"No EGL Display" error coming while running deepstream python app inside a docker
• Hardware Platform (Jetson / GPU) Jetson AGX Orin
• DeepStream Version 6.1.1
• JetPack Version (valid for Jetson only) 5.0.2
• TensorRT Version 8.4.1
• Issue Type( questions, new requirements, bugs) Bugs
While running it locally, ‘xhost +’ fixed the issue.
But currently the device is running remotely and I’m accessing it through ssh.
I really don’t want to display the video and I’m using ‘fakesink’.
I’ve tried unsetting the DISPLAY also tried setting it to :0 and :1, nothing works.
You can try to change the python source code like below to use fakesink.
sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
@yuweiw I was already trying with “fakesink” only. Still it is throwing the error.
It’s weird because only render plugin uses display environment. Which demo did you run and how did you change the source code?
Also, please attach the log with GST_DEBUG=3 python3 ......
@yuweiw
spotgenius_deepstream_app     | No EGL Display
spotgenius_deepstream_app     | nvbufsurftransform: Could not get EGL display connection
spotgenius_deepstream_app     | WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
spotgenius_deepstream_app     | Deserialize yoloLayer plugin: yolo
spotgenius_deepstream_app     | 0:00:05.059060193    19     0x11219440 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<spotgenius_primary-inference_> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/workspace/model_b1_gpu0_fp16.engine
spotgenius_deepstream_app     | 0:00:05.207982837    19     0x11219440 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<spotgenius_primary-inference_> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /workspace/model_b1_gpu0_fp16.engine
spotgenius_deepstream_app     | 0:00:05.234778048    19     0x11219440 ERROR       nvinferallocator gstnvinfer_allocator.cpp:102:gst_nvinfer_allocator_alloc: Error: Could not map EglImage from NvBufSurface for nvinfer
spotgenius_deepstream_app     | 0:00:05.234819232    19     0x11219440 WARN              GST_BUFFER gstbuffer.c:951:gst_buffer_new_allocate: failed to allocate 88 bytes
spotgenius_deepstream_app     | 0:00:05.234848384    19     0x11219440 WARN              bufferpool gstbufferpool.c:305:do_alloc_buffer:<bufferpool0> alloc function failed
spotgenius_deepstream_app     | 0:00:05.234853985    19     0x11219440 WARN              bufferpool gstbufferpool.c:338:default_start:<bufferpool0> failed to allocate buffer
spotgenius_deepstream_app     | 0:00:05.234859649    19     0x11219440 ERROR             bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<bufferpool0> start failed
spotgenius_deepstream_app     | 0:00:05.234871489    19     0x11219440 WARN                 nvinfer gstnvinfer.cpp:943:gst_nvinfer_start:<spotgenius_primary-inference_> error: Failed to set buffer pool to active
spotgenius_deepstream_app     | 0:00:05.254981281    19     0x11219440 WARN                GST_PADS gstpad.c:1142:gst_pad_set_active:<spotgenius_primary-inference_:sink> Failed to activate pad
spotgenius_deepstream_app     | INFO:DEEPSTREAM_PIPELINE:End of stream error
spotgenius_deepstream_app     | INFO:DEEPSTREAM_PIPELINE:gst-resource-error-quark: Failed to set buffer pool to active (1),/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(943): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:spotgenius_primary-inference_
@yuweiw This is a custom made code. I’ve tested this code with my local AGX machine and everything is working fine. Currently I’m trying to run it on a remote AGX Orin machine and facing this issue.
@yuweiw Solved the issue. The default value for DISPLAY inside docker is :1. So I think the pipeline is always expecting a display to be there.
I’ve to run unset DISPLAY inside the docker.
unset DISPLAY
