Non-aggregated profiling result support
The nvprof is not supported starts from Ampere GPU.
“aggregated-mode=off” used to be supported in nvprof, and I am looking for a nwe profiling tool that shows the non-aggregated result for the L2 cache or Memory metric/event.
For example, the result look like this:
 l2_subp0_write_sector_misses (32 instances)           -           -  [          0          0          0          0          0          0          0          0          0          0          0          0          0          8          0          0          0          4          0          0          0          0          0          0          0          0          0          0          0          0          0          0 ]           -
 l2_subp1_write_sector_misses (32 instances)           -           -  [          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          8          0          0          0          0          0          0          0          0          0          0          0          0          0          0 ]           -
 l2_subp0_read_sector_misses (32 instances)           -           -  [          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          5          0          0          0          0          0          0          0          0          0          0          0          0          0          0 ]           -
 l2_subp1_read_sector_misses (32 instances)           -           -  [          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0 ]           -
Does Nsight Compute has similar functionality?
You’ll find a number of Nsight Compute CLI equivalent metrics listed here.
Thank you, but I know which metric/event I need from the Nsight compute.
I am wondering if I can get the non-aggregated result of these metrics in Nsight Compute.
In the newer architectures supported by Nsight Compute, instance metrics are generally not available.
