How to export model using tlt-converter for Jetson Nano
Hi Guys,
I am training a custom object detection model (resnet10 , detectnet_v2) on my x86 machine. I wish to use the trained models on Jetson Nano. In the sample code, there is an instruction to download tlt-converter for Jetson platform. I downloaded it but the readme is not readbale.
Kindly let me know the instructions to use ‘tlt-converter’ for Jetson Nano.
Hi neophyte1,
For details info of “tlt-converter” tool, please see https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#deepstream_deployment .
Using the tlt-converter
tlt-converter [-h] -k <encryption_key>
              -d <input_dimensions>
              -o <comma separated output nodes>
              [-c <path to calibration cache file>]
              [-e <path to output engine>]
              [-b <calibration batch size>]
              [-m <maximum batch size of the TRT engine>]
              [-t <engine datatype>]
              [-w <maximum workspace size of the TRT Engine>]
              [-i <input dimension ordering>]
              input_file
Required arguments:
 •input_file: Path to the model exported using tlt-export.
•-k: The API key used to configure the ngc cli to download the models.
•-d: Comma-separated list of input dimensions that should match the dimensions used for tlt-export. Unlike tlt-export this cannot be inferred from calibration data.
•-o: Comma-separated list of output blob names that should match the output configuration used for tlt-export. For classification use: predictions/Softmax.  ◦For detection: output_bbox/BiasAdd,output_cov/Sigmoid
◦For FasterRCNN: dense_class/Softmax,dense_regress/BiasAdd, proposal
◦For SSD: NMS
Optional arguments:
 •-e: Path to save the engine to. (default: ./saved.engine)
•-t: Desired engine data type, generates calibration cache if in INT8 mode. The default value is fp32.The options are {fp32, fp16, int8}
•-w: Maximum workspace size for the TensorRT engine. The default value is  1<<30.
•-i: Input dimension ordering, all other tlt command use NCHW. The default value is nchw. The options are {nchw, nhwc, nc}.
INT8 Mode Arguments:
 •-c: Path to calibration cache file, only used in INT8 mode. The default value is ./cal.bin.
•-b: Batch size used during the tlt-export step for INT8 calibration cache generation. (default: 8).
•-m: Maximum batch size of TensorRT engine. The default value is 16.
Use the following command:
./tlt-converter -k $API_KEY -o output_bbox/BiasAdd,output_cov/Sigmoid -d 3,368,640 -e $ENGINE_FILE_PATH $OBTAINED_ETLT_FILE_PATH
You can then directly use the engine file for inference by modifying the config file of deepstream app and replacing the model-engine with the obtained engine file after tlt-converter.
Hi Guys,
I tried following your advice but I get the following error when I try to use the exported model on Jetson Nano.
0:00:01.350167495  8765   0x5595ccdec0 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): The engine plan file is not compatible with this version of TensorRT, expecting library version 5.1.6 got 5.1.5, please rebuild.
Please help me out.
Hi neophyte1,
For the Jetson platform, make sure the tlt-converter is downloaded from the dev zone.https://developer.nvidia.com/tlt-converter
Then copy it into your nano and run tlt-converter tool.
What’s your trt version inside your nano?
$ dpkg -l |grep tensorrt
See https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#deepstream_deployment
for Jetson devices, TensorRT 5.1 should come pre-installed with the JetPack.
Hi Morganh,
I wish to clarify my scenario. I am using nvidia docker image for TLT on x86_64 platform. i am performing training on this machine. After training, I am exporting the trained model and converting it to trt engine format so that it could be used on Jetson Nano.
TensorRT version on Jetson Nano : 5.1.6.1
Deepstream SDK version : 4.0
I dont understand your instruction on downloaded tlt-converter, copying it on nano and running tlt-converter tool. Does it mean the following:
  1. Export etlt model on x86_64 machine
  2. Copy the etlt model on Jetson Nano
  3. Run tlt-converter tool on Jetson Nano to convert etlt model to trt engine.
Please correct me if I am wrong.
Hi Morganh,
I finally got it to work. Thanks for all the help. However, I am unable to control the annotations in the deepstream app in which I am using the engine.
Please let me know in case you have any pointers for it.
Hi neophyte1,
For deployment your TRT engine into DS, please see “Integrating a DetectNet_v2 model” inside tlt doc.
I provide some overall steps here.
  1. select deepstream-test1-app
  2. modify the app’s config file : dstest1_pgie_config.txt
  3. make clean and make
  4. $./deepstream-test1-app
Reference ticket:
  1. https://devtalk.nvidia.com/default/topic/1064422/transfer-learning-toolkit/finding-inaccurate-result-while-testing-model-tlt-trained-model-with-deepstream-/
  2. https://devtalk.nvidia.com/default/topic/1064346/deepstream-sdk/getting-erroneous-detection-with-tlt-trained-model-deployed-while-testing-with-deepstream/
The label file is configed inside dstest1_pgie_config.txt
labelfile-path=/path/ to/ labels.txt
Hi Morganh,
I am getting the following warnings when I use the newly built trt engine. I dont get these messages with earlier engine.
0:00:04.719499726 12295     0x3095eb30 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:checkEngineParams(): Could not find output layer 'conv2d_bbox' in engine
0:00:04.719588737 12295     0x3095eb30 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:checkEngineParams(): Could not find output layer 'conv2d_cov/Sigmoid' in engine
Kindly let me know what could be wrong.
Did you set correct output-blob-names inside dstest1_pgie_config.txt?
For detectnet_v2, it should be
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
See tlt doc https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#exporting_models
All the output blob names are listed as below.
  • For classification use: predictions/Softmax.
  • For detection: output_bbox/BiasAdd,output_cov/Sigmoid
  • For FasterRCNN: dense_class/Softmax,dense_regress/BiasAdd, proposal
  • For SSD: NMS
Reference topic: https://devtalk.nvidia.com/default/topic/1063940/transfer-learning-toolkit/transfert-learning-toolkit-gt-export-model-/
Hello
I’m in a similar position to you,I am training a custom object detection model (resnet18 , ssd) on my x86 machine.In the sample code,I downloaded tlt-convert.I have exported the etlt model on the X86_64 machine and copied it to Jetson TX2 .
Next I want to generate the TensorRT engine through tlt-converter for DeepStream.But I had no way to successfully run tlt-convert
This is an error message:
nvidia@nvidia-desktop:~ tlt-converter /home/nvidia/tlt_converter/tlt-converter: line 4: ’\371\377\227\002\024\363\003\252\240\203\004\221p\371\377\227\240\243\006\221v\371\377\227\340\003\023\2524\372\377\227G\371\377\227\363SA\251\375{@\251\377C#\221\300\003_\326\375{\276\251\375\003\221\240\037\271\241\E\271\240\037@\271\037\004q\301\002T\241\E@\271\340\377\237R?kA\002T\240\260\300\221\345\371\377\227\240\260\002’: command not found
/home/nvidia/tlt_converter/tlt-converter: line 4: @~H~(P~)X~~,h~.p~/x~0�~1�~2�~3�~4�~5�~6�~7�~8�~9�~:�~;�~<�~=�~>�~?�~@BCD E(F0G8H@IHKPLXMNhOpPxS�T�{����:��{���_��{�����F�5� � � � հ��F�"5� ְ��F�B5� ְ��F�b5� ְ��F��5� ְ��F��5� ְ��F��5� ְ��F��5� ְ��F�6� ְ��F�"6� ְ��F�B6� ְ��F�b6� ְ��F��6� ְ��F��6� ְ��F��6� ְ��F��6� ְ��F�7� ְ��F�"7� ְ��F�B7� ְ��F�b7� ְ��F��7� ְ��F��7� ְ��F��7� ְ��F��7� ְ�G�8� ְ�G�"8� ְ�
G�B8� ְ�G�b8� ְ�G��8� ְ�G��8� ְ�G��8� ְ�G��8� ְ�"G�9� ְ�&G�"9� ְ�
G�B9� ְ�.G�b9� ְ�2G��9� ְ�6G��9� ְ�:G��9� ְ�>G��9� ְ�BG�:� ְ�FG�":� ְ�JG�B:� ְ�NG�b:� ְ�RG��:� ְ�VG��:� ְ�ZG��:� ְ�^G��:� ְ�bG�;� ְ�fG�";� ְ�jG�B;� ְ�nG�b;� ְ�rG��;� ְ�vG��;� ְ�zG��;� ְ�~G��;� ְ��G�<� ְ��G�"<� ְ��G�B<� ְ��G�b<� ְ��G��<� ְ��G��<� ְ��G��<� ְ��G��<� ְ��G�=� ְ��G�"=� ְ��G�B=� ְ��G�b=� ְ��G��=� ְ��G��=� ְ��G��=� ְ��G��=� ְ��G�>� ��������@��#������G���c�G�����G�$����������G�@�����_֠Ѐ���!��?��T��!�G�A� ��_� ՠЀ���!��!�!�C�!�A�!�A�����B�G�B�@��_��{�����
����@9@5���G�����@��������� �R�9�
@��{¨�_�����{�����
����������G�@��?����� �Җ����+��@������*)������ 6��+@��R��ԐR$�r�R����@�P����� �ҁ����/��@��ҡ/@����o����3�I����/@��+@������3@������� ��p����7��@���ҡ7@�������� ��h����;��O��@�|������qT�3���R�7@����;@��3@�����@��O@�!|@����;@������@���ҡ7@���������@�c����*�3��*�7@����;@��3@������@��O@�!|@����;@������@�s����3@�y����+@�_����/@�]����7@�[����;@�Y��� ՠ��G��?@�@� ��@T8���� @��{Ȩ�_��{���������@�q�T�@����R?kaT�Р������� ��������G����� ��{¨�_��{�������R �R�����{���_��{������A~�R�@�T����{¨�_����{�����S��/������G�@�����Ҡ��a����c����������������������� 8��c��������L��������������@8����y������C��������������8��c�p������:����R�C��R�G��R�K��O��S���8����@��/@�����W��W@�1��q�8T�W@��q T�q�T�qT�q�T�q�T�qT��q�T�q�T��q T�q�T�q�T�q�T��q@T�qT����G�@������C�����G�@��㑑����㑠������(�������c����������������������G�@��������㑠c���������c���������c������������z���G�@����m����㑠�������������c�������������������h���G�@����[����㑠#����������㑼����9��#�X���q��qT�S�#� 9��#�M���q��q�T �R�S��@9��#�A���q��q�T@�R�S�
9���@���!�R��3�R�R4�R ՠ#�W����q�1TW�����G�@��������㑠c����������c��c������c�E������w������G�@�R����G����G�@��������㑠#����������#����s����#�-������_�������G�@���������㑠#������������R�����9��#�����q��q�T@�R�O�"�:��#�����q��q�T �R�O�� :��#�����q��qT�O�
�@:���@���!�R��3�R�R4�R ՠ#������q�$T������G�@������K����:����G�������@�@�����������;�����������Р;������������@<�������������<�����������Ѐ=������������@>�����������Р>��������������G�����������>����G����������G�����������?����G����������������������G���������������G�������������������� ��������������G���������������G�������� ���������������������������������������������������������{������������u�����������o������� �����i��������G�����k����Rr�� ����G�\��������G�����^�������/���/@�qMT�/���}� ѡ@� �@��@T�/���}� ѡ@� �@�@9�q�T� ����G�;��������G�����=���3�RD�/���}� ѡ@� �@��#��R�����#���������#������������q�T�� ����G���������G��������3�R$�c�����q�T�
����G� ��������G�����
���3�R�������c��c��c�����S@����O@��
��K@����G@��C@���_��R�c�������������c�������������c�������������
��!�G���B�!@�A�?�TD���������8���������2���������,���������&���������"���������������������#��������������������������㑼���
���#��������#�P������c�|������z����c�x������v����c�t������B�����8���K����SC��{B����_��C#��{����S��W��S��O��K��G��C����{����G�@��g����@8���@�5��������k���@�����o��o@�@�@��o@� ?֠s��o@�@� �@��{@��o@�@?֠o@�@��@��ӈ����o@�@?��R�R*��*����*�G@��������������������R���@�!�!@��s���qT�k@�@� �@����������k@�?��������R�R ����
�C@����������
���R����@�!�!@��T���q�T��@�������B�R�����*~@��~ӡC�"h ������@� q�Tq�Tq�T�A��A���������" @� �" A� �" B� �" C� �!@@�@�&�A��A��A���%������" @� �" A� �" B� �" C� �!@@�@��A��A��A��A���A������" @� �" A� �" B� �" C� �!@@�@� Հ��I����w��W@���ҡw@�����w@�@9�ù �R�ǹ��@� q�T�ǀ��w@� �@9�*��@� ���@� �ù��@��ǹ����À�,����{��W@��À����{@������k@�@�@�������" @� �" A� �" B� �" C� �!@@�@������H����{@��k@��?ր����������H�������������������������[������R�Rb��*����*�@������O@�P�������������W@������g���H�q�T�k@�@�@�@��R�s@��@��k@��?�Rq� T�� ���@���!�R��\��H�q�T�k@�@�@�@��R�s@��@��k@��?�RqT�� ���@���!�R���o@�@���@�!�R�o@�@?�<��H�q!T���K@������ ��K������@�������g�������o@�@��@��g@��o@�@?֠o@�@� �@�!�R�o@�@?֠o@�@���@�!�R�o@�@?֠k@�@�@�@��R�s@��@��k@��?�RqT��
���@������@���!�Rl���@�@� �@���@� ?֠���S@��������R�R��������������@�@�@���@� ?�����@�@� �@���@� ?��������������������"����g@��@T�g@���T�g@�@���@��g@� ?� ՠ�������%�����������
�������������������: File name too long
/home/nvidia/tlt_converter/tlt-converter: line 5: syntax error near unexpected token (' /home/nvidia/tlt_converter/tlt-converter: line 5: �C��_��C����@�� �C��_��{���������@�@��@�������@���@��{¨�_��C����
@� �C��_��{�����
����’��@���'@������*������ �� @��{è�_��{�������R�@������@��{¨�_��C��������@�A�R��@��@���@��@�� ��C��_��{�����������@��@��@������@�(��@�(@��@�$� ��{¨�_�������������@�a�R��@��@���@��@���@��@� � �����_��{�������'��#����@��@��#@��'@������@�!�R$��@�,��@�,@��@�(� ��{è�_������������� ��@���R��@��@���@��@���@��@� ��@�� @�� �����_��{�������'��#������@��@��@��#@��'@������@�A�R$��@�!�R(��@�0��@�0@��@�,� ��{è�_��C������(��@�� ��C��_��{�������@������@�x����{¨�_��C���@�R�C��_��{���������'��@���@����� ��{¨�_��{�������@������@�^����{¨�_��C�����'��@�� ��C��_��{�������@������@�L����{¨�_��C������(��@�� ��C��_��{�������@��������'��@�� ��{¨�_��{����� ������/��@��������%��@���@� ��@������@��/@�(��@���\����@������������ @��{Ĩ�_��{���������%��@���@���Q��@� ������@����� ��{¨�_��{�������@������@������{¨�_��C����@�(@��C��_������� ������R����_��C����@���@� 9�@�$9 ��C��_��� ��{���� ��������G�@��7��Ҡ@���-��@� ��c���RW�������c�k����c� �p���q�T�c����&��#������@���/����#����S��@���v����@���@�@���T�@�����u����Ҡc�Z�������!�G��7A�!@�A�?�@�����c�L�����B���U���� @��{@��� ��_������� ��� �����_��{�������'����'@�q�Tq�TqT>q@T
q@T9� 7����G�����@�}��������G��������+�@7����G�q����@�o��������G�����q�����7����G�c����@�a��������G�����c�����7����G�U����@�S��������G�����U��� � ��{è�_��{������u���@��@��q���� ��{¨�_��{������i���@�q�Te������@�@� � ��{¨�_��C����9�@���a�?��T�@��{@�?�mT �R�R�C��_��{�����
��’��#������/����G�@��?��Ҡ����������’@��/@����@�?֠;��7@��@�?�aT�#@�����1���@��q�T�*�;@�����qT �R�RqT�#@�A����;@��g��@��T�7@����@� ����@���g@���������*��!�G��?@�!@�A�?�T�����������t�������� @��{Ȩ�_��{�������@��� ��{¨�_��{�����S����@�@��@�@��@������������@��� ��SA��{è�_��{�������@�@����@��� ��{¨�_��{������� �� @������@���@��� ��{¨�_��{���������G�@����Ҡ���@�Ք�@���!�G��@�!@�A�?�@T;����{è�_��C������@�@��@���@� @9�@� 9�@�$@9�@�$9 ��C��_��{�������������G�@��?��Ҡ㑡@������㑡#������c��@������c������������#��@�����!�G��?@�!@�A�?�@T����{Ȩ�_��C����@�@����@�@� ��C��_��C������@�@��@� ��C��_��{�������@����� ��{¨�_��{�������@��� ��{¨�_��{�������@�@��@@����@�@�@����@����@����� ��{¨�_��C����@��C��_��{�����������@��@��� ��{è�_��{����� ������@�@��@����������@������@��@�� �� @��{è�_��C����@��C��_��{�������@�@���T�@�@��@�!@�!@�!�!@�����qT!�R�R�@�$9�@�$@9q�T�@�@��@� ���������@�@��@�!@�!@�!�!@�������@�$9 ��{¨�_��{�������
@�b����@�� ��{¨�_��{�����
@��{è�_��{�������������G�@��?��Ҡ㑡@�����㑡#���D��c��@�
����c������=��@�G�������#�H���!�G��?@�!@�A�?�@T2����{Ȩ�_��{�������@������@���@���@�� ��{¨�_��{�����������@���T�@��@��@�C� ��{è�_��{�������
@��@�E� ��{¨�_��C����@��C��_��{�����
@��{è�_��C����@��C��_��{�������������G�@��/��ҿ�9�㑡@������#��@������#��㑢@����!�G��/@�!@�A�?�@T�����{ƨ�_��{�����������@��@��@�’� ��{è�_��C����� ��C��_��{�����
��������@��@�&�q�T���:����@�<�����?����%��@�(�����@��
@��{Ĩ�_��{�����������@����� ��{è�_��{�������@�2��{¨�_��{�������
@��@�.�R�{¨�_��C����@��C��_��{�������@������@��{¨�_��C����@��C��_��C����@� ��C��_��{�������
@�#��@��{¨�_��C������C��_��C������@�$@9�@�$@9?k�T�@�$@9Rq�T�@�@��@�@�?�aT �R�R�C��_��{�������
��@�@��@@�?��T�@��@�@��
@����@�.� ��{¨�_��C����@��C��_��{�����������@��������@��@��� ��{è�_��{���������G�@����Ҡ@� �������@���!�G��@�!@�A�?�@T���!�Ҡ@����+��@�ܔ�#����Ñ/��@��+@����3��3@��’��@��3@��/@�4��@����������������’��@�@��Ñ��@��@�������3@��������’��’@���’��Ñ��@��@�@��@��������’@�����㔠’��@�@��@�@��@����������������@��@�@��@@����@�@�@�����~����@��3@���@��’@���3@��+@�!��@�� Հ��G��7@�@� ���T�����’@��!T�@��3@��/@� ��������@��������’@��3@������@��+@��3@�T��������B�����\���o����SA��{Ǩ�_��{�����
��������@�?���@9�@��� ��C����T�*9 �� @��{Ĩ�_��C������@�@��@�� ��C��_��{����� ����������G�@��/��Ҡ@������@�=���aˠ@�?��'�qT�@�H����@�2������@�/����’��Ñ�#�~�@���+��@�&������+@���T�@�k����+@���T�@�e��+@���!�G��/@�!@�A�?�@T���� @��{ƨ�_��{���������G�@����ҡ@���������@���!�G��@�!@�A�?�@T�����{è�_��{����� ������@��@����@��@���
@��{è�_��{�������
@���T�@��
@�>����{¨�_��C����@��C��_��{�����
����������@�6����@�3��@��@�����D��
@��{Ĩ�_��{�������
@��@�F� ��{¨�_��{�������@�D�����{¨�_��C������@�@��@�@�?�bT�@��@��C��_��{�������
��ҡ
@��@�0��{¨�_��{���������G�@����Ҡ���@�6��@���!�G��@�!@�A�?�@T�����{è�_��{�����������
��{è�_��C����� ��C��_��C����@��C��_��{�����������@��������@�����q@T^����@������{è�_��C������@��@�� ��C��_��{���������� �R��9�@��@��@���{Ĩ�_��{�����������@��@��@���{è�_��{�����
@��{Ĩ�_��{�������c����{¨�_��{�����S��������@�����@�����@����������SA��{Ĩ�_��C����@�@��C��_��C����@��C��_��C����@��C��_��{���������� �R��9�@��@��@���{Ĩ�_��{�����������@��@� ˠ��@���T�@����@��@�D����@��@� ��{Ĩ�_��{��������@%��@���@����� ��{¨�_��{�������@������@�����{¨�_��{��������ЕД�$���$�������������C����������
��ңzs������
s�`?֟�!��T�
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �<�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]’
Please help me
Hi 17521754134,
Could you please paste your full log here? Especially the running command.
Please use code block when you paste your log. The code block button looks like "</> ".
nvidia@nvidia-desktop:~$ tlt-converter
/home/nvidia/tlt_converter/tlt-converter: line 4: $'717727[code]nvidia@nvidia-desktop:~$ tlt-converter
/home/nvidia/tlt_converter/tlt-converter: line 4: $'\371\377\227\002\024\363\003\252\240\203\004\221p\371\377\227\240\243\006\221v\371\377\227\340\003\023\2524\372\377\227G\371\377\227\363SA\251\375{@\251\377C#\221\300\003_\326\375{\276\251\375\003\221\240\037\271\241\E\271\240\037@\271\037\004q\301\002T\241\E@\271\340\377\237R?kA\002T\240\260\300\221\345\371\377\227\240\260\002': command not found
/home/nvidia/tlt_converter/tlt-converter: line 4: @~H~(P~)X~*`~,h~.p~/x~0�~1�~2�~3�~4�~5�~6�~7�~8�~9�~:�~;�~&lt;�~=�~&gt;�~?�~@BCD E(F0G8H@IHKPLXM`NhOpPxS�T�{����:��{���_��{�����F�5� � � � հ��F�&quot;5� ְ��F�B5� ְ��F�b5� ְ��F��5� ְ��F��5� ְ��F��5� ְ��F��5� ְ��F�6� ְ��F�&quot;6� ְ��F�B6� ְ��F�b6� ְ��F��6� ְ��F��6� ְ��F��6� ְ��F��6� ְ��F�7� ְ��F�&quot;7� ְ��F�B7� ְ��F�b7� ְ��F��7� ְ��F��7� ְ��F��7� ְ��F��7� ְ�G�8� ְ�G�&quot;8� ְ�
G�B8� ְ�G�b8� ְ�G��8� ְ�G��8� ְ�G��8� ְ�G��8� ְ�&quot;G�9� ְ�&amp;G�&quot;9� ְ�*G�B9� ְ�.G�b9� ְ�2G��9� ְ�6G��9� ְ�:G��9� ְ�&gt;G��9� ְ�BG�:� ְ�FG�&quot;:� ְ�JG�B:� ְ�NG�b:� ְ�RG��:� ְ�VG��:� ְ�ZG��:� ְ�^G��:� ְ�bG�;� ְ�fG�&quot;;� ְ�jG�B;� ְ�nG�b;� ְ�rG��;� ְ�vG��;� ְ�zG��;� ְ�~G��;� ְ��G�&lt;� ְ��G�&quot;&lt;� ְ��G�B&lt;� ְ��G�b&lt;� ְ��G��&lt;� ְ��G��&lt;� ְ��G��&lt;� ְ��G��&lt;� ְ��G�=� ְ��G�&quot;=� ְ��G�B=� ְ��G�b=� ְ��G��=� ְ��G��=� ְ��G��=� ְ��G��=� ְ��G�&gt;� ��������@��#������G���c�G�����G�$����������G�@�����_֠Ѐ���!��?��T��!�G�A� ��_� ՠЀ���!��!�!�C�!�A�!�A�����B�G�B�@��_��{�����
���`�@9@5���G�����@��������� �R`�9�
@��{&uml;�_�����{�����
����������G�@��?����� �Җ����+��@������*)������ 6��+@��R��ԐR$�r�R���*�@�P����� �ҁ����/��@��ҡ/@����o����3�I����/@��+@������3@������� ��p����7��@���ҡ7@�������� ��h����;��O��@�|������q`T�3���R�7@����;@��3@�����@��O@�!|@����;@������@���ҡ7@���������@�c����*�3��*�7@����;@��3@������@��O@�!|@����;@������@�s����3@�y����+@�_����/@�]����7@�[����;@�Y��� ՠ��G��?@�@� ��@T8����
@��{Ȩ�_��{���������@�q�T�@����R?kaT�Р������� ��������G����� ��{&uml;�_��{�������R �R�����{���_��{������A~�R�@�T����{&uml;�_����{�����S��/������G�@�����Ҡ��a����c����������������������� 8��c��������L��������������@8����y������C��������������`8��c�p������:����R�C��R�G��R�K��O��S���8����@��/@�����W��W@�1��q�8T�W@��q`
T�q�T�q`T�q�T�q�T�q`T��q�T�q�T��q T�q�T�q�T�q�T��q@T�qT����G�@������C�����G�@��㑑����㑠������(�������c����������������������G�@��������㑠c���������c���������c������������z���G�@����m����㑠�������������c�������������������h���G�@����[����㑠#����������㑼����9��#�X���q��q`T�S�#� 9��#�M���q��q�T �R�S��@9��#�A���q��q�T@�R�S�
�`9���@���!�R��3�R�R4�R ՠ#�W����q�1TW�����G�@��������㑠c����������c��c������c�E������w������G�@�R����G����G�@��������㑠#����������#����s����#�-������_�������G�@���������㑠#������������R�����9��#�����q��q�T@�R�O�&quot;�:��#�����q��q�T �R�O�� :��#�����q��q`T�O�
�@:���@���!�R��3�R�R4�R ՠ#������q�$T������G�@������K����:����G�������@�@�����������;�����������Р;������������@&lt;�������������&lt;�����������Ѐ=������������@&gt;�����������Р&gt;��������������G�����������&gt;����G����������G�����������?����G����������������������G���������������G��������`������������ ��������������G���������������G�������� ���������������������������������������������������������{������������u�����������o������� �����i��������G�����k����Rr��
����G���������G��������3�R$�c�����q�T�`
��K@����G@��C@���_��R�c�������������c�������������c�������������*��!�G���B�!@�A�?�TD���������8���������2���������,���������&amp;���������&quot;���������������������#��������������������������㑼���
���#��������#�P������c�|������z����c�x������v����c�t������B�����8���K����SC��{B����_��C#��{����S��W��S��O��K��G��C����{����G�@��g����@8���@�5��������k���@�����o��o@�@�@��o@� ?֠s��o@�@� �@��{@��o@�@?֠o@�@�`�@��ӈ����o@�@?��R�R*��*����*�G@��������������������R���@�!`�!@��s���q`T�k@�@� �@����������k@�`?��������R�R ��*��
��*�C@����������
���R����@�!`�!@��T���q�T��@�`������B�R�����*`~@��~ӡC�&quot;h ������@�
q�Tq�Tq�T�A��A���������&quot;
�&quot;
A�
�&quot;
B�
�&quot;
C�
�!@@�@�&amp;�A��A��A���%������&quot;
�&quot;
A�
�&quot;
B�
�&quot;
C�
�!@@�@��A��A��A��A���A������&quot;
�&quot;
A�
�&quot;
B�
�&quot;
C�
�!@@�@� Հ��I����w��W@���ҡw@�����w@�@9�&ugrave; �R�ǹ��@�
�&ugrave;��@��ǹ����&Agrave;�,����{��W@��&Agrave;����{@������k@�@�@�������&quot;
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
���@���!�R���o@�@���@�!�R�o@�@?�&lt;��H�q!T���K@������ ��K������@�������g�������o@�@�`�@��g@��o@�@?֠o@�@� �@�!�R�o@�@?֠o@�@���@�!�R�o@�@?֠k@�@�@�@��R�s@��@��k@��?�RqT��
���@������@���!�Rl���@�@� �@���@� ?֠���S@��������R�R���*���*��������@�@�@���@� ?�����@�@� �@���@� ?��������������������&quot;����g@��@T�g@���T�g@�@���@��g@� ?� ՠ�������%�����������
/home/nvidia/tlt_converter/tlt-converter: line 5: syntax error near unexpected token `('
/home/nvidia/tlt_converter/tlt-converter: line 5: `�C��_��C����@�� *�C��_��{���������@�@��@������*�@���@��{&uml;�_��C����
@� *�C��_��{�����
@��{&egrave;�_��{�������R�@������@��{&uml;�_��C��������@�A�R��@��@���@��@�� ��C��_��{�����������@��@��@������@�(��@�(@��@�$� ��{&uml;�_�������������@�a�R��@��@���@��@���@��@�
� �����_��{�������'��#����@��@��#@��'@������@�!�R$��@�,��@�,@��@�(� ��{&egrave;�_�������������
@�� �����_��{�������'��#������@��@��@��#@��'@������@�A�R$��@�!�R(��@�0��@�0@��@�,� ��{&egrave;�_��C������(��@�� ��C��_��{�������@������@�x����{&uml;�_��C���@�R�C��_��{���������'��@���@����� ��{&uml;�_��{�������@������@�^����{&uml;�_��C�����'��@�� ��C��_��{�������@������@�L����{&uml;�_��C������(��@�� ��C��_��{�������@��������'��@�� ��{&uml;�_��{�����
@��{Ĩ�_��{���������%��@���@���Q��@� ������@����� ��{&uml;�_��{�������@������@������{&uml;�_��C����@�(@��C��_�������
��������G�@��7��Ҡ@���-��@� ��c���RW�������c�k����c� �p���q�T�c����&amp;��#������@���/����#����S��@���v����@���@�@���T�@�����u����Ҡc�Z�������!�G��7A�!@�A�?�@�����c�L�����B���U����
@��{@��� ��_�������
��� �����_��{�������'����'@�q�Tq�Tq`T&gt;q@T
q@T9� 7����G�����@�}��������G��������+�@7����G�q����@�o��������G�����q�����7����G�c����@�a��������G�����c�����7����G�U����@�S��������G�����U��� � ��{&egrave;�_��{������u���@��@��q���� ��{&uml;�_��{������i���@�q�Te������@�@� � ��{&uml;�_��C����9�@���a�?��T�@��{@�?�mT �R�R�C��_��{�����
��'��#������/����G�@��?��Ҡ����������'@��/@����@�`?֠;��7@��@�?�aT�#@�����1���@��q�T�*�;@�����q`T �R�Rq`T�#@�A����;@��g��@��T�7@����@� ����@���g@���������*��!�G��?@�!@�A�?�T�����������t��������
@��{Ȩ�_��{�������@��� ��{&uml;�_��{�����S����@�@��@�@��@������������@��� ��SA��{&egrave;�_��{�������@�@����@��� ��{&uml;�_��{�������
@������@���@��� ��{&uml;�_��{���������G�@����Ҡ���@�Ք�@���!�G��@�!@�A�?�@T;����{&egrave;�_��C������@�@��@���@� @9�@� 9�@�$@9�@�$9 ��C��_��{�������������G�@��?��Ҡ㑡@������㑡#������c��@������c������������#��@�����!�G��?@�!@�A�?�@T����{Ȩ�_��C����@�@����@�@� ��C��_��C������@�@��@� ��C��_��{�������@����� ��{&uml;�_��{�������@��� ��{&uml;�_��{�������@�@��@@����@�@�@����@����@����� ��{&uml;�_��C����@��C��_��{�����������@��@��� ��{&egrave;�_��{�����
@��{&egrave;�_��C����@��C��_��{�������@�@���T�@�@��@�!@�!@�!`�!@�����q`T!�R�R�@�$9�@�$@9q�T�@�@��@� ���������@�@��@�!@�!@�!`�!@�������@�$9 ��{&uml;�_��{�������
@�b����@�� ��{&uml;�_��{�����
@��{&egrave;�_��{�������������G�@��?��Ҡ㑡@�����㑡#���D��c��@�
����c������=��@�G�������#�H���!�G��?@�!@�A�?�@T2����{Ȩ�_��{�������@������@���@���@�� ��{&uml;�_��{�����������@���T�@��@��@�C� ��{&egrave;�_��{�������
@��@�E� ��{&uml;�_��C����@��C��_��{�����
@��{&egrave;�_��C����@��C��_��{�������������G�@��/��ҿ�9�㑡@������#��@������#��㑢@����!�G��/@�!@�A�?�@T�����{ƨ�_��{�����������@��@��@�'� ��{&egrave;�_��C����� ��C��_��{�����
��������@��@�&amp;�q�T���:����@�&lt;�����?����%��@�(�����@��
@��{Ĩ�_��{�����������@����� ��{&egrave;�_��{�������@�2��{&uml;�_��{�������
@��@�.�R�{&uml;�_��C����@��C��_��{�������@������@��{&uml;�_��C����@��C��_��C����@� ��C��_��{�������
@�#��@��{&uml;�_��C������C��_��C������@�$@9�@�$@9?k�T�@�$@9Rq�T�@�@��@�@�?�aT �R�R�C��_��{�������
@����@�.� ��{&uml;�_��C����@��C��_��{�����������@��������@��@��� ��{&egrave;�_��{���������G�@����Ҡ@� �������@���!�G��@�!@�A�?�@T���!�Ҡ@����+��@�ܔ�#����&Ntilde;/��@��+@����3��3@��'��@��3@��/@�4��@����������������'��@�@��&Ntilde;��@��@�������3@��������'��'@���'��&Ntilde;��@��@�@��@��������'@�����㔠'��@�@��@�@��@����������������@��@�@��@@����@�@�@�����~����@��3@���@��'@���3@��+@�!��@�� Հ��G��7@�@� ���T�����'@��!T�@��3@��/@� ��������@��������'@��3@������@��+@��3@�T��������B�����\���o����SA��{Ǩ�_��{�����
��������@�?���@9�@��� ��C����`T�*9 ��
����������G�@��/��Ҡ@������@�=���aˠ@�?��'�q`T�@�H����@�2������@�/����'��&Ntilde;�#�~�@�`��+��@�&amp;������+@���T�@�k����+@���T�@�e��+@���!�G��/@�!@�A�?�@T����
@��{ƨ�_��{���������G�@����ҡ@���������@���!�G��@�!@�A�?�@T�����{&egrave;�_��{�����
@���T�@��
@�&gt;����{&uml;�_��C����@��C��_��{�����
@��{Ĩ�_��{�������
@��@�F� ��{&uml;�_��{�������@�D�����{&uml;�_��C������@�@��@�@�?�bT�@��@��C��_��{�������
��ҡ
@��@�0��{&uml;�_��{���������G�@����Ҡ���@�6��@���!�G��@�!@�A�?�@T�����{&egrave;�_��{�����������
��@��@��@�*��{&egrave;�_��C����� ��C��_��C����@��C��_��{�����������@��������@�����q@T^����@������{&egrave;�_��C������@��@�� ��C��_��{���������� �R��9�@��@��@���{Ĩ�_��{�����������@��@��@���{&egrave;�_��{�����
@��{Ĩ�_��{�������c����{&uml;�_��{�����S��������@�����@�����@����������SA��{Ĩ�_��C����@�@��C��_��C����@��C��_��C����@��C��_��{���������� �R��9�@��@��@���{Ĩ�_��{�����������@��@� ˠ��@���T�@����@��@�D����@��@� ��{Ĩ�_��{��������@%��@���@����� ��{&uml;�_��{�������@������@�����{&uml;�_��{��������ЕД�$���$���������*����C����������
��ңzs������*s�`?֟�!��T�
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]02[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]2463[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]03524003[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]0421p7177274043[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]0621v71772740[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]03[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]23524727727G71772763SA5175{@5177C#2100[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]03_2675{765175[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]032140[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]377141\E7140[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]37@71[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]37[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]04q01[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]02T41\E@71407737R?kA[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]02T40600021457177274060[code]nvidia@nvidia-desktop:~$ tlt-converter
��*�C@����������
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
�&quot;
A�
�&quot;
B�
�&quot;
C�
T��
@� *�C��_��{�����
@��{@��� ��_�������
@���T�@��
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �&lt;�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'[/code]02': command not found
/home/nvidia/tlt_converter/tlt-converter: line 4: @~H~(P~)X~*`~,h~.p~/x~0�~1�~2�~3�~4�~5�~6�~7�~8�~9�~:�~;�~<�~=�~>�~?�~@BCD E(F0G8H@IHKPLXM`NhOpPxS�T�{����:��{���_��{�����F�5� � � � հ��F�"5� ְ��F�B5� ְ��F�b5� ְ��F��5� ְ��F��5� ְ��F��5� ְ��F��5� ְ��F�6� ְ��F�"6� ְ��F�B6� ְ��F�b6� ְ��F��6� ְ��F��6� ְ��F��6� ְ��F��6� ְ��F�7� ְ��F�"7� ְ��F�B7� ְ��F�b7� ְ��F��7� ְ��F��7� ְ��F��7� ְ��F��7� ְ�G�8� ְ�G�"8� ְ�
G�B8� ְ�G�b8� ְ�G��8� ְ�G��8� ְ�G��8� ְ�G��8� ְ�"G�9� ְ�&G�"9� ְ�*G�B9� ְ�.G�b9� ְ�2G��9� ְ�6G��9� ְ�:G��9� ְ�>G��9� ְ�BG�:� ְ�FG�":� ְ�JG�B:� ְ�NG�b:� ְ�RG��:� ְ�VG��:� ְ�ZG��:� ְ�^G��:� ְ�bG�;� ְ�fG�";� ְ�jG�B;� ְ�nG�b;� ְ�rG��;� ְ�vG��;� ְ�zG��;� ְ�~G��;� ְ��G�<� ְ��G�"<� ְ��G�B<� ְ��G�b<� ְ��G��<� ְ��G��<� ְ��G��<� ְ��G��<� ְ��G�=� ְ��G�"=� ְ��G�B=� ְ��G�b=� ְ��G��=� ְ��G��=� ְ��G��=� ְ��G��=� ְ��G�>� ��������@��#������G���c�G�����G�$����������G�@�����_֠Ѐ���!��?��T��!�G�A� ��_� ՠЀ���!��!�!�C�!�A�!�A�����B�G�B�@��_��{�����
�`9���@���!�R��3�R�R4�R ՠ#�W����q�1TW�����G�@��������㑠c����������c��c������c�E������w������G�@�R����G����G�@��������㑠#����������#����s����#�-������_�������G�@���������㑠#������������R�����9��#�����q��q�T@�R�O�"�:��#�����q��q�T �R�O�� :��#�����q��q`T�O�
�@:���@���!�R��3�R�R4�R ՠ#������q�$T������G�@������K����:����G�������@�@�����������;�����������Р;������������@<�������������<�����������Ѐ=������������@>�����������Р>��������������G�����������>����G����������G�����������?����G����������������������G���������������G��������`������������ ��������������G���������������G�������� ���������������������������������������������������������{������������u�����������o������� �����i��������G�����k����Rr��
��K@����G@��C@���_��R�c�������������c�������������c�������������*��!�G���B�!@�A�?�TD���������8���������2���������,���������&���������"���������������������#��������������������������㑼���
��*�C@����������
���R����@�!`�!@��T���q�T��@�`������B�R�����*`~@��~ӡC�"h ������@�
A�
B�
C�
A�
B�
C�
A�
B�
C�
�&ugrave;��@��ǹ����&Agrave;�,����{��W@��&Agrave;����{@������k@�@�@�������"
A�
B�
C�
T��
���@���!�R���o@�@���@�!�R�o@�@?�<��H�q!T���K@������ ��K������@�������g�������o@�@�`�@��g@��o@�@?֠o@�@� �@�!�R�o@�@?֠o@�@���@�!�R�o@�@?֠k@�@�@�@��R�s@��@��k@��?�RqT��
���@������@���!�Rl���@�@� �@���@� ?֠���S@��������R�R���*���*��������@�@�@���@� ?�����@�@� �@���@� ?��������������������"����g@��@T�g@���T�g@�@���@��g@� ?� ՠ�������%�����������
@� *�C��_��{�����
@��{@��� ��_�������
��� �����_��{�������'����'@�q�Tq�Tq`T>q@T
����������G�@��/��Ҡ@������@�=���aˠ@�?��'�q`T�@�H����@�2������@�/����'��&Ntilde;�#�~�@�`��+��@�&������+@���T�@�k����+@���T�@�e��+@���!�G��/@�!@�A�?�@T����
@���T�@��
@�>����{&uml;�_��C����@��C��_��{�����
@��{Ĩ�_��{�������
��ҡ
@���A���B��@��{Ĩ�_��_��{�����{���_� �� �<�.���ڐ�cj�� �lxUC�a�S�2stoi�[INFO] [WARNING] [INTERNAL_ERROR] [ERROR] cal.binsaved.engineb:c:d:e:i:k:m:o:s:t:w:hnchwnhwcncUnrecognized input order givenint8fp16fp32Unrecognized engine data type givenusage: [-h] [-v] [-e ENGINE_FILE_PATH]'
That’s the whole log…The command I typed was
tlt-converter
Of course, I added parameters to it.But no matter how I change the parameters, he always gives me this information, right.When I run this command on the x86_64 platform, it runs smoothly and produces an RT engine.But an error occurs when you run tlt-converter on TX2
Hi 17521754134,
For Jetson devices instead of x86, please download tlt-converter from dev-zone(https://developer.nvidia.com/tlt-converter) into your TX2.
Make sure you are using this tlt-converter instead of the one inside Jupyter notebook.
Then, run it to generate TRT engine.
For example, to generate an int8 TRT engine for Faster-rcnn (reference link: https://devtalk.nvidia.com/default/topic/1063940/transfer-learning-toolkit/transfert-learning-toolkit-gt-export-model-/)
$ ./tlt-converter frcnn_kitti_retrain.int8.etlt -e frcnn_int8.engine -k -c cal.bin -o dense_regress/BiasAdd,dense_class/Softmax,proposal -d 3,384,1280 -b 8 -m 4 -t int8 -i nchw
Thank you. I have a new problem
nvidia@nvidia-desktop:~$ tlt-converter -k $1234 -o NMS -d 3,384,1248 -e ./ssd_resnet_kitti/ssd_resnet_20191014.engine ./ssd_resnet_kitti/ssd_resnet_20191014.etlt
[ERROR] UffParser: Validator error: FirstDimTile_4: Unsupported operation _BatchTilePlugin_TRT
[ERROR] Failed to parse uff model
[ERROR] Network must have at least one output
[ERROR] Unable to create engine
https://github.com/NVIDIA-AI-IOT/deepstream_4.x_apps
When I run ./deepstream-custom <config_file> <H264_file>,it occur error like:
Using winsys: x11
Creating LL OSD context new
0:00:01.212971323 22530 0x1c26ca00 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:02.349060963 22530 0x1c26ca00 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): UffParser: Could not read buffer.
NvDsInferCudaEngineGetFromTltModel: Failed to parse UFF model
0:00:02.361163908 22530 0x1c26ca00 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Failed to create network using custom network creation function
0:00:02.361284196 22530 0x1c26ca00 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:02.361960128 22530 0x1c26ca00 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Failed to create NvDsInferContext instance
0:00:02.362010624 22530 0x1c26ca00 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Config file path: /home/nvidia/deepstream_sdk_v4.0_jetson/sources/objectDetector_SSD/config_infer_primary_ssd_change_tlt.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
** ERROR: main:651: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie_classifier: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
App run failed
I read the READ.md file,it need rebuild TensorRT OSS.when I try to rebuild TensorRT OSS,I can’t find TensorRT binary release for arm.
I assume your want to generate an SSD TRT engine. Please make sure
  1. your ngc key is correct.
  2. your ssd_resnet_20191014.etlt is generated successfully in previous step. And its output layer is NMS.
Hi Morganh
I run example of deepstream_4.x_apps.
The commandline is ./deepstream-custom pgie_ssd_uff_config.txt rtsp://admin:1111@10.0.0.155:554,but it occur error like:
Using winsys: x11
Opening in BLOCKING MODE
0:00:01.126391355 10970 0x559174bb20 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:02.537087796 10970 0x559174bb20 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): UffParser: Validator error: FirstDimTile_4: Unsupported operation _BatchTilePlugin_TRT
0:00:02.562178752 10970 0x559174bb20 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Failed to create network using custom network creation function
0:00:02.562276988 10970 0x559174bb20 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:02.562679245 10970 0x559174bb20 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:02.562727275 10970 0x559174bb20 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start: error: Config file path: pgie_ssd_uff_config.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Running…
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:ds-custom-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
The content of pgie_ssd_uff_config.txt is:
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
labelfile-path=./nvdsinfer_customparser_ssd_uff/ssd_labels.txt
#uff-file=./sample_ssd_keras.uff
#model-engine-file=./sample_ssd_keras.uff_b1_fp32.engine
tlt-encoded-model=./models/ssd/its_ssd_nvidia_tlt.etlt
tlt-model-key=nvidia_tlt
uff-input-dims=3;300;300;0
uff-input-blob-name=Input
batch-size=1
0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=4
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
#output-blob-names=MarkOutput_0
#output-blob-names=output_bbox/BisassAdd,output_cov/Sigmoid
output-blob-names=NMS
parse-bbox-func-name=NvDsInferParseCustomSSDUff
custom-lib-path=./nvdsinfer_customparser_ssd_uff/libnvds_infercustomparser_ssd_uff.so
[class-attrs-all]
threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Per class configuration
#[class-attrs-2]
#threshold=0.6
#roi-top-offset=20
#roi-bottom-offset=10
#detected-min-w=40
#detected-min-h=40
#detected-max-w=400
#detected-max-h=800
As tlt doc mentioned, please follow https://github.com/NVIDIA-AI-IOT/deepstream_4.x_apps along with TRT OSS https://github.com/NVIDIA/TensorRT/tree/release/5.1 to compile FasterRCNN DeepStream plugin and sample app.
For TRT OSS, you follow below steps in your x86_64 Linux PC
  1. Download TensorRT OSS sources.
  2. Download the TensorRT binary release.
  3. build docker and launch docker
    docker build -f docker/ubuntu-18.04.Dockerfile --build-arg CUDA_VERSION=10.1 --tag=tensorrt . docker run -v $TRT_RELEASE:/tensorrt -v $TRT_SOURCE:/workspace/TensorRT -it tensorrt:latest
  4. build OSS
    cd $TRT_SOURCE
    mkdir -p build && cd build
    cmake … -DTRT_LIB_DIR=TRT_RELEASE/lib -DTRT_BIN_DIR=`pwd`/out make -j(nproc)
  5. check the plugin
    $ ll out/libnvinfer_plugin.so*
