NVIDIA API KEY runs out fast
Currently my NIM API Key is only working for half a day and then it shows something like “403 Forbidden …” . I then have to generate a new key which also works for only ~half a day.
I am having the same issue. Now even a newly created API key won’t work. I’m getting this error : Error code: 403 - {‘status’: 403, ‘title’: ‘Forbidden’, ‘detail’: ‘Authorization failed’}
We have been having the exact same issue. Any progress for you?
Hi @utveckling I’ve reached out to the team to see if we can get some insights into why this is happening - will get back to you asap! Thanks, Sophie
Awesome, thank you Sophie.
Hi @utveckling are you able to confirm the expiry time you selected when you created the key?
Hi Sophie, we can not see that there is any way of selecting an expiry date? It seems to be set to 1 year automatically. Are we missing something?
@utveckling Can you confirm which model you were using when you see this error? Thanks!
Hi Sophie, it is the Nvidia Llama 3.1 Nemotron 70b instruct. Thank you.
