Could not get EGL display connection
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.4
• Issue Type( questions, new requirements, bugs) Could not get EGL display connection
**• How to reproduce the issue ? By running the deepstream app using the sample config.
When i try to run the deepstream-app i get this error :
sudo deepstream-app -c source2_1080p_dec_infer-resnet_demux_int8.txt
** ERROR: <create_multi_source_bin:1424>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:1517>: create_multi_source_bin failed
** ERROR: <create_pipeline:1326>: create_pipeline failed
** ERROR: <main:688>: Failed to create pipeline
Quitting
After clearing the gstreamer cacher :
sudo rm ${HOME}/.cache/gstreamer-1.0/ -rf
nvbuf_utils: Could not get EGL display connection
nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR
nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR
No EGL Display
nvbufsurftransform: Could not get EGL display connection
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:26823): GStreamer-WARNING **: 10:33:42.323: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:26823): GStreamer-WARNING **: 10:33:42.323: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:26837): GStreamer-WARNING **: 10:33:42.831: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
Quitting
App run failed
Any help will be appreciated, i also tried to set the display variable to 0 by running EXPORT $DISPLAY = 0 and i’m still having the same issue.
Could you try to run the export DISPLAY=0 instead of EXPORT $DISPLAY = 0?
This seems to be an issue of legacy Jetpack on the thirdparty Jetson Nano board. Please try the following command line
echo "/usr/lib/aarch64-linux-gnu/tegra-egl" > /etc/ld.so.conf.d/nvidia-tegra-egl.conf && ldconfig
Same error :
No EGL Display
I’ve tried that command, and i’m getting this error,
sudo bash -c 'echo "/usr/lib/aarch64-linux-gnu/tegra-egl" > /etc/ld.so.conf.d/nvidia-tegra-egl.conf'
sudo ldconfig
Quitting
App run failed
cd /opt/nvidia/deepstream/deepstream-6.0
sudo ./install.sh
There is no output when running sudo ./install.sh , and the error persists :
No EGL Display
Could you try the unset DISPLAY command?
Here is my attempt by trying to use unset DISPLAPY
$ unset DISPLAY
$ sudo deepstream-app -c source2_1080p_dec_infer-resnet_demux_int8.txt
Quitting
App run failed
Could you run the command gst-inspect-1.0 nvstreammux?
/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app$ gst-inspect-1.0 nvstreammux
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:1333): GStreamer-WARNING **: 11:29:15.253: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:1333): GStreamer-WARNING **: 11:29:15.254: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:1344): GStreamer-WARNING **: 11:29:16.767: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
No such element or plugin 'nvstreammux'
There may be an exception to the environment of your board. Could you reinstall the Jetpack on your board?
Yes i’ve already tried it using the SDK manager, which version of Jetpack do you suggest ?
You can flash the appropriate version according to Jetson model Platform and OS Compatibility.
