No module named 'tensorflow.contrib'
Have spent a couple days troubleshooting. This is the complete installation guide for a course I am taking
When I try and enter the following in cmd
$python run_webcam.py --camera video.mp4
I get the following error
ModuleNotFoundError: No module named 'tensorflow.contrib'
The offending line is
import tensorflow.contrib.tensorrt as trt
Here are my setup specs
  • Windows 10
    Python 3.6.8
    CUDA 10.0
    cuDNN v 7.6.2
    Tensorflow (gpu) 1.14.0
    GeForce GTX 960M
    Driver version 431.60
    Intel Core i7-6700HQ 2.6 GHz*
Any feedback or troubleshooting steps appreciated!
Is it possible tensorflow is in correctly installed? When I do a $pip list I get
tensorflow 1.14.0
tensorflow-estimator 1.14.0
tensorflow-gpu 2.0.0b1
I get almost identical error if instead of cmd I run using Anaconda prompt with Python 3.7.3 “No module named 'tensorflow.python.compiler.”
Also confirmed that import tensorflow DOES work in a Python shell.
So bottom line is that the tensorRT module is missing. Then how to install? A quick google shows no Windows installer or support? I already tried uninstalling then reinstalling tensorflow and tensorflow-gpu
Finally works but getting 1 frame every 2-4 seconds with canned 1080p video!
here are my specs
hardware + driver
GeForce GTX 960M
Intel Core i7 6700HQ CPU 2.6 GHz
15.87 GB RAM
Software
Windows 10
CUDA 10.0
Python 3.6.8
tensorflow 1.14.0
Questions
  1. I had to comment out the line
import tensorflow.contrib.tensoort as trt
to avoid compile errors.
Could this be causing my performance issues?
  1. I have both tensorflow and tensorflow-gpu installed. How do I know which one I am running?
  2. What other steps should I take to help troubleshoot performance?
Hello batch44
I had same issue and my working environment seems to me same like yours(os, python, package version…etc)
Did you get any answer yet? if you did, let us know, thank you!
Hey I have the same problem I followed this tutorial
how did you solve it?
thanks for the solution… @consistant1y, just remove that line “import tensorflow.contrib.tensoort as trt” from estimator.py file
