You probably need a transistor. See Jetson Nano GPIO - JetsonHacks
i still get a constant (amplified) signal with a transistor, no modulation occuring
Did you set user permissions?
How should I set the user permissions?? If you mean:
sudo groupadd -f -r gpio
sudo usermod -a -G gpio $USER
cp /opt/nvidia/jetson-gpio/etc/99-gpio.rules /etc/udev/rules.d/
udevadm control --reload-rules && sudo udevadm trigger
Then yes, I did
reboot, run simple_pwm.py, then periodically check
$ sudo cat /sys/kernel/debug/pwm
I get a constant output:
ottobot@ottobot-nano:~$ sudo cat /sys/kernel/debug/pwm
platform/70110000.pwm, 1 PWM device
pwm-0 (pwm-regulator ): requested enabled period: 2500 ns duty: 0 ns polarity: normal
platform/7000a000.pwm, 4 PWM devices
pwm-0 ((null) ): period: 0 ns duty: 0 ns polarity: normal
pwm-1 (pwm-regulator ): requested enabled period: 8000 ns duty: 1440 ns polarity: normal
pwm-2 (sysfs ): requested enabled period: 20000000 ns duty: 20000000 ns polarity: normal
pwm-3 (pwm-fan ): requested enabled period: 45334 ns duty: 0 ns polarity: normal
Well, i switched to generating the PWM signals via a PCA9685 using the I2C bus of the Jetson Nano, seems something is off with my board PWM. Either way, thanks a lot!
