Hi, I have been successfully able to overclock my 2 card, thanks to @generix .
Yesterday I decided to buy another 1. But it does not show up when I do nvidia-smi
Wed Jan 13 22:17:53 2021
| NVIDIA-SMI 455.23.05 Driver Version: 455.23.05 CUDA Version: 11.1 |
| | | MIG M. |
| 0 GeForce RTX 3080 Off | 00000000:0B:00.0 Off | N/A |
| 45% 58C P5 126W / 340W | 199MiB / 10018MiB | 8% Default |
| | | N/A |
| 1 GeForce RTX 3080 Off | 00000000:0C:00.0 Off | N/A |
| 0% 30C P8 1W / 320W | 1MiB / 10018MiB | 0% Default |
| | | N/A |
The NVIDIA card is detected with this command
$ lspci | egrep 'VGA|3D|NVIDIA'
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04)
0b:00.0 VGA compatible controller: NVIDIA Corporation Device 2206 (rev a1)
0b:00.1 Audio device: NVIDIA Corporation Device 1aef (rev a1)
0c:00.0 VGA compatible controller: NVIDIA Corporation Device 2206 (rev a1)
0c:00.1 Audio device: NVIDIA Corporation Device 1aef (rev a1)
0d:00.0 VGA compatible controller: NVIDIA Corporation Device 2206 (rev a1)
0d:00.1 Audio device: NVIDIA Corporation Device 1aef (rev a1)
I found the related article from nvidia forums also from this article but still cannot solve my problem.
$ dmesg |grep NVRM
[ 1.659702] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.23.05 Fri Sep 18 19:37:12 UTC 2020
[ 6.411328] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 6.411350] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 8.424882] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 8.424934] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 23.632110] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 23.632145] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 23.824383] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 23.824408] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 23.850310] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 23.850341] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 23.890079] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 23.890106] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 23.930356] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 23.930383] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 23.970516] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 23.970542] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 24.010572] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 24.010607] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 24.050338] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 24.050362] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 24.090219] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 24.090260] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 24.129891] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
[ 24.129938] NVRM: GPU 0000:0d:00.0: rm_init_adapter failed, device minor number 2
[ 210.285969] NVRM: GPU 0000:0d:00.0: RmInitAdapter failed! (0x30:0x56:825)
All the helps is much appreciated.
Thank you in advanced!
nvidia-bug-report.log.gz (1.6 MB)
