Lost in readmes new linux user lost
I have an installed C870 on Redhat 5.1 x86_64.
The latest Nvidia driver is installed (x86_64-169.09-pkg2.run).
Cuda toolkit 1.1 for RH5 x86_64 is also installed (/usr/local/cuda) as well as cuda sdk for linux (/root/NVIDIA_CUDA_SDK).
I red the release note available with sdk and i tried to specify the path of the cuda binaries the “path environment variable” but i don’t really know where to find that… The same problem happens when i try to specify cuda libraries to “LD_LIBRARY_PATH”.
The release note says that it can be done in .bash_profile via bash by adding :
PATH=$PATH:/usr/local/cuda/bin
LD_LIBRARY_PATH=$LD_LIBRARY_PATH::/usr/local/cuda/lib
export PATH
export LD_LIBRARY_PATH
I created the libcutil.a and libcutilD.a libraries in NIVIA_CUDA_SKD/lib.
I also tried to run one of the existing examples, but i’m not sure how to do that…
What should be done ???
I finaly found what to do with the .bash_profile, it now looks like that :
#.bash_profile
#Get the aliases and functions
if [ -f ~/.bashrc ]; then
. ~/.bashrc
fi
User specific environment and startup programs
export PATH
export USERNAME
I tried to “make” some examples, but it still tells me that command nvcc is not found…
It looks like you’re almost there, you just have to add the directory that contains ‘nvcc’ to your PATH variable:
export PATH=/usr/local/cuda/bin:$PATH
Ok, it now works a bit better ^^
The .bash_file looks like that now :
#.bash_profile
    . ~/.bashrc
fi
export USERNAME
I tried, after reboot, to “make” the project named matrixMul.
The terminal answers (approximately, 'cause my version is not in english) :
/usr/bin/ld: cannot find -lGLU
collect2: ld returned 1 execution state code
make: *** [../../bin/release/matrixMul] Error 1
If you have any idea i’ll be glad to read them…
Thanks ^^
I’m not certain, but I think you need GLU / GLUT. Something installed them for me. A forum search should help.
You need to install mesa-libGLU-devel (or equivalent) which ships with the OS.
Me confused…
I took a look on what’s installed and it appears that some mesa-libGL* are already there…
But, indeed there are no mesa-libGLU-devel installed
I’ll try to find that !
Thanks a lot !
Thanks to netlama, I installed mesa-libGLU-devel, so i obtained libglut.so.3 !
Thanks to kristleifur, i searched a bit to know what to do with that.
I found the answer in this post :
[url=“http://forums.nvidia.com/index.php?showtopic=46575”]http://forums.nvidia.com/index.php?showtopic=46575[/url]
Thanks people !!!
I have another problem…
I used “make”, “make dbg=1”, “make emu=1” and “make emu=1 dbg=1”. Everything worked fine, but when I want to run one of the example located in /root/NVIDIA_CUDA_SDK/bin/linux/release/, terminal answers :
[root@tesla release]# ./matrixMul
./matrixMul: error while loading shared libraries: libcudart.so: cannot open shared object file: no such file or directory
I gave all access permission to cuda and its containt (/usr/local/cuda)
with chmod -R 777 cuda, same thing to sdk (/root/NVIDIA_CUDA_SDK).
I think it might be a path problem, but if it is so, i don’t really know how to correct that…
Any idea ?
Thanks ^^
You probably need to add /usr/local/cuda/lib to you LD_LIBRARY_PATH. For example in bash do:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib
Okay, when i type that just before using one of the examples located in /root/NVIDIA_CUDA_SDK/bin/linux/release/
most of them are working correctly.
But when i restart the computer, i have to type it again…
Is there a way to make that permanent ?
For example by creating a .bash_profile file with the bash command line you gave me ?
I tried to copy this command line in .bash_profile located in my home directory (/root) but it still asks me for this line after reboot…
Thanks already for the tip ^^
Hi !!
In order to understand a bit more about how to program the tesla card, i typed the example from the “NVIDIA CUDA Programming Guide v1.1” located page 69 (6.2 Source Code Listing).
I tried to make it but it answers me : No rule to male target
Then, i tried to compile it with nvcc, it happens that there are errors like “attribute” missing or undefined functions…
Is there more info available about this example ?
