non recursive permute
Hello
I am new here and also in Cuda, so please have patience with me :)
I am trying to adapt a code found in Internet to my needs - thanks to the author of the code for the nice job !
The code listed below is simplified from example above and is working fine
It is storing all permutations in an array and than throw it on the display from host.
Because of memory limits (my GPU has 1G) the code is working for numbers till 11.
The author has a solution (on his webpage the first “PermCuda”) to split the result in portions.
So, the problem what I have is in version “ver2” - printf in device.
I would like to use every permutation immediately after creation with the function “device void see” on line 21 (called in 75)
“ver2” can be to activate just following the comments - make a line as a comment or activate the line deleting the comments “//”.
questions:
  • How to declare “arrSee” ? (lines 64, 75 and the function “device void see” )
    It seems that even the “index” must be modify to “NUMBER_OF_ELEMENTS” from “Factorial(NUMBER_OF_ELEMENTS)”
    I am a bit confused why it is “printf” 32 elements …
  • A useful information to printf in “device void see” is also the index (the position of the permutation from the total number of permutations)
I hope I am clear and simply enough, thank you :)
ps:
I use VS2013, GTX 650 with cc 3.0
*** an update to the code till 20 numbers
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
#define WIN32_LEAN_AND_MEAN
#include <Windows.h>
#pragma comment(lib, "winmm.lib")
#define NUMBER_OF_ELEMENTS 6
#define BLOCK_DIM 1024
__constant__ long long arr[20][20] = {
	{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 2, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 6, 12, 18, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 24, 48, 72, 96, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 120, 240, 360, 480, 600, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 720, 1440, 2160, 2880, 3600, 4320, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 5040, 10080, 15120, 20160, 25200, 30240, 35280, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 40320, 80640, 120960, 161280, 201600, 241920, 282240, 322560, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 362880, 725760, 1088640, 1451520, 1814400, 2177280, 2540160, 2903040, 3265920, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 3628800, 7257600, 10886400, 14515200, 18144000, 21772800, 25401600, 29030400, 32659200, 36288000, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 39916800, 79833600, 119750400, 159667200, 199584000, 239500800, 279417600, 319334400, 359251200, 399168000, 439084800, 0, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 479001600, 958003200, 1437004800, 1916006400, 2395008000, 2874009600, 3353011200, 3832012800, 4311014400, 4790016000, 5269017600, 5748019200, 0, 0, 0, 0, 0, 0, 0 },
	{ 0, 6227020800, 12454041600, 18681062400, 24908083200, 31135104000, 37362124800, 43589145600, 49816166400, 56043187200, 62270208000, 68497228800, 74724249600, 80951270400, 0, 0, 0, 0, 0, 0 },
	{ 0, 87178291200, 174356582400, 261534873600, 348713164800, 435891456000, 523069747200, 610248038400, 697426329600, 784604620800, 871782912000, 958961203200, 1046139494400, 1133317785600, 1220496076800, 0, 0, 0, 0, 0 },
	{ 0, 1307674368000, 2615348736000, 3923023104000, 5230697472000, 6538371840000, 7846046208000, 9153720576000, 10461394944000, 11769069312000, 13076743680000, 14384418048000, 15692092416000, 16999766784000, 18307441152000, 19615115520000, 0, 0, 0, 0 },
	{ 0, 20922789888000, 41845579776000, 62768369664000, 83691159552000, 104613949440000, 125536739328000, 146459529216000, 167382319104000, 188305108992000, 209227898880000, 230150688768000, 251073478656000, 271996268544000, 292919058432000, 313841848320000, 334764638208000, 0, 0, 0 },
	{ 0, 355687428096000, 711374856192000, 1067062284288000, 1422749712384000, 1778437140480000, 2134124568576000, 2489811996672000, 2845499424768000, 3201186852864000, 3556874280960000, 3912561709056000, 4268249137152000, 4623936565248000, 4979623993344000, 5335311421440000, 5690998849536000, 6046686277632000, 0, 0 },
	{ 0, 6402373705728000, 12804747411456000, 19207121117184000, 25609494822912000, 32011868528640000, 38414242234368000, 44816615940096000, 51218989645824000, 57621363351552000, 64023737057280000, 70426110763008000, 76828484468736000, 83230858174464000, 89633231880192000, 96035605585920000, 102437979291648000, 108840352997376000, 115242726703104000, 0 },
	{ 0, 121645100408832000, 243290200817664000, 364935301226496000, 486580401635328000, 608225502044160000, 729870602452992000, 851515702861824000, 973160803270656000, 1094805903679488000, 1216451004088320000, 1338096104497152000, 1459741204905984000, 1581386305314816000, 1703031405723648000, 1824676506132480000, 1946321606541312000, 2067966706950144000, 2189611807358976000, 2311256907767808000 }
__device__ void see(char* arrSee)
	//this function will contain other instructions, now only printf
	for (int i = 0; i < NUMBER_OF_ELEMENTS; ++i)
		printf("%d ", arrSee[i]);
__global__ void Permute(long long* Max) // delete comment for ver2
//__global__ void Permute(char* arrDest, long long* Max) // comment for ver2
	long long index = threadIdx.x + blockIdx.x * blockDim.x;
	if (index >= *Max)
		return;
	long long tmpindex = index;
	index += 0;
	char arrSrc[NUMBER_OF_ELEMENTS];
	char arrTaken[NUMBER_OF_ELEMENTS];
	char arrSee[NUMBER_OF_ELEMENTS]; // delete comment for ver2
#pragma unroll
	for (char i = 0; i<NUMBER_OF_ELEMENTS; ++i)
		arrSrc[i] = i;
		arrTaken[i] = 0;
		arrSee[i] = 0; //  delete comment for ver2
	char size = NUMBER_OF_ELEMENTS;
#pragma unroll
	for (char i = NUMBER_OF_ELEMENTS - 1; i >= 0; --i)
		for (char j = i; j >= 0; --j)
		if (index >= arr[i][j])
			char foundcnt = 0;
			index = index - arr[i][j];
			for (char k = 0; k<NUMBER_OF_ELEMENTS; ++k)
			if (arrTaken[k] == 0) // set not to taken
				if (foundcnt == j)
					arrTaken[k] = 1; // set to taken
					arrSee[(0 * NUMBER_OF_ELEMENTS) + (NUMBER_OF_ELEMENTS - size)] = arrSrc[k]; // delete comment for ver2
					//arrDest[(tmpindex*NUMBER_OF_ELEMENTS) + (NUMBER_OF_ELEMENTS - size)] = arrSrc[k]; // comment for ver2
					break;
				foundcnt++;
			break;
		--size;
	//see(arrSee); //  delete comment for ver2
cudaError_t PermuteWithCuda(long long* Max) // delete comment for ver2
//cudaError_t PermuteWithCuda(char* arrDest, long long* Max) // comment for ver2
	//char* dev_arrDest = 0; // comment for ver2
	long long *dev_Max = 0;
	cudaError_t cudaStatus;
	cudaMalloc((void**)&dev_Max, sizeof(long long));
	//cudaMalloc((void**)&dev_arrDest, (*Max)*NUMBER_OF_ELEMENTS); // comment for ver2
	cudaMemcpy(dev_Max, Max, sizeof(long long), cudaMemcpyHostToDevice);
	int blocks = (*Max) / BLOCK_DIM;
	if ((*Max) % BLOCK_DIM != 0)
		++blocks;
	++blocks;
	Permute << <blocks, BLOCK_DIM >> >(dev_Max); // delete comment for ver2
	//Permute << <blocks, BLOCK_DIM >> >(dev_arrDest, dev_Max);// comment for ver2
	cudaDeviceSynchronize();
	//cudaMemcpy(arrDest, dev_arrDest, (*Max) * NUMBER_OF_ELEMENTS, cudaMemcpyDeviceToHost); // comment in ver2
	//cudaFree(dev_arrDest); // comment for ver2
	cudaFree(dev_Max);
	cudaStatus = cudaSuccess;
	return cudaStatus;
void display(char* arrDest, long long Max)
	for (int i = 0; i<Max; ++i)
		for (int j = 0; j<NUMBER_OF_ELEMENTS; ++j)
			printf("%d", arrDest[i*NUMBER_OF_ELEMENTS + j]);
		printf("\n");
int main()
	long long Max=1;
	for (long long i = 2; i <= NUMBER_OF_ELEMENTS; ++i)
		Max *= i; // factorial(NUMBER_OF_ELEMENTS)
	//char* arrDest = new char[Max*NUMBER_OF_ELEMENTS]; // comment for ver2
	cudaError_t cudaStatus = PermuteWithCuda(&Max); // delete comment for ver2
	//cudaError_t cudaStatus = PermuteWithCuda(arrDest, &Max); // comment for ver2
	//display(arrDest, Max); //  comment for ver2
	printf("\nExecuted program successfully.\n");
	cudaStatus = cudaDeviceReset();
	//delete[] arrDest; // comment for ver2
	return 0;
I wrote a far better version of this which is not limited by the memory of the GPU, and can handle (theoretically) up to 19!(though I have only tested up to 16! which takes about 8 hours). My version does not need to split up launches when you get past 11! and is much faster.
There are two distinct implementations, one which just generates each permutation in local memory, and one which generated each permutation, evaluates (in n steps) each permutation against some global metric, caches the block best answer and the permutation responsible for that answer, scans, reduces and return to host the optimal permutation and the value associated with that permutation.
Take a look at my code, as I think it is easier to follow.
Here is a link to an older version which does both the raw permutation generation or the permutation+evaluation:
https://github.com/OlegKonings/CUDA_permutations_large
One caveat would be that it was written for GPUs of compute capability of 3.5 or higher. It may work on your GPU which is compute 3.0, but you will have to comment out the lines where it gets the device properties.
NOTE: the default implementation in that old code does the permutation+evaluation. If you just want to generate each unique permutation then you need to change these two lines:
//#define TEST_RAW 1
const bool test_raw=false;//for testing of raw version or full version with permutation evaluation,
Yes, I know this implementation, thanks for writing me as a teacher in this subject !
I tried it out yesterday with few elements “#define NUM_ELEMENTS 4”
But it was not working (possible of these “device properties” lines) .
So, I gave up … it seems too easy.
Now I will have a closer look.
It will take … half a day, maybe
That implementation is intended for larger number of elements, as it does not take long for even a CPU to handle permutations less than 7.
For your GPU there would have to be a few adjustments such as adjusting this value:
const int blockSize=26624;
you could try some lower multiples of 2048 like 8192 for that number.
If you have any questions feel free to ask. I do not get much interest in that project, but I have yet to see a faster implementation.
Also, if you have not yet done so, disable the Windows timeout detection or the OS will stop operations if the GPU takes longer than a couple of seconds.
Follow this guide:
http://www.youtube.com/watch?v=8NtHDkUoN98
Hi
I’ve just made it work and it seems to be much faster than the other code !
Your two answers had put me on the right way.
Your first answer from here, it was written also on the website, but a beginner like me, just jumped over.
As a suggestion, write (about two implementations and what to change) directly in the code as an overview - comment on line 1, 2, 3 …
Than everything will be in one piece.
Now, I go forward to use the permutations in a function “device seePerm”
It should be not so difficult but because of short time, I didn’t get all the ideas from your code.
For example in 2 lines (353 and 390) is written as a comment about “permutation in array A”.
And I am not sure if I should call “device seePerm” on both lines.
“device seePerm” can be simple, just “printf A” and the index of the permutation.
So, my questions are:
  • can you write me a function like this ? it was also the question on the other code.
    Even if I didn’t solve it, I’ve made a step forward moving at your faster code :)
  • the second questions is much time consuming, but maybe you can give me a hint.
    My intention is to permute string like “F0000…” or “E1000…” or “D2000…” …
    I would like to eliminate doubles, or similar permutations (to permute “0” with “0” has no sens and is time consuming calling next function “device seePerm” for the same job)
    I’ve done this in recursive Permutation in CPU, but on GPU … I am lost in space.
“F000…” is a split of 15 in small portions
it looks like
15 0x14 times
14 1 0x13 times
13 2 0x13 times
13 1 1 0x12 times
2 1x14 times
1x15 times
cutting doubles for last string I would have only 1 permutation instead of 15! - 2 hours less :)
  • in next step I would like implement it for multi GPU
    I have a GTX 690 waiting in the drawer, but first I must learn basic about Cuda with 650
thank you
ps:
it looks that I am asking you too much.
I’ve just realized that these are my next steps and I wrote them down.
I think I can manage myself if I will read some tutorials :)
