not a valid identifier
I have a trouble with the environment setup, [url]Installation Guide Linux :: CUDA Toolkit Documentation, which says
[i]In addition, when using the runfile installation method, the LD_LIBRARY_PATH variable needs to contain /usr/local/cuda-9.1/lib64 on a 64-bit system, or /usr/local/cuda-9.1/lib on a 32-bit system
To change the environment variables for 64-bit operating systems:
$ export LD_LIBRARY_PATH=/usr/local/cuda-9.1/lib64
${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
[/i]
I copy and paste it to ~/.bashrc and my bash shell prints following message as starting up,
-bash: export: `:/usr/local/cuda-9.1/lib64’: not a valid identifier
I double-checked that the path exists.
I’m looking forward to your help and advice.
Bit of a late reply - I had a similar problem when I added the path to my environment from the CLI, so I added it manually; on the way, I came across this.
Here’s what you want to add in .bashrc or .bash_profile or .profile:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-9.1/lib64
This will append the new path onto whatever LD library path you already have.
For example, part of my .bash_profile looks like this:
export PATH=/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/opt/local/bin
export PATH=$PATH:/Library/NNM/bin
export PATH=$PATH:/Developer/NVIDIA/CUDA-9.1/bin
If I echo $PATH, it looks like so:
/usr/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/opt/local/bin:/Library/NNM/bin:/Developer/NVIDIA/CUDA-9.1/bin
Hope that helps someone.
