Not able to deploy .etlt file in deepstream test app 1
I have configured my config_file.txt according to the specifications given at Integrating TAO Models into DeepStream — TAO Toolkit 3.22.05 documentation .
I am trying to deploy the detect_netv2 model with Resnet 18 that i have trained using the transfer learning toolkit. This is the error log
Now playing: sample_720p.h264
Using winsys: x11
Opening in BLOCKING MODE
Creating LL OSD context new
0:00:02.949047261 25442   0x558b9f1f50 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:03.321378562 25442   0x558b9f1f50 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:log(): UffParser: Could not read buffer.
NvDsInferCudaEngineGetFromTltModel: Failed to parse UFF model
0:00:03.338591708 25442   0x558b9f1f50 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:generateTRTModel(): Failed to create network using custom network creation function
0:00:03.338655511 25442   0x558b9f1f50 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:03.338714887 25442   0x558b9f1f50 WARN                 nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:03.338744627 25442   0x558b9f1f50 WARN                 nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Running...
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
I am running this on the Jetson nano platform.
Duplicated with [url]https://devtalk.nvidia.com/default/topic/1065722/transfer-learning-toolkit/not-able-to-deploy-etlt-file-in-deepstream-test-app-1/[/url]
