TC358743 HDMI-CSI on Nano
I’m trying to push to run HDMI-CSI converter H100F (1080@30fps) using this gist
gist
I compiled Kernel and driver, I see the video device /dev/video0
I have connected the display with settings 1920*1080@30fps
But the video is not streaming. Here is my log, I’m need help, what can I change to push it to work
v4l2-ctl -d /dev/video0 --query-dv-timings
Active width: 1920
Active height: 1080
Total width: 2200
Total height: 1125
Frame format: progressive
Polarities: -vsync -hsync
Pixelclock: 74250000 Hz (30.00 frames per second)
Horizontal frontporch: 0
Horizontal sync: 280
Horizontal backporch: 0
Vertical frontporch: 0
Vertical sync: 45
Vertical backporch: 0
Standards:
Flags:
@Jetson:~$ media-ctl -d /dev/media0   -V ‘“tc358743 6-000f”:0 [fmt:UYVY8_1X16/1920x1080 field:none]’
@Jetson:~$ v4l2-ctl -d /dev/video0   --set-fmt-video=width=1920,height=1080,pixelformat=UYVY   --stream-mmap --stream-count=20 --stream-poll --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height      : 1920/1080
Pixel Format      : ‘UYVY’
Field             : None
Bytes per Line    : 3840
Size Image        : 4147200
Colorspace        : SMPTE 170M
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization      : Default (maps to Limited Range)
Flags             :
New timings found
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
select timeout
arnet@Jetson:~$ sudo dmesg |tail -200
[sudo] password for arnet:
[   97.287149] tc358743 6-000f: Here 6b, colorspace: 1
[   97.287158] tc358743 6-000f: get fmt complete
[   97.287166] tc358743 6-000f: format width 0
[   97.287175] tc358743 6-000f: format height 0
[   97.287183] tc358743 6-000f: fmt_code: 8207
[   97.287191] tc358743 6-000f: RGB888 code: 4106
[   97.287199] tc358743 6-000f: UYVY8 code: 8207
[   97.287644] tc358743 6-000f: Calling tc358743_get_fmt
[   97.287700] tc358743 6-000f: Here 6b, colorspace: 1
[   97.287708] tc358743 6-000f: get fmt complete
[   97.287717] tc358743 6-000f: format width 0
[   97.287725] tc358743 6-000f: format height 0
[   97.287735] tc358743 6-000f: fmt_code: 8207
[   97.287744] tc358743 6-000f: RGB888 code: 4106
[   97.287753] tc358743 6-000f: UYVY8 code: 8207
[   97.287766] tc358743 6-000f: enable_stream: disable
[   97.288915] tc358743 6-000f: 801:enable_stream: end
[   97.289858] tc358743 6-000f: tc358743_set_pll:
[   97.289878] tc358743 6-000f: tc358743_set_csi:
[   97.303163] tc358743 6-000f: tc358743_set_csi_color_space: YCbCr 422 16-bit
[   97.304944] tc358743 6-000f: Called tc358743_set_fmt, completed successfully
[   97.305338] tc358743 6-000f: Calling tc358743_g_input_status
[   97.306559] tc358743 6-000f: tc358743_g_input_status: status =0x0
[   97.306568] tc358743 6-000f: Now getting and setting dv timings
[   97.306577] tc358743 6-000f: Calling tc358743_query_dv_timings
[   97.311238] tc358743 6-000f: 499:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[   97.311250] tc358743 6-000f: tc358743_query_dv_timings: 1920x1080p30.0 (2200x1125)
[   97.311257] tc358743 6-000f: tc358743_s_dv_timings
[   97.311276] tc358743 6-000f: Calling tc358743_query_dv_timings
[   97.315608] tc358743 6-000f: 499:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[   97.315618] tc358743 6-000f: tc358743_query_dv_timings: 1920x1080p30.0 (2200x1125)
[   97.315637] tc358743 6-000f: Calling tc358743_g_dv_timings
[   97.315706] vi 54080000.vi: dma_alloc_coherent of size 0 failed
[  101.541620] tc358743 6-000f: Calling tc358743_get_fmt
[  101.541629] tc358743 6-000f: Here 6b, colorspace: 1
[  101.541633] tc358743 6-000f: get fmt complete
[  101.541638] tc358743 6-000f: format width 1920
[  101.541642] tc358743 6-000f: format height 1080
[  101.541646] tc358743 6-000f: fmt_code: 8207
[  101.541650] tc358743 6-000f: RGB888 code: 4106
[  101.541654] tc358743 6-000f: UYVY8 code: 8207
[  101.542057] tc358743 6-000f: Calling tc358743_get_fmt
[  101.542064] tc358743 6-000f: Here 6b, colorspace: 1
[  101.542068] tc358743 6-000f: get fmt complete
[  101.542072] tc358743 6-000f: format width 1920
[  101.542076] tc358743 6-000f: format height 1080
[  101.542080] tc358743 6-000f: fmt_code: 8207
[  101.542083] tc358743 6-000f: RGB888 code: 4106
[  101.542087] tc358743 6-000f: UYVY8 code: 8207
[  101.542092] tc358743 6-000f: enable_stream: disable
[  101.542920] tc358743 6-000f: 801:enable_stream: end
[  101.543561] tc358743 6-000f: tc358743_set_pll:
[  101.543566] tc358743 6-000f: tc358743_set_csi:
[  101.550981] tc358743 6-000f: tc358743_set_csi_color_space: YCbCr 422 16-bit
[  101.552465] tc358743 6-000f: Called tc358743_set_fmt, completed successfully
[  101.552729] tc358743 6-000f: Calling tc358743_g_input_status
[  101.553624] tc358743 6-000f: tc358743_g_input_status: status =0x0
[  101.553630] tc358743 6-000f: Now getting and setting dv timings
[  101.553637] tc358743 6-000f: Calling tc358743_query_dv_timings
[  101.557554] tc358743 6-000f: 499:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[  101.557563] tc358743 6-000f: tc358743_query_dv_timings: 1920x1080p30.0 (2200x1125)
[  101.557569] tc358743 6-000f: tc358743_s_dv_timings
[  101.557586] tc358743 6-000f: Calling tc358743_query_dv_timings
[  101.562147] tc358743 6-000f: 499:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[  101.562158] tc358743 6-000f: tc358743_query_dv_timings: 1920x1080p30.0 (2200x1125)
[  101.562181] tc358743 6-000f: Calling tc358743_g_dv_timings
[  101.582692] tc358743 6-000f: Calling tc358743_s_stream
[  101.582696] tc358743 6-000f: Calling tc358743_s_stream
[  101.588023] tc358743 6-000f: enable_stream: enable
[  101.589279] tc358743 6-000f: 801:enable_stream: end
[  101.596581] tc358743 6-000f: tc358743_get_edid i2c_rd return 0
[  101.596584] tc358743 6-000f: tc358743_get_edid done
[  101.596586] tc358743 6-000f: -----Chip status-----
[  101.596851] tc358743 6-000f: Chip ID:0x00
[  101.597119] tc358743 6-000f: Chip revision:0x00
[  101.597123] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[  101.597126] tc358743 6-000f: Sleep mode: off
[  101.597129] tc358743 6-000f: Cable detected (+5V power): yes
[  101.597367] tc358743 6-000f: DDC lines enabled: yes
[  101.597664] tc358743 6-000f: Hotplug enabled: yes
[  101.597902] tc358743 6-000f: Hotplug ctl: no
[  101.598157] tc358743 6-000f: CEC enabled: no
[  101.598159] tc358743 6-000f: -----Signal status-----
[  101.598161] tc358743 6-000f: TMDS signal detected: yes
[  101.598163] tc358743 6-000f: Stable sync signal: yes
[  101.598165] tc358743 6-000f: PHY PLL locked: yes
[  101.598167] tc358743 6-000f: PHY DE detected: yes
[  101.601216] tc358743 6-000f: 499:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[  101.601221] tc358743 6-000f: Detected format: 1920x1080p30.0 (2200x1125)
[  101.601225] tc358743 6-000f: horizontal: fp = 0, -sync = 280, bp = 0
[  101.601229] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
[  101.601232] tc358743 6-000f: pixelclock: 74250000
[  101.601236] tc358743 6-000f: flags (0x0):
[  101.601238] tc358743 6-000f: standards (0x0):
[  101.601242] tc358743 6-000f: Configured format: 1920x1080p30.0 (2200x1125)
[  101.601245] tc358743 6-000f: horizontal: fp = 0, -sync = 280, bp = 0
[  101.601247] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
[  101.601249] tc358743 6-000f: pixelclock: 74250000
[  101.601252] tc358743 6-000f: flags (0x0):
[  101.601254] tc358743 6-000f: standards (0x0):
[  101.601256] tc358743 6-000f: -----CSI-TX status-----
[  101.601258] tc358743 6-000f: Lanes needed: 2
[  101.601259] tc358743 6-000f: Lanes in use: 2
[  101.601644] tc358743 6-000f: Waiting for particular sync signal: no
[  101.601905] tc358743 6-000f: Transmit mode: yes
[  101.602162] tc358743 6-000f: Receive mode: no
[  101.602420] tc358743 6-000f: Stopped: no
[  101.602422] tc358743 6-000f: Color space: YCbCr 422 16-bit
[  101.602656] tc358743 6-000f: -----HDMI status-----
[  101.602658] tc358743 6-000f: HDCP encrypted content: no
[  101.602660] tc358743 6-000f: Input color space: RGB limited range
[  101.602893] tc358743 6-000f: AV Mute: off
[  101.603127] tc358743 6-000f: Deep color mode: 8-bits per channel
[  101.604147] tc358743 6-000f: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[  101.604152] tc358743 6-000f:     colorspace: RGB
[  101.604156] tc358743 6-000f:     scan mode: No Data
[  101.604159] tc358743 6-000f:     colorimetry: ITU709
[  101.604162] tc358743 6-000f:     picture aspect: 16:9
[  101.604165] tc358743 6-000f:     active aspect: Same as Picture
[  101.604167] tc358743 6-000f:     itc: IT Content
[  101.604170] tc358743 6-000f:     extended colorimetry: xvYCC 601
[  101.604173] tc358743 6-000f:     quantization range: Limited
[  101.604176] tc358743 6-000f:     nups: Unknown Non-uniform Scaling
[  101.604178] tc358743 6-000f:     video code: 34
[  101.604181] tc358743 6-000f:     ycc quantization range: Limited
[  101.604184] tc358743 6-000f:     hdmi content type: Graphics
[  101.604186] tc358743 6-000f:     pixel repeat: 0
[  101.604189] tc358743 6-000f:     bar top 0, bottom 0, left 0, right 0
[  101.806250] video4linux video0: frame start syncpt timeout!0
[  102.014507] video4linux video0: frame start syncpt timeout!0
[  102.222229] video4linux video0: frame start syncpt timeout!0
[  102.429961] video4linux video0: frame start syncpt timeout!0
[  102.638205] video4linux video0: frame start syncpt timeout!0
[  102.846194] video4linux video0: frame start syncpt timeout!0
[  103.054180] video4linux video0: frame start syncpt timeout!0
[  103.262225] video4linux video0: frame start syncpt timeout!0
[  103.469801] video4linux video0: frame start syncpt timeout!0
[  103.678259] video4linux video0: frame start syncpt timeout!0
[  103.684962] tc358743 6-000f: Calling tc358743_s_stream
[  103.684976] tc358743 6-000f: Calling tc358743_s_stream
[  103.690392] tc358743 6-000f: enable_stream: enable
[  103.693221] tc358743 6-000f: 801:enable_stream: end
[  103.702820] tc358743 6-000f: tc358743_get_edid i2c_rd return 0
[  103.702859] tc358743 6-000f: tc358743_get_edid done
[  103.702890] tc358743 6-000f: -----Chip status-----
[  103.703982] tc358743 6-000f: Chip ID:0x00
[  103.704965] tc358743 6-000f: Chip revision:0x00
[  103.705006] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[  103.705036] tc358743 6-000f: Sleep mode: off
[  103.705066] tc358743 6-000f: Cable detected (+5V power): yes
[  103.707168] tc358743 6-000f: DDC lines enabled: yes
[  103.707751] tc358743 6-000f: Hotplug enabled: yes
[  103.708279] tc358743 6-000f: Hotplug ctl: no
[  103.708813] tc358743 6-000f: CEC enabled: no
[  103.708827] tc358743 6-000f: -----Signal status-----
[  103.708842] tc358743 6-000f: TMDS signal detected: yes
[  103.708856] tc358743 6-000f: Stable sync signal: yes
[  103.708870] tc358743 6-000f: PHY PLL locked: yes
[  103.708883] tc358743 6-000f: PHY DE detected: yes
[  103.715454] tc358743 6-000f: 499:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[  103.715478] tc358743 6-000f: Detected format: 1920x1080p30.0 (2200x1125)
[  103.715493] tc358743 6-000f: horizontal: fp = 0, -sync = 280, bp = 0
[  103.715506] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
[  103.715519] tc358743 6-000f: pixelclock: 74250000
[  103.715532] tc358743 6-000f: flags (0x0):
[  103.715543] tc358743 6-000f: standards (0x0):
[  103.715560] tc358743 6-000f: Configured format: 1920x1080p30.0 (2200x1125)
[  103.715573] tc358743 6-000f: horizontal: fp = 0, -sync = 280, bp = 0
[  103.715586] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
[  103.715597] tc358743 6-000f: pixelclock: 74250000
[  103.715609] tc358743 6-000f: flags (0x0):
[  103.715620] tc358743 6-000f: standards (0x0):
[  103.715630] tc358743 6-000f: -----CSI-TX status-----
[  103.715640] tc358743 6-000f: Lanes needed: 2
[  103.715649] tc358743 6-000f: Lanes in use: 2
[  103.716082] tc358743 6-000f: Waiting for particular sync signal: no
[  103.716508] tc358743 6-000f: Transmit mode: yes
[  103.716931] tc358743 6-000f: Receive mode: no
[  103.717352] tc358743 6-000f: Stopped: no
[  103.717363] tc358743 6-000f: Color space: YCbCr 422 16-bit
[  103.718392] tc358743 6-000f: -----HDMI status-----
[  103.718406] tc358743 6-000f: HDCP encrypted content: no
[  103.718421] tc358743 6-000f: Input color space: RGB limited range
[  103.718899] tc358743 6-000f: AV Mute: off
[  103.719333] tc358743 6-000f: Deep color mode: 8-bits per channel
[  103.720361] tc358743 6-000f: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[  103.720370] tc358743 6-000f:     colorspace: RGB
[  103.720379] tc358743 6-000f:     scan mode: No Data
[  103.720388] tc358743 6-000f:     colorimetry: ITU709
[  103.720396] tc358743 6-000f:     picture aspect: 16:9
[  103.720408] tc358743 6-000f:     active aspect: Same as Picture
[  103.720416] tc358743 6-000f:     itc: IT Content
[  103.720424] tc358743 6-000f:     extended colorimetry: xvYCC 601
[  103.720432] tc358743 6-000f:     quantization range: Limited
[  103.720440] tc358743 6-000f:     nups: Unknown Non-uniform Scaling
[  103.720448] tc358743 6-000f:     video code: 34
[  103.720456] tc358743 6-000f:     ycc quantization range: Limited
[  103.720464] tc358743 6-000f:     hdmi content type: Graphics
[  103.720471] tc358743 6-000f:     pixel repeat: 0
[  103.720481] tc358743 6-000f:     bar top 0, bottom 0, left 0, right 0
Please share which Jetpack version you are using. And please run $ v4l2-ctl --list-formats-ext -d /dev/video0 and share the prints for reference.
Hi, thank you for your reply.
I have
Package: nvidia-jetpack
Version: 4.6.1-b110
ioctl: VIDIOC_ENUM_FMT
Index       : 0
Type        : Video Capture
Pixel Format: ‘AR24’
Name        : 32-bit BGRA 8-8-8-8
Size: Discrete 1920x1080
    Index       : 1
    Pixel Format: 'UYVY'
                    Interval: Discrete 0.033s (30.000 fps)
                    Interval: Discrete 0.020s (50.000 fps)
                    Interval: Discrete 0.017s (60.000 fps)
    Index       : 2
    Pixel Format: 'NV16'
Please try this command and see if it can be successfully run:
$ v4l2-ctl --device /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=UYVY --set-ctrl bypass_mode=0 --stream-mmap --stream-count=200
Unfortunately I got timeout:
New timings found
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Calling tc358743_s_stream
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: enable_stream: enable
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: 798:enable_stream: end
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: tc358743_get_edid i2c_rd return 0
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: tc358743_get_edid done
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: -----Chip status-----
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Chip ID:0x00
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Chip revision:0x00
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Sleep mode: off
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Cable detected (+5V power): yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: DDC lines enabled: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Hotplug enabled: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Hotplug ctl: no
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: CEC enabled: no
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: -----Signal status-----
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: TMDS signal detected: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Stable sync signal: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: PHY PLL locked: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: PHY DE detected: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: 497:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Detected format: 1920x1080p30.0 (2200x1125)
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: horizontal: fp = 0, -sync = 280, bp = 0
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: pixelclock: 74250000
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: flags (0x0):
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: standards (0x0):
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Configured format: 1920x1080p30.0 (2200x1125)
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: -----CSI-TX status-----
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Lanes needed: 1
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Lanes in use: 1
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Waiting for particular sync signal: no
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Transmit mode: yes
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Receive mode: no
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Stopped: no
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Color space: YCbCr 422 16-bit
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: -----HDMI status-----
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: HDCP encrypted content: no
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Input color space: RGB limited range
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: AV Mute: off
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: Deep color mode: 8-bits per channel
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: colorspace: RGB
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: scan mode: No Data
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: colorimetry: ITU709
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: picture aspect: 16:9
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: active aspect: Same as Picture
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: itc: IT Content
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: extended colorimetry: xvYCC 601
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: quantization range: Limited
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: nups: Unknown Non-uniform Scaling
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: video code: 34
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: ycc quantization range: Limited
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: hdmi content type: Graphics
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: pixel repeat: 0
[Wed Oct 29 11:42:00 2025] tc358743 6-000f: bar top 0, bottom 0, left 0, right 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Calling tc358743_get_fmt
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Here 6b, colorspace: 1
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: get fmt complete
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: format width 1920
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: format height 1080
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: fmt_code: 8207
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: RGB888 code: 4106
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: UYVY8 code: 8207
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: enable_stream: disable
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: 798:enable_stream: end
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_set_pll:
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_set_csi:
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_set_csi_color_space: YCbCr 422 16-bit
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Called tc358743_set_fmt, completed successfully
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Calling tc358743_g_input_status
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_g_input_status: status =0x0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Now getting and setting dv timings
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Calling tc358743_query_dv_timings
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: 497:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_query_dv_timings: 1920x1080p30.0 (2200x1125)
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_s_dv_timings
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Calling tc358743_g_dv_timings
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Calling tc358743_s_stream
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: enable_stream: enable
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_get_edid i2c_rd return 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: tc358743_get_edid done
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: -----Chip status-----
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Chip ID:0x00
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Chip revision:0x00
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Sleep mode: off
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Cable detected (+5V power): yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: DDC lines enabled: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Hotplug enabled: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Hotplug ctl: no
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: CEC enabled: no
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: -----Signal status-----
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: TMDS signal detected: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Stable sync signal: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: PHY PLL locked: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: PHY DE detected: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Detected format: 1920x1080p30.0 (2200x1125)
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: horizontal: fp = 0, -sync = 280, bp = 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: pixelclock: 74250000
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: flags (0x0):
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: standards (0x0):
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Configured format: 1920x1080p30.0 (2200x1125)
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: -----CSI-TX status-----
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Lanes needed: 1
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Lanes in use: 1
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Waiting for particular sync signal: no
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Transmit mode: yes
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Receive mode: no
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Stopped: no
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Color space: YCbCr 422 16-bit
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: -----HDMI status-----
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: HDCP encrypted content: no
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Input color space: RGB limited range
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: AV Mute: off
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: Deep color mode: 8-bits per channel
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: colorspace: RGB
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: scan mode: No Data
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: colorimetry: ITU709
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: picture aspect: 16:9
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: active aspect: Same as Picture
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: itc: IT Content
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: extended colorimetry: xvYCC 601
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: quantization range: Limited
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: nups: Unknown Non-uniform Scaling
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: video code: 34
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: ycc quantization range: Limited
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: hdmi content type: Graphics
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: pixel repeat: 0
[Wed Oct 29 11:42:07 2025] tc358743 6-000f: bar top 0, bottom 0, left 0, right 0
[Wed Oct 29 11:42:07 2025] video4linux video0: frame start syncpt timeout!0
[Wed Oct 29 11:42:08 2025] video4linux video0: frame start syncpt timeout!0
[Wed Oct 29 11:42:09 2025] video4linux video0: frame start syncpt timeout!0
[Wed Oct 29 11:42:10 2025] video4linux video0: frame start syncpt timeout!0
It looks like driver or device tree is not ready. Would suggest investigate this. You can refer to camera sensor driver programming section in developer guide.
