Nvprof and Nsight returning different results for L1 and L2 cache hit rates
I am getting different cache stats for L1 and L2 after evaluating the same executable via nvprof and nsight compute.
The machine configurations are:
GPU : P40
CUDA version : 10.1
#include <stdio.h>
#include "cuda_profiler_api.h"
__global__ void initialization(int n, float a, float *x, float *y)
  int i = blockIdx.x * blockDim.x + threadIdx.x;
  if (i<n/2) {
    x[i] = i;
    y[i] = 2*i;
__global__
void saxpy(int n, float a, float *x, float *y)
  int i = blockIdx.x*blockDim.x + threadIdx.x;
  if (i < n) y[i] = a*x[i] + y[i];
  int sum = 0;
  //if (i < n) sum = sum + y[i];
  //if (i == n) printf("%d", sum);
int main(void)
  int N = 1<<20;
  float *x, *y, *d_x, *d_y;
  cudaHostAlloc((void **)&x,  N*sizeof(float), cudaHostAllocMapped );
  cudaHostAlloc((void **)&y,  N*sizeof(float), cudaHostAllocMapped );
  cudaHostGetDevicePointer((void **)&d_x, x, 0);
  cudaHostGetDevicePointer((void **)&d_y, y, 0);
  for (int i = 0; i < N; i++) {
    x[i] = 1.0f;
    y[i] = 2.0f;
  cudaDeviceSynchronize();
  // Perform SAXPY on 1M elements
  //initialization<<<(N+255)/256, 256>>>(N, 2.0f, d_x, d_y);
  cudaProfilerStart();
  saxpy<<<(N+255)/256, 256>>>(N, 2.0f, d_x, d_y);
  cudaProfilerStop();
  float maxError = 0.0f;
    maxError = max(maxError, abs(y[i]-4.0f));
  printf("Max error: %f\n", maxError);
  cudaFree(d_x);
  cudaFree(d_y);
  cudaFreeHost(x);
  cudaFreeHost(y);
cuda compilation : nvcc -Xptxas -O0 -Xptxas -dlcm=cg -Xptxas -dscm=cg -o saxpy_orig_cg_cg saxpy.cu
nvvp results :
Unified cache hit rate : 50%
L2 cache hit rate : 33%
nsight compute results :
Unified cache hit rate : 0.00%
L2 cache hit rate : 42.23&
It would be really great if someone could help me with this.
Thanks in advance.
We are looking into the differences internally and will update here once we have more information.
Thank you.
Hello Felix,
Has there been any updates about this?
Regards,
Shweta
Apologies for not replying earlier. I wasn’t able to confirm any issues with the metric formulae by nvprof or Nsight Compute yes, but I did ask the team again to provide the info. As for the information I did get already:
First of all, nvprof and Nsight Compute differ in terms of cache metrics in that nvprof does not flush any caches when replaying kernels to collect data for multiple metrics. If not all requested metrics can be collected in a single replay pass, the kernel memory is saved and restored and the kernel is executed multiple times with varying metrics for profiling. In nvprof, the caches aren’t actively altered before and in between those passes. In Nsight Compute, all caches are flushed before each profiling pass to guarantee more deterministic results.
In addition, currently released versions of Nsight Compute are impacted by a bug on Linux and Windows TCC rlated to the driver scrubbing memory allocations after free, that can influence L2 metrics. If you could let us know the OS and potentially the driver version you used, we can better determine if this would impact you. In the next release of Nsight Compute, this bug will be fixed.
OS used : Ubuntu 18.04
Nsight version : NsightCompute-2019.3
Driver version : 418.67
Thanks a lot!
