Not sure if it is a gstreamer or USB issue.
In your 4 cams pipeline, you have some wrong ypos parameters set to negative values.
First try your compositor layout and display with videotestsrc:
gst-launch-1.0 -v \
compositor name=comp \
sink_0::xpos=0 sink_0::ypos=0 sink_0::width=400 sink_0::height=250 \
sink_1::xpos=400 sink_1::ypos=0 sink_1::width=400 sink_1::height=250 \
sink_2::xpos=0 sink_2::ypos=250 sink_2::width=400 sink_2::height=250 \
sink_3::xpos=400 sink_3::ypos=250 sink_3::width=400 sink_3::height=250 \
videotestsrc pattern=0 is-live=1 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_0 \
videotestsrc pattern=18 is-live=1 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_1 \
videotestsrc pattern=22 is-live=1 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_2 \
videotestsrc pattern=1 is-live=1 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_3 \
comp. ! videoconvert ! autovideosink
If this gives the expected layout, try replacing sources one by one up to:
gst-launch-1.0 -v \
v4l2src device=/dev/video0 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_0 \
v4l2src device=/dev/video2 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_1 \
v4l2src device=/dev/video4 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_2 \
v4l2src device=/dev/video6 ! video/x-raw, width=320, height=240 ! queue ! comp.sink_3 \
comp. ! videoconvert ! autovideosink sync=false
When you see failure, you may check last kernel error messages with:
sudo dmesg
and check if last lines mention USB issues.
You may also post the output of :
lsusb -tv
Also note that it would be better to specify a framerate and format, especially for v4l2src, check the ones available for 320x240 from your camera with:
v4l2-ctl --device=/dev/video0 --list-formats-ext
If 30 fps is supported, try:
gst-launch-1.0 -v \
v4l2src device=/dev/video0 ! video/x-raw, width=320, height=240, framerate=30/1 ! queue ! comp.sink_0 \
v4l2src device=/dev/video2 ! video/x-raw, width=320, height=240, framerate=30/1 ! queue ! comp.sink_1 \
v4l2src device=/dev/video4 ! video/x-raw, width=320, height=240, framerate=30/1 ! queue ! comp.sink_2 \
v4l2src device=/dev/video6 ! video/x-raw, width=320, height=240, framerate=30/1 ! queue ! comp.sink_3 \
You may also try to specify mmap for v4l2src:
v4l2src device=/dev/video0 io-mode=2 ! ...
Last, your pipeline may be further optimized using Jetson HW rather than CPU. You may try something like:
gst-launch-1.0 -v \
nvcompositor name=comp \
videotestsrc pattern=0 is-live=1 ! video/x-raw, width=320, height=240 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=400,height=250,pixel-aspect-ratio=1/1' ! queue ! comp.sink_0 \
videotestsrc pattern=18 is-live=1 ! video/x-raw, width=320, height=240 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=400,height=250,pixel-aspect-ratio=1/1' ! queue ! comp.sink_1 \
videotestsrc pattern=22 is-live=1 ! video/x-raw, width=320, height=240 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=400,height=250,pixel-aspect-ratio=1/1' ! queue ! comp.sink_2 \
videotestsrc pattern=1 is-live=1 ! video/x-raw, width=320, height=240 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=400,height=250,pixel-aspect-ratio=1/1' ! queue ! comp.sink_3 \
comp. ! nvvidconv ! autovideosink
