I’m using an orin NX dev kit and installed JP 5.1.2 with SDK manager. On port CAM0 everything is fine, but with port CAM1 I can not grab images.
The camera is probed and /dev/video0 is created, so the i2c channel seems to work.
I’ve read about the line polarity problem, but as far as I can see this problem seems to be solved in a previous update, and I checked the version:
$ cat /etc/nv_tegra_release
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
As mentioned on port CAM0 everything is fine, same camera and cable on CAM1:
nxo@ubuntu:~$ v4l2-ctl --set-fmt-video width=640,height=480 --stream-mmap
nxo@ubuntu:~$ sudo dmesg -c
[ 131.577393] bwmgr API not supported
[ 152.551840] bwmgr API not supported
[ 155.096489] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 155.109269] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 155.119298] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 155.127026] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[ 155.137752] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 155.145472] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[ 155.156191] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 157.913315] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 157.922487] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 157.932301] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 157.940024] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[ 157.950680] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 157.958398] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[ 157.969136] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 160.730097] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 160.739261] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 160.749294] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 160.757022] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[ 160.767686] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 160.775402] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[ 160.786098] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 163.547012] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 163.556187] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 163.566303] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 163.574027] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[ 163.584685] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 163.592403] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[ 163.603119] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 166.363805] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 166.372969] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 166.383296] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 166.391020] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[ 166.401683] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 166.409402] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[ 166.420114] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 169.180237] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 169.189375] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 169.199330] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 169.207048] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[ 169.217715] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 169.225438] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[ 169.236172] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
maybe this could be interesting:
nxo@ubuntu:~$ sudo media-ctl -p -d /dev/media0
Media controller API version 5.10.120Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.120Device topology
entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
← “imx219 9-0010”:0 [ENABLED]
pad1: Source
→ “vi-output, imx219 9-0010”:0 [ENABLED]entity 4: 13e40000.host1x:nvcsi@15a00000- (2 pads, 0 link)
device node name /dev/v4l-subdev1
pad0: Sink
pad1: Sourceentity 7: imx219 9-0010 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[fmt:SRGGB10_1X10/3280x2464 field:none colorspace:srgb]
→ “13e40000.host1x:nvcsi@15a00000-”:0 [ENABLED]entity 9: vi-output, imx219 9-0010 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “13e40000.host1x:nvcsi@15a00000-”:1 [ENABLED]
Regards
Joscha
