Not able to use LUKS Disk Encryption on Jetson NX
Hi!
I have a Jetson NX dev kit and I’d like to encrypt the SD Card to not expose my data. I followed the guide on this link that uses flash.sh to flash the NX in recovery mode. I’m using the standard image for JetPack 4.5 as my rootfs. I have following concerns with respect to the encryption feature:
  1. Is the encryption feature available only on module devices with eMMC? Because I read the code in flash.sh and it has the following section:
    rootdev_type="external";
    if [[ "${target_rootdev}" == "internal" || "${target_rootdev}" == mmcblk0p* || \
        "${target_rootdev}" == ${BOOTDEV} ]]; then
      rootdev_type="internal";
      INITRD="";
      if [ ${disk_enc_enable} -eq 1 ]; then
      	target_rootdev="internal";
      fi
    elif [ "${target_rootdev}" = "eth0" -o "${target_rootdev}" = "eth1" ]; then
      rootdev_type="network";
      disk_enc_enable=0;
    elif [[ "${target_rootdev}" != "external" && "${target_rootdev}" != mmcblk1p* && \
      "${target_rootdev}" != sd* && "${target_rootdev}" != nvme* ]]; then
      echo "Error: Invalid target rootdev($target_rootdev).";
      usage rootdevunknown 1;
    fi;
    if [[ "${rootdev_type}" == "external" ]]; then.  <--- disables encryption on SD card devices
      disk_enc_enable=0;
    fi;
    Here you can see that if the device boot device is mmcblk1p* which is the SD card, then it disables the disk encryption. How do I make it work with my SD Card?
  2. I tried hacking the script and forced disk_enc_enable=1, the installation proceeds normally for some time and fails with this error, I use the following command:
    sudo ROOTFS_ENC=1 ./flash.sh -i "./ekb.key" jetson-xavier-nx-devkit mmcblk1p1
    Which gives me following output:
    # L4T BSP Information:
    # R32 , REVISION: 5.0
    # Target Board Information:
    # Name: jetson-xavier-nx-devkit, Board Family: t186ref, SoC: Tegra 194,
    # OpMode: production, Boot Authentication: NS,
    # Disk encryption: enabled ,
    copying soft_fuses(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
    ./tegraflash.py --chip 0x19 --applet "/filer2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
    Welcome to Tegra Flash
    version 1.0.0
    Type ? or help for help and q or quit to exit
    Use ! to execute system commands
    [   0.0310 ] Generating RCM messages
    [   0.0329 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /filer2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
    [   0.0347 ] Header already present for /filer2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
    [   0.0397 ]
    [   0.0409 ] tegrasign_v2 --key None --getmode mode.txt
    [   0.0416 ] Assuming zero filled SBK key
    [   0.0421 ]
    [   0.0531 ] tegrasign_v2 --key None --file /filer2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
    [   0.0539 ] Assuming zero filled SBK key
    [   0.0585 ]
    [   0.0661 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /filer2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /filer2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
    [   0.0701 ]
    [   0.0736 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
    [   0.0745 ]
    [   0.0751 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /filer2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
    [   0.0778 ] RCM 0 is saved as rcm_0.rcm
    [   0.0810 ] RCM 1 is saved as rcm_1.rcm
    [   0.0812 ] RCM 2 is saved as rcm_2.rcm
    [   0.0825 ] List of rcm files are saved in rcm_list.xml
    [   0.0828 ]
    [   0.0828 ] Signing RCM messages
    [   0.0840 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
    [   0.0847 ] Assuming zero filled SBK key
    [   0.0893 ]
    [   0.0893 ] Copying signature to RCM mesages
    [   0.0906 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
    [   0.0982 ]
    [   0.0983 ] Boot Rom communication
    [   0.0996 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
    [   0.1002 ] RCM version 0X190001
    [   0.1014 ] Boot Rom communication completed
    [   1.1177 ]
    [   2.1201 ] tegrarcm_v2 --isapplet
    [   2.1209 ] Applet version 01.00.0000
    [   2.1378 ]
    [   2.1403 ] tegrarcm_v2 --ismb2
    [   2.1730 ]
    [   2.1758 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
    [   2.1786 ]
    [   2.1802 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
    [   2.1810 ] adding BCH for nvtboot_applet_t194.bin
    [   2.1837 ]
    [   2.1853 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
    [   2.1859 ] Assuming zero filled SBK key
    [   2.1882 ]
    [   2.1891 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
    [   2.1920 ]
    [   2.1952 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
    [   2.1969 ] Applet version 01.00.0000
    [   2.2129 ] Sending mb2
    [   2.2130 ] [................................................] 100%
    [   2.2332 ]
    [   2.2347 ] tegrarcm_v2 --boot recovery
    [   2.2356 ] Applet version 01.00.0000
    [   2.2577 ]
    [   3.2602 ] tegrarcm_v2 --isapplet
    [   3.2773 ]
    [   3.2787 ] tegrarcm_v2 --ismb2
    [   3.2795 ] MB2 Applet version 01.00.0000
    [   3.3133 ]
    [   3.3170 ] tegrarcm_v2 --ismb2
    [   3.3180 ] MB2 Applet version 01.00.0000
    [   3.3498 ]
    [   3.3524 ] Retrieving board information
    [   3.3536 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
    [   3.3554 ] MB2 Applet version 01.00.0000
    [   3.3909 ] Saved platform info in chip_info.bin
    [   3.3971 ] Chip minor revision: 2
    [   3.3972 ] Bootrom revision: 0xf
    [   3.3972 ] Ram code: 0x0
    [   3.3972 ] Chip sku: 0xde
    [   3.3972 ] Chip Sample: non es
    [   3.3972 ]
    [   3.3977 ] Retrieving EEPROM data
    [   3.3977 ] tegrarcm_v2 --oem platformdetails eeprom cvm /filer2/Linux_for_Tegra/bootloader/cvm.bin
    [   3.3992 ] MB2 Applet version 01.00.0000
    [   3.4230 ] Saved platform info in /filer2/Linux_for_Tegra/bootloader/cvm.bin
    [   3.4617 ]
    [   3.4618 ] Rebooting to recovery mode
    [   3.4634 ] tegrarcm_v2 --ismb2
    [   3.4643 ] MB2 Applet version 01.00.0000
    [   3.4952 ]
    [   3.4953 ] Rebooting to recovery mode
    [   3.4967 ] tegrarcm_v2 --reboot recovery
    [   3.5026 ] MB2 Applet version 01.00.0000
    [   3.5292 ]
    Board ID(3668) version(200) sku(0000) revision(J.0)
    Copy /filer2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /filer2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
    copying bctfile(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
    copying bctfile1(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
    copying device_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
    copying misc_cold_boot_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
    copying misc_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
    copying pinmux_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
    copying gpioint_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
    copying pmic_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
    copying pmc_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
    copying prod_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
    copying scr_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
    copying scr_cold_boot_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
    copying bootrom_config(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
    copying dev_params(/filer2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
    Existing bootloader(/filer2/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
    copying initrd(/filer2/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
    prepare_luks_initrd: Begin to copy binaries into initrd
    30402 blocks
    49606 blocks
    prepare_luks_initrd: Finish copying binaries into initrd
    done.
      populating kernel to rootfs... done.
    /filer2/Linux_for_Tegra/bootloader/tegraflash.py  --chip 0x19 --key  --cmd sign /filer2/Linux_for_Tegra/rootfs/boot/Image
    version 1.0.0
    [   0.0279 ] Generating signature
    [   0.0291 ] tegrasign_v2 --key  --getmode mode.txt
    [   0.0298 ] Assuming zero filled SBK key
    [   0.0302 ]
    [   0.0304 ] header_magic: 5614
    [   0.0320 ] tegrahost_v2 --chip 0x19 --align 1_Image
    [   0.0330 ]
    [   0.0334 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
    [   0.0338 ] adding BCH for 1_Image
    [   0.7750 ]
    [   0.7798 ] tegrasign_v2 --key  --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
    [   0.7805 ] Assuming zero filled SBK key
    [   1.0234 ]
    [   1.0255 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
    [   1.5205 ]
    [   1.7199 ] Signed file: /filer2/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
    l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
    l4t_sign_image.sh: chip 0x19: add 0x20bf808 to offset  0x8 in sig file
    l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
    l4t_sign_image.sh: the sign header is saved at /filer2/Linux_for_Tegra/rootfs/boot/Image.sig
    done.
      populating initrd to rootfs... done.
    /filer2/Linux_for_Tegra/bootloader/tegraflash.py  --chip 0x19 --key  --cmd sign /filer2/Linux_for_Tegra/rootfs/boot/initrd
    version 1.0.0
    [   0.0405 ] Generating signature
    [   0.0422 ] tegrasign_v2 --key  --getmode mode.txt
    [   0.0430 ] Assuming zero filled SBK key
    [   0.0434 ]
    [   0.0437 ] header_magic: 1f8b0800
    [   0.0446 ] tegrahost_v2 --chip 0x19 --align 1_initrd
    [   0.0453 ]
    [   0.0459 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
    [   0.0468 ] adding BCH for 1_initrd
    [   0.3640 ]
    [   0.3678 ] tegrasign_v2 --key  --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
    [   0.3691 ] Assuming zero filled SBK key
    [   0.5989 ]
    [   0.6002 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
    [   0.7745 ]
    [   0.8958 ] Signed file: /filer2/Linux_for_Tegra/bootloader/initrd_sigheader.encrypt
    l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
    l4t_sign_image.sh: chip 0x19: add 0xad42ae to offset  0x8 in sig file
    l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
    l4t_sign_image.sh: the sign header is saved at /filer2/Linux_for_Tegra/rootfs/boot/initrd.sig
    done.
      populating /filer2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to rootfs... done.
    Making Boot image... done.
    /filer2/Linux_for_Tegra/bootloader/tegraflash.py  --chip 0x19 --key  --cmd sign boot.img
    version 1.0.0
    [   0.0015 ] Generating signature
    [   0.0030 ] tegrasign_v2 --key  --getmode mode.txt
    [   0.0036 ] Assuming zero filled SBK key
    [   0.0041 ]
    [   0.0045 ] header_magic: 414e4452
    [   0.0062 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
    [   0.0074 ]
    [   0.0087 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_boot.img zerosbk
    [   0.0142 ] adding BCH for 1_boot.img
    [   1.0378 ]
    [   1.0429 ] tegrasign_v2 --key  --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
    [   1.0442 ] Assuming zero filled SBK key
    [   1.3981 ]
    [   1.4001 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
    [   2.2164 ]
    [   2.6025 ] Signed file: /filer2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
    l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
    l4t_sign_image.sh: chip 0x19: add 0x2b95000 to offset  0x8 in sig file
    l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
    l4t_sign_image.sh: the signed file is /filer2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
    done.
    Making recovery ramdisk for recovery image...
    Re-generating recovery ramdisk for recovery image...
    /filer2/Linux_for_Tegra/bootloader/ramdisk_tmp /filer2/Linux_for_Tegra/bootloader /filer2/Linux_for_Tegra
    30402 blocks
    _BASE_KERNEL_VERSION=4.9.201-tegra
    /filer2/Linux_for_Tegra/bootloader/ramdisk_tmp/lib /filer2/Linux_for_Tegra/bootloader/ramdisk_tmp /filer2/Linux_for_Tegra/bootloader /filer2/Linux_for_Tegra
    65765 blocks
    Making Recovery image...
    copying recdtbfile(/filer2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
    20+0 records in
    20+0 records out
    20 bytes copied, 0.000487891 s, 41.0 kB/s
    Existing sosfile(/filer2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
    Existing tegraboot(/filer2/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
    Existing cpu_bootloader(/filer2/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
    Existing mb2blfile(/filer2/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
    Existing mtspreboot(/filer2/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
    Existing mcepreboot(/filer2/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
    Existing mtsproper(/filer2/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
    Existing mb1file(/filer2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
    Existing bpffile(/filer2/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
    copying bpfdtbfile(/filer2/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
    Existing scefile(/filer2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
    Existing camerafw(/filer2/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
    Existing spefile(/filer2/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
    Existing drameccfile(/filer2/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
    Existing badpagefile(/filer2/Linux_for_Tegra/bootloader/badpage.bin) reused.
    Existing wb0boot(/filer2/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
    Existing tosfile(/filer2/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
    Existing eksfile(/filer2/Linux_for_Tegra/bootloader/eks.img) reused.
    copying dtbfile(/filer2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
    Copying nv_boot_control.conf to rootfs
    XPath set is empty
    /filer2/Linux_for_Tegra/bootloader/tegraflash.py  --chip 0x19 --key  --cmd sign kernel_tegra194-p3668-all-p3509-0000.dtb
    version 1.0.0
    [   0.0053 ] Generating signature
    [   0.0064 ] tegrasign_v2 --key  --getmode mode.txt
    [   0.0070 ] Assuming zero filled SBK key
    [   0.0073 ]
    [   0.0077 ] header_magic: d00dfeed
    [   0.0127 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
    [   0.0143 ]
    [   0.0152 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
    [   0.0164 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
    [   0.0241 ]
    [   0.0265 ] tegrasign_v2 --key  --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
    [   0.0272 ] Assuming zero filled SBK key
    [   0.0323 ]
    [   0.0350 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
    [   0.0407 ]
    [   0.0428 ] Signed file: /filer2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
    l4t_sign_image.sh: Generate header for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
    l4t_sign_image.sh: chip 0x19: add 0x30c8e to offset  0x8 in sig file
    l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
    l4t_sign_image.sh: the sign header is saved at kernel_tegra194-p3668-all-p3509-0000.dtb.sig
    done.
    version 1.0.0
    [   0.0022 ] Generating signature
    [   0.0079 ] tegrasign_v2 --key  --getmode mode.txt
    [   0.0089 ] Assuming zero filled SBK key
    [   0.0096 ]
    [   0.0099 ] header_magic: d00dfeed
    [   0.0110 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p3668-all-p3509-0000.dtb
    [   0.0173 ]
    [   0.0269 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_kernel_tegra194-p3668-all-p3509-0000.dtb zerosbk
    [   0.0320 ] adding BCH for 1_kernel_tegra194-p3668-all-p3509-0000.dtb
    [   0.0394 ]
    [   0.0428 ] tegrasign_v2 --key  --list 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
    [   0.0434 ] Assuming zero filled SBK key
    [   0.0454 ]
    [   0.0492 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
    [   0.0549 ]
    [   0.0584 ] Signed file: /filer2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
    l4t_sign_image.sh: the signed file is /filer2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
    done.
    generating  for booting...
    Making APPFILE...
    Error: file system size has to be 512 bytes allign
hello hatake_kakashi,
yes, Jetson security only supports with eMMC modules; due to SD card is removeable, it is not supported.
