Not able to run samples after fresh install
naju@naju-Dell-G15-5520:/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app$ deepstream-app -c source1_usb_dec_infer_resnet_int8.txt
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1152 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b1_gpu0_int8.engine open error
0:00:00.248880343 35227 0x607768c16330 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b1_gpu0_int8.engine failed
0:00:00.248899016 35227 0x607768c16330 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b1_gpu0_int8.engine failed, try rebuild
0:00:00.248902795 35227 0x607768c16330 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: Unable to determine GPU memory usage: In getGpuMemStatsInBytes at /_src/common/extended/resources.cpp:1180
ERROR: [TRT]: createInferBuilder: Error Code 6: API Usage Error (CUDA initialization failure with error: 35. Please check your CUDA installation: CUDA Installation Guide for Linux — Installation Guide for Linux 13.1 documentation In operator() at /_src/optimizer/api/builder.cpp:1399)
ERROR: [TRT]: [checkMacros.cpp::catchCudaError::229] Error Code 1: Cuda Runtime (In catchCudaError at /_src/common/dispatch/checkMacros.cpp:229)
deepstream-app: ../nvdsinfer/nvdsinfer_model_builder.cpp:337: nvdsinfer::TrtModelBuilder::TrtModelBuilder(int, nvinfer1::ILogger&, const std::shared_ptrnvdsinfer::DlLibHandle&, bool): Assertion `m_Builder’ failed.
Aborted (core dumped)
this is the error
Deepstream 7.1
Ubuntu 22.04
Laptop
GPU 3050 Ti
Please help me fix this
CUDA error 35 means “driver is older than the CUDA runtime library”. what is the GPU driver verson? please refer to this compatibiliity table. DeepStream 7.1 requires R535.183.06(Data Center GPUs), R560.35.03(RTX GPUs).
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
