I have trained a Model using DetectNet with Resnet 18 using Transfer Learning Toolkit for Intelligent Video Analytics
And did the below steps:
0. [Set up env variables]
- [Prepare dataset and pre-trained model]
1. [Verify downloaded dataset]
1. [Prepare tfrecords from kitti format dataset]
2. [Download pre-trained model] - [Provide training specification]
- [Run TLT training]
- [Evaluate trained models]
- [Prune trained models]
- [Retrain pruned models]
- [Evaluate retrained model]
- [Visualize inferences]
- [Deploy]
1. [Int8 Optimization]
2. [Generate TensorRT engine]
Exported and Model is Saved in Nvidia Jetson Tx2 → Calibration & etlt Model
Already have TensorRT Installed with 5.1.6 in Tx2
After all above steps I’m using tlt-converter in Nvidia Jetson Tx2 to save the engine
But getting the following ERROR:
nvidia@nvidia-desktop:~/Desktop/TLT_Converter$ ./tlt-converter -e resnet18_detector.engine -k MYKEY -c calibration.bin -o output_cov/Sigmoid,output_bbox/BiasAdd -d 3,384,1248 -b 4 -m 64 -t int8 -i nchw resnet18_detector.etlt
[ERROR] UffParser: Could not open /tmp/fileqsrTCW
[ERROR] Failed to parse uff model
[ERROR] Network must have at least one output
[ERROR] Unable to create engine
Also I tried directly using etlt and calibration file directly to Deepstream and below is the Config File but getting ERROR:
[property]
gpu-id=0
preprocessing parameters.
net-scale-factor=0.0039215697906911373
model-color-format=0
model paths.
int8-calib-file=./models/calibration.bin
labelfile-path=./models/labels.txt
tlt-encoded-model=./models/resnet18_detector.etlt
#model-engine-file=./models/resnet18_detector.trt
tlt-model-key=MYKEY
input-dims=3;384;1248;0 # where c = number of channels, h = height of the model input, w = width of model input, 0: implies CHW format.
uff-input-blob-name=input_1
batch-size=4
0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=3
interval=0
gie-unique-id=1
is-classifier=0
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
#enable_dbscan=0
[class-attrs-all]
threshold=0.2
group-threshold=1
Set eps=0.7 and minBoxes for enable-dbscan=1
eps=0.2
#minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
ERROR:
./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
Now playing: …/…/…/…/samples/streams/sample_720p.h264
Using winsys: x11
Opening in BLOCKING MODE
Creating LL OSD context new
0:00:01.306060535 2052 0x5576738520 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.306441113 2052 0x5576738520 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
0:00:01.860334501 2052 0x5576738520 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): UffParser: Could not read buffer.
NvDsInferCudaEngineGetFromTltModel: Failed to parse UFF model
0:00:01.868581228 2052 0x5576738520 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Failed to create network using custom network creation function
0:00:01.868673325 2052 0x5576738520 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:01.868743149 2052 0x5576738520 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:01.868778797 2052 0x5576738520 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start: error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Running…
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Kindly do the needful ASAP.
