NIM API KEY
It’s a bit strange, but the NIM API key seems to change every minute today. Shouldn’t the API key for the same NIM under the same a/c be valid for a year (ie, remain the same in a year)?
Can you provide more context? Do you mean to say that you construct a key, and then try and use the key - it quickly stops working?
I was using one of the NIM at build.nvidia.com. The same NIM, when I clicked get an API key, it responded 3 different keys. When I run the app, i can’t connect to the NIM even though I used the API key.
Can you please try regenerating the key and using only the final key generated?
Thanks,
Chris
the same with my case. I have use the Personal API key (never expire key) and follow the documentation on the model
still the response [504] Gateway Timeout
