Thank you AastaLLL,
Yes, I addressed it in the post. Unfortunately this is a multi threaded, pre fetch python script so I need to disentangle it. Did it before so shouldn’t be too hard. Also, iirc, in the yolov5_trt they do not count the post processing, which is actually very lengthy.
Is you mobilenet ssd repository still working?
@AastaLLL , I am trying to make the TRT_object_detection work again, but it seems a bit neglected. It is using the flattenconcat library that used to be in the samples but now it can’t load the version that is there. Is there an alternative for it for running the mobilenet models in jp4.6? it was a pretty neat repository.
The GitHub is designed based on the previous environment.
So it is not compatible with the latest JetPack 4.6 software.
If TF 1.15 is used, you can find an example here to convert the model into TensorRT.
If TF 2.x is used, we have an example to demonstrate the EfficientNet conversion as below:
Problem is, everyone shows conversion of classification models… Not object detection. I have tried to convert object detection models before but failed because of the post processing. If you happen to have mobilenet ssd version running in trt, or can point me to how to produce one, I’ll add it to the repository. Efficientdet would also be interesting although I doubt it will be stunningly fast or accurate.
