Hi everyone,
I am looking for some assistance to install properly and run processes on a GPU. Currently I have a message saying “No running processes found”.
The server is a ubuntu 16.04.6 LTS. I know the server has an Intel Xeon Silver 4110 (nproc=8). I installed Unity on this server. I am new to GPU and ubuntu. Here is the server status:
ls /usr/share/xsessions/
gnome-flashback-compiz.desktop gnome-flashback-metacity.desktop ubuntu.desktop
please note that originally there was no desktop installed, so: ls -l /usr/share/xsessions/
ls: cannot access ‘/usr/share/xsessions/’: No such file or directory
lspci |grep 3D
Displays nothings
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
dpkg --print-architecture
amd64
lspci | egrep -i “vga|display|3d”
00:02.0 VGA compatible controller: Cirrus Logic GD 5446
00:05.0 VGA compatible controller: NVIDIA Corporation GP102 [TITAN Xp] (rev a1)
System tools / preferences / additional drivers:
System tools / administration / Nvidia X server settings
Only shows
-applications profile
-and Nvidia setting configuration (there is nothing configured here)
nvidia-smi
| NVIDIA-SMI 384.130 Driver Version: 384.130 |
| 0 TITAN Xp Off | 00000000:00:05.0 Off | N/A |
| 0% 21C P0 54W / 250W | 0MiB / 12189MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
grep 10de /lib/udev/rules.d/*
/lib/udev/rules.d/71-nvidia.rules:SUBSYSTEM==“pci”, ATTRS{vendor}==“0x10de”, DRIVERS==“nvidia”, TAG+=“seat”, TAG+=“master-of-seat”
lshw -numeric -C display
WARNING: you should run this program as super-user.
*-display:0
description: VGA compatible controller
product: GD 5446 [1013:B8]
vendor: Cirrus Logic [1013]
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: vga_controller rom
configuration: driver=cirrus latency=0
resources: irq:0 memory:f0000000-f1ffffff memory:fe110000-fe110fff memory:fe100000-fe10ffff
*-display:1
product: GP102 [TITAN Xp] [10DE:1B02]
vendor: NVIDIA Corporation [10DE]
physical id: 5
bus info: pci@0000:00:05.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:11 memory:fd000000-fdffffff memory:e0000000-efffffff memory:f2000000-f3ffffff ioport:c000(size=128) memory:fe080000-fe0fffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
All the hardware installed is given by:
inxi -Fxz
System: Kernel: 4.4.0-184-generic x86_64 (64 bit gcc: 5.4.0) Console: tty 8
Distro: Ubuntu 16.04 xenial
Machine: System: OpenStack Foundation product: OpenStack Nova v: 17.0.12
Mobo: N/A model: N/A Bios: Sea v: 1.10.2-1ubuntu1~cloud0 date: 04/01/2014
CPU(s): 8 Single core Intel Xeon Silver 4110s (-SMP-) cache: 32768 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 33575
clock speeds: max: 2098 MHz 1: 2098 MHz 2: 2098 MHz 3: 2098 MHz 4: 2098 MHz
5: 2098 MHz 6: 2098 MHz 7: 2098 MHz 8: 2098 MHz
Graphics: Card-1: Cirrus Logic GD 5446 bus-ID: 00:02.0
Card-2: NVIDIA GP102 [TITAN Xp] bus-ID: 00:05.0
Display Server: N/A drivers: nouveau (unloaded: fbdev,vesa) FAILED: nvidia
tty size: 96x24 Advanced Data: N/A out of X
Network: Card: Red Hat Virtio network device driver: virtio-pci port: c0e0 bus-ID: 00:03.0
IF: ens3 state: up speed: -1 duplex: unknown mac:
Drives: HDD Total Size: 47.2GB (34.2% used)
ID-1: /dev/sda model: QEMU_HARDDISK size: 42.9GB temp: 0C
ID-2: /dev/sdb model: QEMU_HARDDISK size: 4.3GB temp: 0C
Partition: ID-1: / size: 39G used: 12G (30%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sdb
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: None detected - is lm-sensors installed and configured?
Info: Processes: 223 Uptime: 12:55 Memory: 3093.2/7982.6MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0 Client: Shell (bash 4.3.481) inxi: 2.2.35
