Hi. I am following replicator tutorial to create synthetic fruit datase.
But, After a day, i still cannot create the random synthetic dataset.
I follow two above tutorial videos. Both of these two video do not show fruit or shrubs.
@Robert_Hoang i am just another user passing by - do you see any errors in your console? can you confirm that the asset paths to the USD assets you’ve specified in the script can be found on your localhost?
Hi @Simplychenable Thank for your reply.
I don’t seen any errors on my console, detail log is attached in this comment.
I also check the usd files, All of them are available
logs.txt (11.8 KB)
i see, you did say it was working for you for a day before it stopped working? i see several warnings pertaining to the material on the worker and the outdoor template scene, but nothing regarding meshes like you’ve said.
Sorry for making you misunderstand, I followed the documentation, and used many different ways, from debugging (print) to using difference versions of (omniverse, code, issac sim). But i have never done it successfully
can you confirm whether you tried to “Start” the replicator from the Replicator menu? it should freeze the OV app for a few seconds. i can’t seem to replicate the issue (fruitbox tutorial, specifically) using the python snippet from github. is that where you got the code? because i do see some discrepancies in the code based on your screenshot.
Hi @Simplychenable
I copy the code from nvidia official repo from github
I also try “Start” from Replicator (in toolbar), but nothing happend.
Detail is showed in the attached video (pls ignore the sound)
everything seems correct (the only thing i left as is was the output). now that you have gotten the wooden crate on screen from running the script, try to “Start” from the Replicator menu; that should kick things off (this should freeze the app for a few seconds). that’s really the only step that i see that didn’t take place at the end. or, you can try “Preview” to see a single iteration of randomizations and quickly visualize to ensure everything’s working.
to clarify regarding the output path, here’s what was noted on the doc at the bottom (added below for your convenience).
If you did not modify
output_dir, in linux, the data will be inHOME/_output.
Hi @Simplychenable ,
Finally I did it, it shows me the fruits with random position.
I am checking on other examples.
Thank you so much.
so it’s really just order of operations from the sound of it. the idea is to run the script to define the environment first before starting the replicator; both are needed for it to work.
Yes, you are definitely right,
Without your help, It might take me another day to solve it.
don’t sweat it, i am learning too 🙂 and hopefully learn twice as fast when we put our heads together.
