.094
per-domain: math 3.373 code 3.520 chat 3.004
Throughput sweep (`sglang.bench_serving`, random 1024/1024, request-rate inf):
DSpark c=1 297.6 tok/s median TPOT 2.93 ms accept 3.41
DSpark c=4 607.8 tok/s median TPOT 4.65 ms accept 3.54
DSpark c=8 735.1 tok/s median TPOT 6.75 ms accept 3.74
DSpark c=16 788.3 tok/s median TPOT 5.11 ms accept 4.01
DSpark c=32 761.3 tok/s median TPOT 5.16 ms accept 4.25
no-spec c=1 164.7 tok/s median TPOT 6.00 ms
no-spec c=4 585.6 tok/s median TPOT 6.68 ms
no-spec c=8 608.4 tok/s median TPOT 7.24 ms
no-spec c=16 601.8 tok/s median TPOT 7.26 ms
</details>
## Scope
Greedy (temperature 0) verification. Requests with temperature > 0 are served with greedy verification and log a one-time warning; rejection sampling on the draft distribution (which the Markov-argmax drafter does not expose yet) is a follow-up. The throughput sweep was run with `--disable-overlap-schedule`; the draft-input structures carry the overlap-scheduler fields, and validating overlap-on throughput is a follow-up.
## Checklist
- [x] Format your code according to the [Format code with pre-commit](https://docs.sglang.io/developer_guide/contribution_guide.html#format-code-with-pre-commit).
- [x] Add unit tests according to the [Run and add unit tests](https://docs.sglang.io/developer_guide/contribution_guide.html#run-and-add-unit-tests).
- [x] Update documentation according to [Write documentations](https://docs.sglang.io/developer_guide/contribution_guide.html#write-documentations).
- [x] Provide accuracy and speed benchmark results according to [Test the accuracy](https://docs.sglang.io/developer_guide/contribution_guide.html#test-the-accuracy) and [Benchmark the speed](https://docs.sglang.io/developer_guide/contribution_guide.html#benchmark-the-speed).
- [x] Follow the SGLang code style [guidance](https://docs.sglang.io/developer_guide/contribution_guide.html#code-style-guidance).
### CI States
Latest PR Test (Base): :x: [Run #28309481835](https://github.com/sgl-project/sglang/actions/runs/28309481835)
Latest PR Test (Extra): :x: [Run #28309481732](https://github.com/sgl-project/sglang/actions/runs/28309481732)
