I am attempting to get the Auvida B101 (a breakout for the Toshiba TC358743 HDMI to CSI converter) working with the Jetson Nano devkit. Using the forums I have managed to piece together a driver that can be registered as a v4l2 device (/dev/video0) and responds to various v4l2 commands but unfortunately I cannot capture any data from it.
The code I used to piece this driver together came from this TC358840 R32.2 driver and the TC358743 code for an old kernel version here.
I have uploaded my driver code and device tree are here. I was sensing some problems around tc358743_enum_frame_size so I’ve made some hacky changes there that might be worth reviewing by somebody that knows what they’re doing!
I am very new to this so I’m likely making some silly mistakes and I’m also not sure of all the tools available to help me debug things. Any help would be much appreciated and I’ll be sure to share the code once it’s working so others can benefit!
dmesg output
Probing
[ 93.532440] tc358743: loading out-of-tree module taints kernel.
[ 93.539674] tc358743 0-000f: chip found @0xf (7000c000.i2c)
[ 93.539678] tc358743 0-000f: Device Tree Parameters:
[ 93.539742] tc358743 0-000f: reset_gpio = 148
[ 93.539745] tc358743 0-000f: refclk_hz = 27000000
[ 93.539756] tc358743 endpoint->bus.mipi_csi2.flags 512
[ 93.539758] tc358743 endpoint->bus.mipi_csi2.clock_lane 0
[ 93.539760] tc358743 endpoint->bus.mipi_csi2.num_data_lanes 4
[ 93.539762] tc358743 endpoint->bus.mipi_csi2.data_lanes [1-2-3-4]
[ 93.539764] tc358743 endpoint->nr_of_link_frequencies 1
[ 93.539766] tc358743 state->pdata.pll_prd=4
[ 93.539767] tc358743 state->pdata.pll_fbd=88
[ 93.539771] tc358743 0-000f: Subdev init done
[ 93.539773] tc358743 0-000f: Reading i2c_rd16
[ 93.540046] tegra-i2c 7000c000.i2c: no acknowledge from address 0xf
[ 93.546463] tc358743 0-000f: i2c_rd: #### reading register0x0 from0xf failed
[ 93.553755] tc358743 0-000f: RET -1
[ 93.553757] tc358743 0-000f: Chip ID val: 99
[ 93.553760] tc358743 0-000f: tc358743: ERROR: not a TC358743 on address0xf
[ 93.553852] tc358743 1-000f: chip found @0xf (7000c400.i2c)
[ 93.553855] tc358743 1-000f: Device Tree Parameters:
[ 93.553908] tc358743 1-000f: reset_gpio = 152
[ 93.553920] tc358743 1-000f: refclk_hz = 27000000
[ 93.553929] tc358743 endpoint->bus.mipi_csi2.flags 512
[ 93.553931] tc358743 endpoint->bus.mipi_csi2.clock_lane 0
[ 93.553933] tc358743 endpoint->bus.mipi_csi2.num_data_lanes 2
[ 93.553935] tc358743 endpoint->bus.mipi_csi2.data_lanes [1-2-0-0]
[ 93.553937] tc358743 endpoint->nr_of_link_frequencies 1
[ 93.553938] tc358743 state->pdata.pll_prd=4
[ 93.553940] tc358743 state->pdata.pll_fbd=88
[ 93.553943] tc358743 1-000f: Subdev init done
[ 93.553944] tc358743 1-000f: Reading i2c_rd16
[ 93.554224] tegra-i2c 7000c400.i2c: no acknowledge from address 0xf
[ 93.562259] tc358743 1-000f: i2c_rd: #### reading register0x0 from0xf failed
[ 93.569359] tc358743 1-000f: RET -1
[ 93.569362] tc358743 1-000f: Chip ID val: 99
[ 93.569368] tc358743 1-000f: tc358743: ERROR: not a TC358743 on address0xf
[ 93.569462] tc358743 2-000f: chip found @0xf (7000c500.i2c)
[ 93.569465] tc358743 2-000f: Device Tree Parameters:
[ 93.569504] tc358743 2-000f: reset_gpio = 149
[ 93.569506] tc358743 2-000f: refclk_hz = 27000000
[ 93.569516] tc358743 endpoint->bus.mipi_csi2.flags 512
[ 93.569517] tc358743 endpoint->bus.mipi_csi2.clock_lane 0
[ 93.569519] tc358743 endpoint->bus.mipi_csi2.num_data_lanes 4
[ 93.569521] tc358743 endpoint->bus.mipi_csi2.data_lanes [1-2-3-4]
[ 93.569523] tc358743 endpoint->nr_of_link_frequencies 1
[ 93.569525] tc358743 state->pdata.pll_prd=4
[ 93.569526] tc358743 state->pdata.pll_fbd=88
[ 93.569529] tc358743 2-000f: Subdev init done
[ 93.569531] tc358743 2-000f: Reading i2c_rd16
[ 93.569672] tegra-i2c 7000c500.i2c: no acknowledge from address 0xf
[ 93.576007] tc358743 2-000f: i2c_rd: #### reading register0x0 from0xf failed
[ 93.583089] tc358743 2-000f: RET -1
[ 93.583093] tc358743 2-000f: Chip ID val: 99
[ 93.583096] tc358743 2-000f: tc358743: ERROR: not a TC358743 on address0xf
[ 93.583170] tc358743 6-000f: chip found @0xf (Tegra I2C adapter)
[ 93.583173] tc358743 6-000f: Device Tree Parameters:
[ 93.583204] tc358743 6-000f: reset_gpio = 151
[ 93.583206] tc358743 6-000f: refclk_hz = 27000000
[ 93.583215] tc358743 endpoint->bus.mipi_csi2.flags 512
[ 93.583216] tc358743 endpoint->bus.mipi_csi2.clock_lane 0
[ 93.583218] tc358743 endpoint->bus.mipi_csi2.num_data_lanes 4
[ 93.583220] tc358743 endpoint->bus.mipi_csi2.data_lanes [1-2-3-4]
[ 93.583222] tc358743 endpoint->nr_of_link_frequencies 1
[ 93.583223] tc358743 state->pdata.pll_prd=4
[ 93.583225] tc358743 state->pdata.pll_fbd=88
[ 93.583228] tc358743 6-000f: Subdev init done
[ 93.583229] tc358743 6-000f: Reading i2c_rd16
[ 93.584108] tc358743 6-000f: RET 0
[ 93.584111] tc358743 6-000f: Chip ID val: 0
[ 93.584115] tc358743 6-000f: ctrl handler initied
[ 93.584126] tc358743 6-000f: A bunch of new cutoms done
[ 93.586682] tc358743 6-000f: Controls updated
[ 93.586906] tc358743 6-000f: Work queue created
[ 93.586908] tc358743 6-000f: About to call tegra_media_entity_init
[ 93.586911] tc358743 6-000f: tegra_media_entity_init complete
[ 93.586913] tc358743 6-000f: Set mbus_fmt_code in probe to: 8207
[ 93.586915] tc358743 6-000f: About to register subdev
[ 93.586921] vi 54080000.vi: subdev tc358743 6-000f bound
[ 93.587248] tc358743 6-000f: tc358743_enum_mbus_code()
[ 93.587251] tc358743 6-000f: tc358743_enum_mbus_code()
[ 93.587253] tc358743 6-000f: tc358743_enum_mbus_code()
[ 93.587255] tc358743 6-000f: Error in tc358743_enum_mbus_code
[ 93.593992] tc358743 6-000f: Calling tc358743_get_fmt
[ 93.593996] tc358743 6-000f: Here 6b, colorspace: 1
[ 93.593998] tc358743 6-000f: get fmt complete
[ 93.594000] tc358743 6-000f: format width 0
[ 93.594002] tc358743 6-000f: format height 0
[ 93.594004] tc358743 6-000f: fmt_code: 8207
[ 93.594006] tc358743 6-000f: RGB888 code: 4106
[ 93.594008] tc358743 6-000f: UYVY8 code: 8207
[ 93.594443] tc358743 6-000f: Register subdev: 0
[ 93.594447] tc358743 6-000f: before tc358743_initial_setup
[ 93.594450] tc358743 6-000f: Reading i2c_rd16
[ 93.596473] tc358743 6-000f: RET 0
[ 93.596690] tc358743 6-000f: Reading i2c_rd16
[ 93.597005] tc358743 6-000f: RET 0
[ 93.597427] tc358743 6-000f: Reading i2c_rd16
[ 93.597689] tc358743 6-000f: RET 0
[ 93.604290] tc358743 6-000f: tc358743_set_hdmi_hdcp: disable
[ 93.609076] tc358743 6-000f: Reading i2c_rd16
[ 93.609332] tc358743 6-000f: RET 0
[ 93.611597] tc358743 6-000f: after tc358743_initial_setup
[ 93.611601] tc358743 6-000f: tc358743_set_csi_color_space: YCbCr 422 16-bit
[ 93.612419] tc358743 6-000f: Reading i2c_rd16
[ 93.612672] tc358743 6-000f: RET 0
[ 93.612872] tc358743 6-000f: before tc358743_s_dv_timings
[ 93.612875] tc358743 6-000f: tc358743_s_dv_timings
[ 93.612879] tc358743 6-000f: enable_stream: disable
[ 93.613059] tc358743 6-000f: Reading i2c_rd16
[ 93.613312] tc358743 6-000f: RET 0
[ 93.613517] tc358743 6-000f: 793:enable_stream: end
[ 93.613520] tc358743 6-000f: Reading i2c_rd16
[ 93.613774] tc358743 6-000f: RET 0
[ 93.613777] tc358743 6-000f: Reading i2c_rd16
[ 93.614030] tc358743 6-000f: RET 0
[ 93.614033] tc358743 6-000f: tc358743_set_pll:
[ 93.614036] tc358743 6-000f: tc358743_set_pll: updating PLL clock
[ 93.614038] tc358743 6-000f: Reading i2c_rd16
[ 93.614291] tc358743 6-000f: RET 0
[ 93.614777] tc358743 6-000f: Reading i2c_rd16
[ 93.615125] tc358743 6-000f: RET 0
[ 93.615382] tc358743 6-000f: Reading i2c_rd16
[ 93.615682] tc358743 6-000f: RET 0
[ 93.615889] tc358743 6-000f: Reading i2c_rd16
[ 93.616143] tc358743 6-000f: RET 0
[ 93.616346] tc358743 6-000f: tc358743_set_csi:
[ 93.616348] tc358743 6-000f: Reading i2c_rd16
[ 93.616603] tc358743 6-000f: RET 0
[ 93.621372] tc358743 6-000f: before tc358743_init_interrupts
[ 93.624309] tc358743 6-000f: tc358743_enable_interrupts: cable connected = 1
[ 93.625397] tc358743 6-000f: tc358743 found @0xf (Tegra I2C adapter)
[ 93.625401] tc358743 6-000f: tc358743_s_edid, pad 0, start block 0, blocks 2
[ 93.625404] tc358743 6-000f: tc358743_disable_edid:
[ 93.632799] tc358743 6-000f: Calling tc358743_g_edid
[ 93.639151] tc358743 6-000f: EDID_RAM has 256 byte from: 0x8c00 to 0x8d00
[ 93.639396] tc358743 6-000f: Reading i2c_rd16
[ 93.639665] tc358743 6-000f: RET 0
[ 93.639908] tc358743 6-000f: -----Chip status-----
[ 93.639911] tc358743 6-000f: Reading i2c_rd16
[ 93.640170] tc358743 6-000f: RET 0
[ 93.640173] tc358743 6-000f: Chip ID:0x00
[ 93.640176] tc358743 6-000f: Reading i2c_rd16
[ 93.640444] tc358743 6-000f: RET 0
[ 93.640447] tc358743 6-000f: Chip revision:0x00
[ 93.640452] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[ 93.640455] tc358743 6-000f: Sleep mode: off
[ 93.640458] tc358743 6-000f: Cable detected (+5V power): no
[ 93.640701] tc358743 6-000f: DDC lines enabled: yes
[ 93.640936] tc358743 6-000f: Hotplug enabled: no
[ 93.640938] tc358743 6-000f: Reading i2c_rd16
[ 93.641205] tc358743 6-000f: RET 0
[ 93.641209] tc358743 6-000f: CEC enabled: no
[ 93.641211] tc358743 6-000f: -----Signal status-----
[ 93.641215] tc358743 6-000f: TMDS signal detected: no
[ 93.641217] tc358743 6-000f: Stable sync signal: no
[ 93.641220] tc358743 6-000f: PHY PLL locked: no
[ 93.641223] tc358743 6-000f: PHY DE detected: no
[ 93.641464] tc358743 6-000f: tc358743_get_detected_timings: no valid signal
[ 93.641467] tc358743 6-000f: No video detected
[ 93.641474] tc358743 6-000f: Configured format: 1920x1080p60.0 (2200x1125)
[ 93.641479] tc358743 6-000f: horizontal: fp = 88, +sync = 44, bp = 148
[ 93.641483] tc358743 6-000f: vertical: fp = 4, +sync = 5, bp = 36
[ 93.641487] tc358743 6-000f: pixelclock: 148500000
[ 93.641492] tc358743 6-000f: flags (0x12): CAN_REDUCE_FPS CE_VIDEO
[ 93.641495] tc358743 6-000f: standards (0x3): CEA DMT
[ 93.641498] tc358743 6-000f: -----CSI-TX status-----
[ 93.641501] tc358743 6-000f: Lanes needed: 4
[ 93.641812] tc358743 6-000f: Lanes in use: 4
[ 93.641815] tc358743 6-000f: Reading i2c_rd16
[ 93.642082] tc358743 6-000f: RET 0
[ 93.642086] tc358743 6-000f: Waiting for particular sync signal: no
[ 93.642088] tc358743 6-000f: Reading i2c_rd16
[ 93.642385] tc358743 6-000f: RET 0
[ 93.642388] tc358743 6-000f: Transmit mode: no
[ 93.642390] tc358743 6-000f: Reading i2c_rd16
[ 93.642666] tc358743 6-000f: RET 0
[ 93.642672] tc358743 6-000f: Receive mode: no
[ 93.642675] tc358743 6-000f: Reading i2c_rd16
[ 93.643024] tc358743 6-000f: RET 0
[ 93.643029] tc358743 6-000f: Stopped: no
[ 93.643032] tc358743 6-000f: Color space: YCbCr 422 16-bit
[ 93.643351] tc358743 6-000f: -----DVI-D status-----
[ 93.643355] tc358743 6-000f: HDCP encrypted content: no
[ 93.643359] tc358743 6-000f: Input color space: RGB full range
[ 93.643614] tc358743 6-000f: Probe complete
v4l2-ctl
v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, tc358743 6-000f
Bus info : platform:54080000.vi:1
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (HDMI 1: ok)
DV timings:
Active width: 1920
Active height: 1080
Total width: 2200
Total height: 1125
Frame format: progressive
Polarities: +vsync +hsync
Pixelclock: 148500000 Hz (60.00 frames per second)
Horizontal frontporch: 88
Horizontal sync: 44
Horizontal backporch: 148
Vertical frontporch: 4
Vertical sync: 5
Vertical backporch: 36
Standards: CTA-861, DMT
Flags: framerate can be reduced by 1/1.001, CE-video
DV timings capabilities:
Minimum Width: 1
Maximum Width: 10000
Minimum Height: 1
Maximum Height: 10000
Minimum PClock: 0
Maximum PClock: 165000000
Standards: CTA-861, DMT, CVT, GTF
Capabilities: Progressive, Reduced Blanking, Custom Formats
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'UYVY'
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : SMPTE 170M
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
User Controls
audio_sampling_rate 0x00981980 (int) : min=0 max=768000 step=1 default=0 value=0 flags=read-only
audio_present 0x00981981 (bool) : default=0 value=0 flags=read-only
Camera Controls
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (bool) : default=0 value=0
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=30 flags=read-only
Digital Video Controls
power_present 0x00a00964 (bitmask): max=0x00000001 default=0x00000000 value=0x00000001 flags=read-only
v4l2-ctl --log-status
Status Log:
[ 15.519221] vi 54080000.vi: ================= START STATUS =================
[ 15.519669] tc358743 6-000f: Reading i2c_rd16
[ 15.519988] tc358743 6-000f: RET 0
[ 15.520280] tc358743 6-000f: -----Chip status-----
[ 15.520284] tc358743 6-000f: Reading i2c_rd16
[ 15.520584] tc358743 6-000f: RET 0
[ 15.520590] tc358743 6-000f: Chip ID:0x00
[ 15.520594] tc358743 6-000f: Reading i2c_rd16
[ 15.520904] tc358743 6-000f: RET 0
[ 15.520909] tc358743 6-000f: Chip revision:0x00
[ 15.520914] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[ 15.520919] tc358743 6-000f: Sleep mode: off
[ 15.520923] tc358743 6-000f: Cable detected (+5V power): yes
[ 15.521205] tc358743 6-000f: DDC lines enabled: yes
[ 15.521488] tc358743 6-000f: Hotplug enabled: yes
[ 15.521492] tc358743 6-000f: Reading i2c_rd16
[ 15.521877] tc358743 6-000f: RET 0
[ 15.521886] tc358743 6-000f: CEC enabled: no
[ 15.521893] tc358743 6-000f: -----Signal status-----
[ 15.521900] tc358743 6-000f: TMDS signal detected: yes
[ 15.521908] tc358743 6-000f: Stable sync signal: yes
[ 15.521915] tc358743 6-000f: PHY PLL locked: yes
[ 15.521923] tc358743 6-000f: PHY DE detected: yes
[ 15.526409] tc358743 6-000f: 496:tc358743_get_detected_timings: width 1280 heigh 720 interlaced 0
[ 15.526420] tc358743 6-000f: Detected format: 1280x720p50.0 (1980x750)
[ 15.526427] tc358743 6-000f: horizontal: fp = 0, -sync = 700, bp = 0
[ 15.526432] tc358743 6-000f: vertical: fp = 0, -sync = 30, bp = 0
[ 15.526437] tc358743 6-000f: pixelclock: 74250000
[ 15.526443] tc358743 6-000f: flags (0x0):
[ 15.526448] tc358743 6-000f: standards (0x0):
[ 15.526454] tc358743 6-000f: Configured format: 1920x1080p60.0 (2200x1125)
[ 15.526460] tc358743 6-000f: horizontal: fp = 88, +sync = 44, bp = 148
[ 15.526465] tc358743 6-000f: vertical: fp = 4, +sync = 5, bp = 36
[ 15.526470] tc358743 6-000f: pixelclock: 148500000
[ 15.526476] tc358743 6-000f: flags (0x12): CAN_REDUCE_FPS CE_VIDEO
[ 15.526481] tc358743 6-000f: standards (0x3): CEA DMT
[ 15.526485] tc358743 6-000f: -----CSI-TX status-----
[ 15.526490] tc358743 6-000f: Lanes needed: 4
[ 15.526853] tc358743 6-000f: Lanes in use: 4
[ 15.526858] tc358743 6-000f: Reading i2c_rd16
[ 15.527164] tc358743 6-000f: RET 0
[ 15.527169] tc358743 6-000f: Waiting for particular sync signal: no
[ 15.527173] tc358743 6-000f: Reading i2c_rd16
[ 15.527477] tc358743 6-000f: RET 0
[ 15.527482] tc358743 6-000f: Transmit mode: no
[ 15.527485] tc358743 6-000f: Reading i2c_rd16
[ 15.527790] tc358743 6-000f: RET 0
[ 15.527794] tc358743 6-000f: Receive mode: no
[ 15.527797] tc358743 6-000f: Reading i2c_rd16
[ 15.528100] tc358743 6-000f: RET 0
[ 15.528104] tc358743 6-000f: Stopped: no
[ 15.528108] tc358743 6-000f: Color space: YCbCr 422 16-bit
[ 15.528388] tc358743 6-000f: -----DVI-D status-----
[ 15.528393] tc358743 6-000f: HDCP encrypted content: no
[ 15.528398] tc358743 6-000f: Input color space: RGB full range
[ 15.528678] vi 54080000.vi: ================== END STATUS ==================
I noticed the configured format and deteted format differ but I haven’t been able to find out how to fix it.
yavta
Running
./yavta -f UYVY -s 1280x720 -n 4 --capture=5 -F /dev/video0
yeilds
Device /dev/video0 opened: vi-output, tc358743 6-000f (platform:54080000.vi:1).
Video format set: width: 1920 height: 1080 buffer size: 4147200
Video format: UYVY (59565955) 1920x1080
4 buffers requested.
length: 4147200 offset: 0
Buffer 0 mapped at address 0x7f79cb0000.
length: 4147200 offset: 4149248
Buffer 1 mapped at address 0x7f798bb000.
length: 4147200 offset: 8298496
Buffer 2 mapped at address 0x7f794c6000.
length: 4147200 offset: 12447744
Buffer 3 mapped at address 0x7f790d1000.
Then it hangs doing nothing…
and running
./yavta --enum-formats /dev/video0
yeilds
- Available formats:
Format 0: AR24 (34325241)
Type: Video capture (1)
Name: 32-bit BGRA 8-8-8-8
Format 1: UYVY (59565955)
Frame size: 1280x720 (1/30, 1/60)
Frame size: 1920x1080 (1/30, 1/60)
Format 2: NV16 (3631564e)
Video format: UYVY (59565955) 0x32
gstreamer
gst-launch-1.0 -vvvvv v4l2src ! "video/x-raw, width=1280, height=720, framerate=60/1,format=UYVY" ! nvvidconv ! omxh264enc ! mpegtsmux ! filesink location=test.ts
This creates an empty test.ts file and the following logs:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)60/1, interlace-mode=(string)progressive
Framerate set to : 60 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)60/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
if I set the framerate to 50/1 (like is detected) I get:
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.099286390
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Many thanks in advance for your help!
