Hello all CUDA experts!
Today my GeForce GTX 295 arrived and we have just started to get to know each other.
I am new in CUDA and have just been running Device Query and simpleStreams and I am a bit cunfused over that my results are much lower than expected when running simpleStreams(red text). What can be wrong and is it fixable? Are both my GPUs working? Any help is appreciated.
These are my outputs:
Device Query:
There is 1 device supporting CUDA
Device 0: “GeForce GTX 2295”
Major revision number: 1
Minor revision number: 3
Total amount of global memory: 939196416 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.24 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default
Test PASSED
Press ENTER to exit…
simpleStreams:
running on: GeForce GTX 295
memcopy: 27.51
kernel: 214.54
non-streamed: 124.47 (242.05 expected)
4 streams: 26.42 (221.42 expected with compute capability 1.1 or later)
Test PASSED
