I am currently trying to port a radiative transfer code to GPU. The code is about 3000 lines, but for now the cuda relevent part only ~ 200 lines.
I don’t expect it to comile correctly yet, but I get an error message such that
I have no idea to the nature of the problem…
/opt/pgi/linux86-64/11.1/bin/pgf90 -Mlarge_arrays -Bdynamic -mcmodel=medium -Mcuda=cc13 -c tr_ly_utils_cuda.cuf
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(34): error: class “” has no member “m”/tmp/pgcudaforfHjgpIHQFwvJ.gpu(38): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(40): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(42): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(43): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(44): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(45): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(49): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(59): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(60): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(61): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(66): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(70): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(71): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(72): error: class “” has no member “m”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(99): error: class “” has no member “m4122904”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(100): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(101): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(102): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(103): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(104): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(107): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(108): error: class “” has no member “m4184344”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(110): error: class “” has no member “m4122904”
/tmp/pgcudaforfHjgpIHQFwvJ.gpu(111): error: class “” has no member “m4184344”
27 errors detected in the compilation of “/tmp/pgnvdPIjg74VnjPwX.nv0”.
PGF90-F-0000-Internal compiler error. pgnvd job exited with nonzero status code 0 (tr_ly_utils_cuda.cuf: 153)
PGF90/x86-64 Linux 11.1-0: compilation aborted
make: *** [utils_cuda.mod] Erreur 2
Any hint? I am using version 11.1 of the compiler with the following options:
If necessary I can post the current version of the .cuf files, but they are not so short…
Benoit Semelin.
