No audio on Jetson Orin Nano Dev Kit through I2S
I have connected the ICS43434 breakout board to the 40-pin header.
While trying to capture the audio, the I2S2_SCLK is 2.1V 48.8MHz wave.
I am getting the I2S2_FS with a 3.3V square wave with a 12KHz wave.
jetson-nano:~/projects/audio_classification$ amixer -c 1 cset name=‘I2S2 Sample Rate’ 48000
amixer -c 1 cset name=‘I2S2 BCLK Ratio’ 64
amixer -c 1 cset name=‘I2S2 Capture Audio Bit Format’ 2
amixer -c 1 cset name=‘I2S2 Client Bit Format’ 2
amixer -c 1 cset name=‘I2S2 Capture Audio Channels’ 2
amixer -c 1 cset name=‘I2S2 Client Channels’ 2
amixer -c 1 cset name=‘I2S2 codec frame mode’ ‘i2s’
amixer -c 1 cset name=‘I2S2 codec master mode’ ‘cbs-cfs’
amixer -c 1 cset name=‘I2S2 Mux’ ‘ADMAIF1’
amixer -c 1 cset name=‘ADMAIF1 Mux’ ‘I2S2’
amixer -c 1 cset name=‘ADMAIF1 Capture Audio Channels’ 2
amixer -c 1 cset name=‘ADMAIF1 Capture Client Channels’ 2
arecord -D hw:1,0 -f S32_LE -r 48000 -c 2 -d 5 test.wav
sox test.wav -n stat 2>&1 | grep -i “RMS|Maximum”
numid=162,iface=MIXER,name=‘I2S2 Sample Rate’
; type=INTEGER,access=rw------,values=1,min=0,max=192000,step=0
: values=48000
numid=176,iface=MIXER,name=‘I2S2 BCLK Ratio’
; type=INTEGER,access=rw------,values=1,min=0,max=2147483647,step=0
: values=64
numid=164,iface=MIXER,name=‘I2S2 Capture Audio Bit Format’
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 ‘None’
; Item #1 ‘16’
; Item #2 ‘32’
: values=2
numid=165,iface=MIXER,name=‘I2S2 Client Bit Format’
; Item #0 ‘None’
; Item #1 ‘16’
; Item #2 ‘32’
: values=2
numid=167,iface=MIXER,name=‘I2S2 Capture Audio Channels’
; type=INTEGER,access=rw------,values=1,min=0,max=16,step=0
: values=2
numid=168,iface=MIXER,name=‘I2S2 Client Channels’
: values=2
numid=1223,iface=MIXER,name=‘I2S2 codec frame mode’
; type=ENUMERATED,access=rw------,values=1,items=6
; Item #0 ‘None’
; Item #1 ‘i2s’
; Item #2 ‘right-j’
; Item #3 ‘left-j’
; Item #4 ‘dsp-a’
; Item #5 ‘dsp-b’
: values=1
numid=1224,iface=MIXER,name=‘I2S2 codec master mode’
; Item #0 ‘None’
; Item #1 ‘cbm-cfm’
; Item #2 ‘cbs-cfs’
: values=2
numid=1105,iface=MIXER,name=‘I2S2 Mux’
; type=ENUMERATED,access=rw------,values=1,items=81
; Item #0 ‘None’
; Item #1 ‘ADMAIF1’
; Item #2 ‘ADMAIF2’
; Item #3 ‘ADMAIF3’
; Item #4 ‘ADMAIF4’
; Item #5 ‘ADMAIF5’
; Item #6 ‘ADMAIF6’
; Item #7 ‘ADMAIF7’
; Item #8 ‘ADMAIF8’
; Item #9 ‘ADMAIF9’
; Item #10 ‘ADMAIF10’
; Item #11 ‘ADMAIF11’
; Item #12 ‘ADMAIF12’
; Item #13 ‘ADMAIF13’
; Item #14 ‘ADMAIF14’
; Item #15 ‘ADMAIF15’
; Item #16 ‘ADMAIF16’
; Item #17 ‘I2S1’
; Item #18 ‘I2S2’
; Item #19 ‘I2S3’
; Item #20 ‘I2S4’
; Item #21 ‘I2S5’
; Item #22 ‘I2S6’
; Item #23 ‘SFC1’
; Item #24 ‘SFC2’
; Item #25 ‘SFC3’
; Item #26 ‘SFC4’
; Item #27 ‘MIXER1 TX1’
; Item #28 ‘MIXER1 TX2’
; Item #29 ‘MIXER1 TX3’
; Item #30 ‘MIXER1 TX4’
; Item #31 ‘MIXER1 TX5’
; Item #32 ‘AMX1’
; Item #33 ‘AMX2’
; Item #34 ‘AMX3’
; Item #35 ‘AMX4’
; Item #36 ‘ARAD1’
; Item #37 ‘AFC1’
; Item #38 ‘AFC2’
; Item #39 ‘AFC3’
; Item #40 ‘AFC4’
; Item #41 ‘AFC5’
; Item #42 ‘AFC6’
; Item #43 ‘OPE1’
; Item #44 ‘SPKPROT1’
; Item #45 ‘MVC1’
; Item #46 ‘MVC2’
; Item #47 ‘IQC1-1’
; Item #48 ‘IQC1-2’
; Item #49 ‘IQC2-1’
; Item #50 ‘IQC2-2’
; Item #51 ‘DMIC1’
; Item #52 ‘DMIC2’
; Item #53 ‘DMIC3’
; Item #54 ‘DMIC4’
; Item #55 ‘ADX1 TX1’
; Item #56 ‘ADX1 TX2’
; Item #57 ‘ADX1 TX3’
; Item #58 ‘ADX1 TX4’
; Item #59 ‘ADX2 TX1’
; Item #60 ‘ADX2 TX2’
; Item #61 ‘ADX2 TX3’
; Item #62 ‘ADX2 TX4’
; Item #63 ‘ADX3 TX1’
; Item #64 ‘ADX3 TX2’
; Item #65 ‘ADX3 TX3’
; Item #66 ‘ADX3 TX4’
; Item #67 ‘ADX4 TX1’
; Item #68 ‘ADX4 TX2’
; Item #69 ‘ADX4 TX3’
; Item #70 ‘ADX4 TX4’
; Item #71 ‘ADMAIF17’
; Item #72 ‘ADMAIF18’
; Item #73 ‘ADMAIF19’
; Item #74 ‘ADMAIF20’
; Item #75 ‘ASRC1 TX1’
; Item #76 ‘ASRC1 TX2’
; Item #77 ‘ASRC1 TX3’
; Item #78 ‘ASRC1 TX4’
; Item #79 ‘ASRC1 TX5’
; Item #80 ‘ASRC1 TX6’
: values=1
numid=1094,iface=MIXER,name=‘ADMAIF1 Mux’
; Item #0 ‘None’
; Item #1 ‘ADMAIF1’
; Item #2 ‘ADMAIF2’
; Item #3 ‘ADMAIF3’
; Item #4 ‘ADMAIF4’
; Item #5 ‘ADMAIF5’
; Item #6 ‘ADMAIF6’
; Item #7 ‘ADMAIF7’
; Item #8 ‘ADMAIF8’
; Item #9 ‘ADMAIF9’
; Item #17 ‘I2S1’
; Item #18 ‘I2S2’
; Item #19 ‘I2S3’
; Item #20 ‘I2S4’
; Item #21 ‘I2S5’
; Item #22 ‘I2S6’
; Item #23 ‘SFC1’
; Item #24 ‘SFC2’
; Item #25 ‘SFC3’
; Item #26 ‘SFC4’
; Item #32 ‘AMX1’
; Item #33 ‘AMX2’
; Item #34 ‘AMX3’
; Item #35 ‘AMX4’
; Item #36 ‘ARAD1’
; Item #37 ‘AFC1’
; Item #38 ‘AFC2’
; Item #39 ‘AFC3’
; Item #40 ‘AFC4’
; Item #41 ‘AFC5’
; Item #42 ‘AFC6’
; Item #43 ‘OPE1’
; Item #45 ‘MVC1’
; Item #46 ‘MVC2’
; Item #47 ‘IQC1-1’
; Item #48 ‘IQC1-2’
; Item #49 ‘IQC2-1’
; Item #50 ‘IQC2-2’
; Item #51 ‘DMIC1’
; Item #52 ‘DMIC2’
; Item #53 ‘DMIC3’
; Item #54 ‘DMIC4’
: values=18
numid=2,iface=MIXER,name=‘ADMAIF1 Capture Audio Channels’
: values=2
numid=4,iface=MIXER,name=‘ADMAIF1 Capture Client Channels’
: values=2
Recording WAVE ‘test.wav’ : Signed 32 bit Little Endian, Rate 48000 Hz, Stereo
Maximum amplitude: 1.000000
RMS amplitude: 0.537631
Maximum delta: 1.384766
RMS delta: 0.760327
The sound file ‘test.wav’ is just noise only.
What may be the reason?
Why this config done, usually this is not required unless codec needs bclk ratio multiplier. you can try with setting 0 for this control.
As you are trying 48KHz, 32bits, 2ch, the SCLK should be 3.072MHz and Fs should be 48KHz
Actually, only these controls are enough, the configuration would be taken from the audio format.
