This is progress. Now it fails because it cannot delete the folder when it tries to uninstall the previous version:
C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions\NVIDIA
It says that it cannot delete due to permissions, but I already manually deleted it earlier. So, there is no such folder in my case now. I attach here the new log file.
=== Verbose logging started: 10/8/2018 10:51:41 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Windows\system32\msiexec.exe ===
MSI (c) (F4:88) [10:51:41:342]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (F4:B8) [10:51:41:360]: Resetting cached policy values
MSI (c) (F4:B8) [10:51:41:360]: Machine policy value ‘Debug’ is 0
MSI (c) (F4:B8) [10:51:41:360]: ******* RunEngine:
******* Product: NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi
******* Action:
******* CommandLine: **********
MSI (c) (F4:B8) [10:51:41:362]: Machine policy value ‘DisableUserInstalls’ is 0
MSI (c) (F4:B8) [10:51:41:440]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (c) (F4:B8) [10:51:41:441]: SOFTWARE RESTRICTION POLICY: Verifying package → ‘C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi’ against software restriction policy
MSI (c) (F4:B8) [10:51:41:442]: SOFTWARE RESTRICTION POLICY: C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi has a digital signature
MSI (c) (F4:B8) [10:51:45:378]: SOFTWARE RESTRICTION POLICY: C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi is permitted to run at the ‘unrestricted’ authorization level.
MSI (c) (F4:B8) [10:51:45:385]: Cloaking enabled.
MSI (c) (F4:B8) [10:51:45:385]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (F4:B8) [10:51:45:388]: End dialog not enabled
MSI (c) (F4:B8) [10:51:45:388]: Original package ==> C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi
MSI (c) (F4:B8) [10:51:45:388]: Package we’re running from ==> C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi
MSI (c) (F4:B8) [10:51:45:396]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (F4:B8) [10:51:45:396]: APPCOMPAT: looking for appcompat database entry with ProductCode ‘{CDBB8E9C-056A-4B34-AB2E-70166508F455}’.
MSI (c) (F4:B8) [10:51:45:396]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (F4:B8) [10:51:45:407]: MSCOREE not loaded loading copy from system32
MSI (c) (F4:B8) [10:51:45:411]: Machine policy value ‘TransformsSecure’ is 0
MSI (c) (F4:B8) [10:51:45:411]: User policy value ‘TransformsAtSource’ is 0
MSI (c) (F4:B8) [10:51:45:412]: Machine policy value ‘DisablePatch’ is 0
MSI (c) (F4:B8) [10:51:45:412]: Machine policy value ‘AllowLockdownPatch’ is 0
MSI (c) (F4:B8) [10:51:45:412]: Machine policy value ‘DisableLUAPatching’ is 0
MSI (c) (F4:B8) [10:51:45:412]: Machine policy value ‘DisableFlyWeightPatching’ is 0
MSI (c) (F4:B8) [10:51:45:413]: APPCOMPAT: looking for appcompat database entry with ProductCode ‘{CDBB8E9C-056A-4B34-AB2E-70166508F455}’.
MSI (c) (F4:B8) [10:51:45:413]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (F4:B8) [10:51:45:413]: Transforms are not secure.
MSI (c) (F4:B8) [10:51:45:413]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is ‘C:\Users\user\Downloads\nsight.log’.
MSI (c) (F4:B8) [10:51:45:413]: Command Line: CURRENTDIRECTORY=C:\Users\user\Downloads CLIENTUILEVEL=0 CLIENTPROCESSID=10996
MSI (c) (F4:B8) [10:51:45:413]: PROPERTY CHANGE: Adding PackageCode property. Its value is ‘{D8D4B4EA-0808-4F6B-AB47-BC9406D5CD1F}’.
MSI (c) (F4:B8) [10:51:45:413]: Product Code passed to Engine.Initialize: ‘’
MSI (c) (F4:B8) [10:51:45:413]: Product Code from property table before transforms: ‘{CDBB8E9C-056A-4B34-AB2E-70166508F455}’
MSI (c) (F4:B8) [10:51:45:413]: Product Code from property table after transforms: ‘{CDBB8E9C-056A-4B34-AB2E-70166508F455}’
MSI (c) (F4:B8) [10:51:45:413]: Product not registered: beginning first-time install
MSI (c) (F4:B8) [10:51:45:413]: PROPERTY CHANGE: Adding ProductState property. Its value is ‘-1’.
MSI (c) (F4:B8) [10:51:45:413]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (F4:B8) [10:51:45:413]: User policy value ‘SearchOrder’ is ‘nmu’
MSI (c) (F4:B8) [10:51:45:413]: Adding new sources is allowed.
MSI (c) (F4:B8) [10:51:45:413]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is ‘1’.
MSI (c) (F4:B8) [10:51:45:413]: Package name extracted from package path: ‘NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi’
MSI (c) (F4:B8) [10:51:45:414]: Package to be registered: ‘NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi’
MSI (c) (F4:B8) [10:51:45:414]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (F4:B8) [10:51:45:414]: Machine policy value ‘DisableMsi’ is 0
MSI (c) (F4:B8) [10:51:45:414]: Machine policy value ‘AlwaysInstallElevated’ is 0
MSI (c) (F4:B8) [10:51:45:414]: User policy value ‘AlwaysInstallElevated’ is 0
MSI (c) (F4:B8) [10:51:45:414]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (F4:B8) [10:51:45:414]: Running product ‘{CDBB8E9C-056A-4B34-AB2E-70166508F455}’ with elevated privileges: Product is assigned.
MSI (c) (F4:B8) [10:51:45:414]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is ‘C:\Users\user\Downloads’.
MSI (c) (F4:B8) [10:51:45:414]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is ‘0’.
MSI (c) (F4:B8) [10:51:45:414]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is ‘10996’.
MSI (c) (F4:B8) [10:51:45:414]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is ‘1’.
MSI (c) (F4:B8) [10:51:45:414]: TRANSFORMS property is now:
MSI (c) (F4:B8) [10:51:45:414]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is ‘405’.
MSI (c) (F4:B8) [10:51:45:415]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming
MSI (c) (F4:B8) [10:51:45:415]: SHELL32::SHGetFolderPath returned: C:\Users\user\Favorites
MSI (c) (F4:B8) [10:51:45:415]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (F4:B8) [10:51:45:415]: SHELL32::SHGetFolderPath returned: C:\Users\user\Documents
MSI (c) (F4:B8) [10:51:45:415]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (F4:B8) [10:51:45:416]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (F4:B8) [10:51:45:416]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (F4:B8) [10:51:45:416]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (F4:B8) [10:51:45:416]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (F4:B8) [10:51:45:416]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Local
MSI (c) (F4:B8) [10:51:45:417]: SHELL32::SHGetFolderPath returned: C:\Users\user\Pictures
MSI (c) (F4:B8) [10:51:45:417]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (F4:B8) [10:51:45:417]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (F4:B8) [10:51:45:418]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (F4:B8) [10:51:45:418]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (F4:B8) [10:51:45:418]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (F4:B8) [10:51:45:419]: SHELL32::SHGetFolderPath returned: C:\Users\user\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (c) (F4:B8) [10:51:45:419]: SHELL32::SHGetFolderPath returned: C:\Users\user\Desktop
MSI (c) (F4:B8) [10:51:45:419]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (F4:B8) [10:51:45:420]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (F4:B8) [10:51:45:421]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (F4:B8) [10:51:45:432]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (F4:B8) [10:51:45:432]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is ‘1’.
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding Privileged property. Its value is ‘1’.
MSI (c) (F4:B8) [10:51:45:432]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding USERNAME property. Its value is ‘Windows User’.
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding DATABASE property. Its value is ‘C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi’.
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is ‘C:\Users\user\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_6.0.0.18260.msi’.
MSI (c) (F4:B8) [10:51:45:432]: Machine policy value ‘MsiDisableEmbeddedUI’ is 0
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\user\Downloads'.
MSI (c) (F4:B8) [10:51:45:432]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\user\Downloads'.
MSI (c) (F4:88) [10:51:45:434]: PROPERTY CHANGE: Adding VersionHandler property. Its value is ‘5.00’.
=== Logging started: 10/8/2018 10:51:45 ===
MSI (c) (F4:B8) [10:51:45:443]: Note: 1: 2205 2: 3: PatchPackage
MSI (c) (F4:B8) [10:51:45:443]: Machine policy value ‘DisableRollback’ is 0
MSI (c) (F4:B8) [10:51:45:443]: User policy value ‘DisableRollback’ is 0
MSI (c) (F4:B8) [10:51:45:443]: PROPERTY CHANGE: Adding UILevel property. Its value is ‘5’.
MSI (c) (F4:B8) [10:51:45:444]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (c) (F4:B8) [10:51:45:444]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (c) (F4:B8) [10:51:45:446]: PROPERTY CHANGE: Adding ACTION property. Its value is ‘INSTALL’.
MSI (c) (F4:B8) [10:51:45:446]: Doing action: INSTALL
Action 10:51:45: INSTALL.
Action start 10:51:45: INSTALL.
MSI (c) (F4:B8) [10:51:45:446]: UI Sequence table ‘InstallUISequence’ is present and populated.
MSI (c) (F4:B8) [10:51:45:446]: Running UISequence
MSI (c) (F4:B8) [10:51:45:446]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is ‘INSTALL’.
MSI (c) (F4:B8) [10:51:45:447]: Doing action: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 10:51:45: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 10:51:45: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (F4:B8) [10:51:45:447]: PROPERTY CHANGE: Adding ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs'.
Action ended 10:51:45: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (F4:B8) [10:51:45:447]: Doing action: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 10:51:45: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 10:51:45: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (F4:B8) [10:51:45:447]: PROPERTY CHANGE: Adding ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files (x86)'.
Action ended 10:51:45: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (F4:B8) [10:51:45:447]: Doing action: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 10:51:45: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 10:51:45: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (F4:B8) [10:51:45:448]: PROPERTY CHANGE: Adding ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files'.
Action ended 10:51:45: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (F4:B8) [10:51:45:448]: Doing action: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 10:51:45: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 10:51:45: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (F4:B8) [10:51:45:448]: PROPERTY CHANGE: Adding StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu'.
Action ended 10:51:45: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (F4:B8) [10:51:45:448]: Doing action: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 10:51:45: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 10:51:45: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (F4:B8) [10:51:45:448]: PROPERTY CHANGE: Adding DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Users\Public\Desktop'.
Action ended 10:51:45: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (F4:B8) [10:51:45:448]: Doing action: SystemFolder_x86_VC.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8
Action 10:51:45: SystemFolder_x86_VC.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8.
Action start 10:51:45: SystemFolder_x86_VC.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8.
MSI (c) (F4:B8) [10:51:45:449]: PROPERTY CHANGE: Adding SystemFolder_x86_VC.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8 property. Its value is 'C:\WINDOWS\SysWOW64'.
Action ended 10:51:45: SystemFolder_x86_VC.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8. Return value 1.
MSI (c) (F4:B8) [10:51:45:449]: Doing action: SystemFolder.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8
Action 10:51:45: SystemFolder.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8.
Action start 10:51:45: SystemFolder.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8.
MSI (c) (F4:B8) [10:51:45:449]: PROPERTY CHANGE: Adding SystemFolder.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8 property. Its value is 'C:\WINDOWS\SysWOW64'.
Action ended 10:51:45: SystemFolder.B796D14F_AD8C_3A96_B2B8_3D8FF8499DA8. Return value 1.
MSI (c) (F4:B8) [10:51:45:449]: Doing action: System64Folder.BC0B92F1_D156_35A8_A565_6689E8DDDA1F
Action 10:51:45: System64Folder.BC0B92F1_D156_35A8_A565_6689E8DDDA1F.
Action start 10:51:45: System64Folder.BC0B92F1_D156_35A8_A565_6689E8DDDA1F.
MSI (c) (F4:B8) [10:51:45:449]: PROPERTY CHANGE: Adding System64Folder.BC0B92F1_D156_35A8_A565_6689E8DDDA1F property. Its value is 'C:\WINDOWS\system32'.
Action ended 10:51:45: System64Folder.BC0B92F1_D156_35A8_A565_6689E8DDDA1F. Return value 1.
MSI (c) (F4:B8) [10:51:45:449]: Doing action: System64Folder_amd64_VC.BC0B92F1_D156_35A8_A565_6689E8DDDA1F
Action 10:51:45: System64Folder_amd64_VC.BC0B92F1_D156_35A8_A565_6689E8DDDA1F.
Action start 10:51:45: System64Folder_amd64_VC.BC0B92F1_D156_35A8_A565_6689E8DDDA1F.
MSI (c) (F4:B8) [10:51:45:450]: PROPERTY CHANGE: Adding System64Folder_amd64_VC.BC0B92F1_D156_35A8_A565_6689E8DDDA1F property. Its value is 'C:\WINDOWS\system32'.
Action ended 10:51:45: System64Folder_amd64_VC.BC0B92F1_D156_35A8_A565_6689E8DDDA1F. Return value 1.
MSI (c) (F4:B8) [10:51:45:450]: Doing action: FindRelatedProducts
Action 10:51:45: FindRelatedProducts. Searching for related applications
Action start 10:51:45: FindRelatedProducts.
FindRelatedProducts: Found application: {01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}
MSI (c) (F4:B8) [10:51:45:451]: PROPERTY CHANGE: Adding PREVIOUSVERSIONSINSTALLED property. Its value is ‘{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}’.
MSI (c) (F4:B8) [10:51:45:451]: PROPERTY CHANGE: Adding MIGRATE property. Its value is ‘{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}’.
Action ended 10:51:45: FindRelatedProducts. Return value 1.
MSI (c) (F4:B8) [10:51:45:451]: Doing action: get_VISUALSTUDIO2017LOCATION
Action 10:51:45: get_VISUALSTUDIO2017LOCATION.
Action start 10:51:45: get_VISUALSTUDIO2017LOCATION.
MSI (c) (F4:F0) [10:51:45:453]: Invoking remote custom action. DLL: C:\Users\user\AppData\Local\Temp\MSIFDD3.tmp, Entrypoint: InitializeVS2017Properties
MSI (c) (F4:08) [10:51:45:455]: Cloaking enabled.
MSI (c) (F4:08) [10:51:45:455]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (F4:08) [10:51:45:455]: Connected to service for CA interface.
SFXCA: Extracting custom action to temporary directory: C:\Users\user\AppData\Local\Temp\MSIFDD3.tmp-
SFXCA: Binding to CLR version v4.0.30319
Calling custom action VSInstanceFinder!VSInstanceFinder.CustomActions.InitializeVS2017Properties
starting custom action FindAnyVS2017Location()
MSI (c) (F4!A0) [10:51:45:860]: PROPERTY CHANGE: Adding VISUALSTUDIO2017INSTANCES property. Its value is ‘1’.
MSI (c) (F4!A0) [10:51:45:860]: PROPERTY CHANGE: Adding VISUALSTUDIO2017INSTANCECOUNT property. Its value is ‘1 instance’.
Considering VS2017 instance rooted at C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise
MSI (c) (F4!A0) [10:51:45:863]: PROPERTY CHANGE: Adding VISUALSTUDIO2017FOLDER property. Its value is ‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE’.
completed custom action FindAnyVS2017Location()
Action ended 10:51:45: get_VISUALSTUDIO2017LOCATION. Return value 1.
MSI (c) (F4:B8) [10:51:45:885]: Doing action: PrepareCustomDlg
Action 10:51:45: PrepareCustomDlg.
Action start 10:51:45: PrepareCustomDlg.
Info 2898. For WixUI_Font_Normal textstyle, the system created a ‘Tahoma’ font, in 0 character set, of 13 pixels height.
Info 2898. For WixUI_Font_Bigger textstyle, the system created a ‘Tahoma’ font, in 0 character set, of 19 pixels height.
Action 10:51:45: PrepareCustomDlg. Dialog created
Action ended 10:51:45: PrepareCustomDlg. Return value 1.
MSI (c) (F4:B8) [10:51:45:945]: Doing action: AppSearch
Action 10:51:45: AppSearch. Searching for installed applications
Action start 10:51:45: AppSearch.
AppSearch: Property: DOTNETFRAMEWORK40CLIENT, Signature: RegistrySearch_DOTNETFRAMEWORK40CLIENT
MSI (c) (F4:B8) [10:51:45:949]: PROPERTY CHANGE: Adding DOTNETFRAMEWORK40CLIENT property. Its value is ‘#1’.
AppSearch: Property: DOTNETFRAMEWORK40FULL, Signature: RegistrySearch_DOTNETFRAMEWORK40FULL
MSI (c) (F4:B8) [10:51:45:954]: PROPERTY CHANGE: Adding DOTNETFRAMEWORK40FULL property. Its value is ‘#1’.
AppSearch: Property: DOTNETFRAMEWORK4KEY, Signature: RegistrySearch_DOTNETFRAMEWORK4KEY
MSI (c) (F4:B8) [10:51:45:957]: PROPERTY CHANGE: Adding DOTNETFRAMEWORK4KEY property. Its value is ‘#1’.
AppSearch: Property: KB971512KEY, Signature: RegistrySearch_KB971512KEY
MSI (c) (F4:B8) [10:51:45:958]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-DGT-Package-TopLevel~31bf3856ad364e35~amd64~~7.0.6002.18107 3: 2
AppSearch: Property: VISUALSTUDIO2015KEY, Signature: RegistrySearch_VISUALSTUDIO2015KEY
AppSearch: Property: VISUALSTUDIO2015LOCATION, Signature: RegistrySearch_VISUALSTUDIO2015LOCATION
AppSearch: Property: DEVENV2015FILEEXISTS, Signature: FileSearch_DEVENV2015FILEEXISTS
MSI (c) (F4:B8) [10:51:45:965]: Note: 1: 1322 2:
AppSearch: Property: VISUALSTUDIO2015FOLDER, Signature: DirectorySearch_VISUALSTUDIO2015FOLDER
MSI (c) (F4:B8) [10:51:45:969]: Note: 1: 1322 2:
MSI (c) (F4:B8) [10:51:45:969]: PROPERTY CHANGE: Adding VISUALSTUDIO2015FOLDER property. Its value is 'C:'.
AppSearch: Property: VISUALSTUDIO2013KEY, Signature: RegistrySearch_VISUALSTUDIO2013KEY
AppSearch: Property: VISUALSTUDIO2013LOCATION, Signature: RegistrySearch_VISUALSTUDIO2013LOCATION
AppSearch: Property: DEVENV2013FILEEXISTS, Signature: FileSearch_DEVENV2013FILEEXISTS
MSI (c) (F4:B8) [10:51:45:977]: Note: 1: 1322 2:
AppSearch: Property: VISUALSTUDIO2013FOLDER, Signature: DirectorySearch_VISUALSTUDIO2013FOLDER
MSI (c) (F4:B8) [10:51:45:980]: Note: 1: 1322 2:
MSI (c) (F4:B8) [10:51:45:980]: PROPERTY CHANGE: Adding VISUALSTUDIO2013FOLDER property. Its value is 'C:'.
AppSearch: Property: VISUALSTUDIO2012KEY, Signature: RegistrySearch_VISUALSTUDIO2012KEY
AppSearch: Property: VISUALSTUDIO2012LOCATION, Signature: RegistrySearch_VISUALSTUDIO2012LOCATION
AppSearch: Property: DEVENV2012FILEEXISTS, Signature: FileSearch_DEVENV2012FILEEXISTS
MSI (c) (F4:B8) [10:51:45:987]: Note: 1: 1322 2:
AppSearch: Property: VISUALSTUDIO2012FOLDER, Signature: DirectorySearch_VISUALSTUDIO2012FOLDER
MSI (c) (F4:B8) [10:51:45:990]: Note: 1: 1322 2:
MSI (c) (F4:B8) [10:51:45:990]: PROPERTY CHANGE: Adding VISUALSTUDIO2012FOLDER property. Its value is 'C:'.
AppSearch: Property: UXTPRODUCTVERSIONREG, Signature: RegistrySearch_UXTPRODUCTVERSIONREG
MSI (c) (F4:B8) [10:51:45:992]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\NVIDIA Corporation\Registration\Nsight Visual Studio Edition 3: 2
AppSearch: Property: USERSIPFILEEXISTS, Signature: CheckUserSIPFile
MSI (c) (F4:B8) [10:51:45:994]: Note: 1: 1322 2:
MSI (c) (F4:B8) [10:51:45:994]: Note: 1: 1324 2: \Vsip\1.0\Settings 3: 1
AppSearch: Property: MSDIA110REGISTERED, Signature: RegistrySearch_MSDIA110WOW6432REGISTERED
MSI (c) (F4:B8) [10:51:45:997]: PROPERTY CHANGE: Adding MSDIA110REGISTERED property. Its value is ‘C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 5.5\Monitor\Redistributables\VsDiaSdk\11\x64\msdia110.dll’.
AppSearch: Property: MSDIA11064REGISTERED, Signature: RegistrySearch_MSDIA110REGISTERED
MSI (c) (F4:B8) [10:51:45:999]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\CLSID{761D3BCD-1304-41D5-94E8-EAC54E4AC172}\InprocServer32 3: 2
Action ended 10:51:45: AppSearch. Return value 1.
MSI (c) (F4:B8) [10:51:45:999]: Doing action: SetDISABLE_NV_CH
Action 10:51:45: SetDISABLE_NV_CH.
Action start 10:51:46: SetDISABLE_NV_CH.
Action ended 10:51:46: SetDISABLE_NV_CH. Return value 1.
MSI (c) (F4:B8) [10:51:46:001]: Doing action: SetDOTNETFRAMEWORK4EXISTS
Action 10:51:46: SetDOTNETFRAMEWORK4EXISTS.
Action start 10:51:46: SetDOTNETFRAMEWORK4EXISTS.
MSI (c) (F4:B8) [10:51:46:003]: PROPERTY CHANGE: Modifying DOTNETFRAMEWORK4EXISTS property. Its current value is ‘false’. Its new value: ‘true’.
Action ended 10:51:46: SetDOTNETFRAMEWORK4EXISTS. Return value 1.
MSI (c) (F4:B8) [10:51:46:003]: Doing action: SetDOTNETFRAMEWORK4REQUIREMENTSPASS
Action 10:51:46: SetDOTNETFRAMEWORK4REQUIREMENTSPASS.
Action start 10:51:46: SetDOTNETFRAMEWORK4REQUIREMENTSPASS.
MSI (c) (F4:B8) [10:51:46:005]: PROPERTY CHANGE: Modifying DOTNETFRAMEWORK4REQUIREMENTSPASS property. Its current value is ‘false’. Its new value: ‘true’.
Action ended 10:51:46: SetDOTNETFRAMEWORK4REQUIREMENTSPASS. Return value 1.
MSI (c) (F4:B8) [10:51:46:005]: Skipping action: SetVISUALSTUDIO2012REQUIREMENTSPASS (condition is false)
MSI (c) (F4:B8) [10:51:46:005]: Skipping action: SetVISUALSTUDIO2013REQUIREMENTSPASS (condition is false)
MSI (c) (F4:B8) [10:51:46:005]: Skipping action: SetVISUALSTUDIO2015REQUIREMENTSPASS (condition is false)
MSI (c) (F4:B8) [10:51:46:005]: Doing action: SetVISUALSTUDIO2017REQUIREMENTSPASS
Action 10:51:46: SetVISUALSTUDIO2017REQUIREMENTSPASS.
Action start 10:51:46: SetVISUALSTUDIO2017REQUIREMENTSPASS.
MSI (c) (F4:B8) [10:51:46:007]: PROPERTY CHANGE: Modifying VISUALSTUDIO2017REQUIREMENTSPASS property. Its current value is ‘false’. Its new value: ‘true’.
Action ended 10:51:46: SetVISUALSTUDIO2017REQUIREMENTSPASS. Return value 1.
MSI (c) (F4:B8) [10:51:46:007]: Doing action: LaunchConditions
Action 10:51:46: LaunchConditions. Evaluating launch conditions
Action start 10:51:46: LaunchConditions.
Action ended 10:51:46: LaunchConditions. Return value 1.
MSI (c) (F4:B8) [10:51:46:011]: Doing action: SetHOSTREQUIREMENTSPASSED
Action 10:51:46: SetHOSTREQUIREMENTSPASSED.
Action start 10:51:46: SetHOSTREQUIREMENTSPASSED.
MSI (c) (F4:B8) [10:51:46:013]: PROPERTY CHANGE: Modifying HOSTREQUIREMENTSPASSED property. Its current value is ‘false’. Its new value: ‘true’.
Action ended 10:51:46: SetHOSTREQUIREMENTSPASSED. Return value 1.
MSI (c) (F4:B8) [10:51:46:013]: Doing action: SetMONITORREQUIREMENTSPASSED
Action 10:51:46: SetMONITORREQUIREMENTSPASSED.
Action start 10:51:46: SetMONITORREQUIREMENTSPASSED.
MSI (c) (F4:B8) [10:51:46:015]: PROPERTY CHANGE: Modifying MONITORREQUIREMENTSPASSED property. Its current value is ‘false’. Its new value: ‘true’.
Action ended 10:51:46: SetMONITORREQUIREMENTSPASSED. Return value 1.
MSI (c) (F4:B8) [10:51:46:015]: Skipping action: SetSIP_CHECK_ENABLED (condition is false)
MSI (c) (F4:B8) [10:51:46:015]: Skipping action: SetVISTADIRECTX11WARNINGREQUIRED (condition is false)
MSI (c) (F4:B8) [10:51:46:015]: Skipping action: SetDOTNETFRAMEWORK4EXISTSFAILMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:015]: Skipping action: SetDOTNETFRAMEWORK4EXISTSFAILSHORTMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:015]: Doing action: SetDOTNETFRAMEWORK4EXISTSPASSMESSAGE
Action 10:51:46: SetDOTNETFRAMEWORK4EXISTSPASSMESSAGE.
Action start 10:51:46: SetDOTNETFRAMEWORK4EXISTSPASSMESSAGE.
MSI (c) (F4:B8) [10:51:46:017]: PROPERTY CHANGE: Adding DOTNETFRAMEWORK4EXISTSPASSMESSAGE property. Its value is '.NET framework 4 is installed. '.
Action ended 10:51:46: SetDOTNETFRAMEWORK4EXISTSPASSMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:017]: Doing action: SetVS2012REQUIREMENTFAILMESSAGE
Action 10:51:46: SetVS2012REQUIREMENTFAILMESSAGE.
Action start 10:51:46: SetVS2012REQUIREMENTFAILMESSAGE.
MSI (c) (F4:B8) [10:51:46:020]: PROPERTY CHANGE: Adding VS2012REQUIREMENTFAILMESSAGE property. Its value is 'Microsoft Visual Studio 2012 was not found. '.
Action ended 10:51:46: SetVS2012REQUIREMENTFAILMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:020]: Doing action: SetVS2012REQUIREMENTFAILSHORTMESSAGE
Action 10:51:46: SetVS2012REQUIREMENTFAILSHORTMESSAGE.
Action start 10:51:46: SetVS2012REQUIREMENTFAILSHORTMESSAGE.
MSI (c) (F4:B8) [10:51:46:022]: PROPERTY CHANGE: Adding VS2012REQUIREMENTFAILSHORTMESSAGE property. Its value is ‘MS VS2012 was not found.’.
Action ended 10:51:46: SetVS2012REQUIREMENTFAILSHORTMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:023]: Skipping action: SetVS2012REQUIREMENTPASSMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:023]: Skipping action: SetVS2012VS2013VS2015VS2017REQUIREMENTFAILMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:023]: Skipping action: SetVS2012VS2013VS2015VS2017REQUIREMENTFAILSHORTMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:023]: Doing action: SetVS2013REQUIREMENTFAILMESSAGE
Action 10:51:46: SetVS2013REQUIREMENTFAILMESSAGE.
Action start 10:51:46: SetVS2013REQUIREMENTFAILMESSAGE.
MSI (c) (F4:B8) [10:51:46:025]: PROPERTY CHANGE: Adding VS2013REQUIREMENTFAILMESSAGE property. Its value is 'Microsoft Visual Studio 2013 was not found. '.
Action ended 10:51:46: SetVS2013REQUIREMENTFAILMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:025]: Doing action: SetVS2013REQUIREMENTFAILSHORTMESSAGE
Action 10:51:46: SetVS2013REQUIREMENTFAILSHORTMESSAGE.
Action start 10:51:46: SetVS2013REQUIREMENTFAILSHORTMESSAGE.
MSI (c) (F4:B8) [10:51:46:027]: PROPERTY CHANGE: Adding VS2013REQUIREMENTFAILSHORTMESSAGE property. Its value is ‘MS VS2013 was not found.’.
Action ended 10:51:46: SetVS2013REQUIREMENTFAILSHORTMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:028]: Skipping action: SetVS2013REQUIREMENTPASSMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:028]: Doing action: SetVS2015REQUIREMENTFAILMESSAGE
Action 10:51:46: SetVS2015REQUIREMENTFAILMESSAGE.
Action start 10:51:46: SetVS2015REQUIREMENTFAILMESSAGE.
MSI (c) (F4:B8) [10:51:46:030]: PROPERTY CHANGE: Adding VS2015REQUIREMENTFAILMESSAGE property. Its value is 'Microsoft Visual Studio 2015 was not found. '.
Action ended 10:51:46: SetVS2015REQUIREMENTFAILMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:030]: Doing action: SetVS2015REQUIREMENTFAILSHORTMESSAGE
Action 10:51:46: SetVS2015REQUIREMENTFAILSHORTMESSAGE.
Action start 10:51:46: SetVS2015REQUIREMENTFAILSHORTMESSAGE.
MSI (c) (F4:B8) [10:51:46:032]: PROPERTY CHANGE: Adding VS2015REQUIREMENTFAILSHORTMESSAGE property. Its value is ‘MS VS2015 was not found.’.
Action ended 10:51:46: SetVS2015REQUIREMENTFAILSHORTMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:032]: Skipping action: SetVS2015REQUIREMENTPASSMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:032]: Skipping action: SetVS2017REQUIREMENTFAILMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:032]: Skipping action: SetVS2017REQUIREMENTFAILSHORTMESSAGE (condition is false)
MSI (c) (F4:B8) [10:51:46:032]: Doing action: SetVS2017REQUIREMENTPASSMESSAGE
Action 10:51:46: SetVS2017REQUIREMENTPASSMESSAGE.
Action start 10:51:46: SetVS2017REQUIREMENTPASSMESSAGE.
MSI (c) (F4:B8) [10:51:46:034]: PROPERTY CHANGE: Adding VS2017REQUIREMENTPASSMESSAGE property. Its value is 'Microsoft Visual Studio 2017 is installed. '.
Action ended 10:51:46: SetVS2017REQUIREMENTPASSMESSAGE. Return value 1.
MSI (c) (F4:B8) [10:51:46:035]: Doing action: ValidateProductID
Action 10:51:46: ValidateProductID.
Action start 10:51:46: ValidateProductID.
Action ended 10:51:46: ValidateProductID. Return value 1.
MSI (c) (F4:B8) [10:51:46:037]: Doing action: CostInitialize
Action 10:51:46: CostInitialize. Computing space requirements
Action start 10:51:46: CostInitialize.
MSI (c) (F4:B8) [10:51:46:039]: Machine policy value ‘MaxPatchCacheSize’ is 10
MSI (c) (F4:B8) [10:51:46:041]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:'.
MSI (c) (F4:B8) [10:51:46:044]: PROPERTY CHANGE: Adding CostingComplete property. Its value is ‘0’.
Action ended 10:51:46: CostInitialize. Return value 1.
MSI (c) (F4:B8) [10:51:46:045]: Doing action: FileCost
Action 10:51:46: FileCost. Computing space requirements
Action start 10:51:46: FileCost.
MSI (c) (F4:B8) [10:51:46:049]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (F4:B8) [10:51:46:050]: Note: 1: 2205 2: 3: Class
MSI (c) (F4:B8) [10:51:46:050]: Note: 1: 2205 2: 3: Extension
MSI (c) (F4:B8) [10:51:46:050]: Note: 1: 2205 2: 3: TypeLib
Action ended 10:51:46: FileCost. Return value 1.
MSI (c) (F4:B8) [10:51:46:051]: Doing action: CostFinalize
Action 10:51:46: CostFinalize. Computing space requirements
Action start 10:51:46: CostFinalize.
MSI (c) (F4:B8) [10:51:46:053]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is ‘0’.
MSI (c) (F4:B8) [10:51:46:053]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is ‘0’.
MSI (c) (F4:B8) [10:51:46:053]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is ‘0’.
MSI (c) (F4:B8) [10:51:46:053]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is ‘0’.
MSI (c) (F4:B8) [10:51:46:053]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is ‘0’.
MSI (c) (F4:B8) [10:51:46:054]: Note: 1: 2205 2: 3: Patch
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding MergeRedirectFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding STARTMENU_NVIDIACORPORATION.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_NVIDIATOOLSEXTENSION64BIT.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation\NVIDIA Tools Extension (64 bit)'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding ROOTINSTALLDIR.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding INSTALLDIR.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding NVTX_SAMPLES_COMPONENT_SAMPLES.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\samples'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding NVTX_SAMPLES_COMPONENT_NVTXMULTITHREADED.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\samples\NvtxMultithreaded'.
MSI (c) (F4:B8) [10:51:46:057]: PROPERTY CHANGE: Adding NVTX_SAMPLES_COMPONENT_NVTXSIMPLE.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\samples\NvtxSimple'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_LIB.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\lib'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_WIN321.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\lib\Win32'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_X641.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\lib\x64'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_INCLUDE.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\include'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_BIN.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\bin'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_WIN32.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\bin\Win32'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_X64_COMPONENT_X64.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\bin\x64'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NVTX_DOCS_COMPONENT_DOCS.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\NVIDIA Corporation\NvToolsExt\docs'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Modifying VISUALSTUDIO2017FOLDER property. Its current value is ‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE’. Its new value: 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding NEXUS.VS.EXTENSIONS.2017.PROPERTY.VISUALSTUDIO2017FOLDER.EXTENSIONS property. Its value is 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding VS.EXTENSIONS.2017.PROPERTY.VISUALSTUDIO2017FOLDER.EXTENSIONS.NVIDIA property. Its value is 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions\NVIDIA'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding Y.VISUALSTUDIO2017FOLDER.EXTENSIONS.NVIDIA.NSIGHT.VISUAL.STUDIO.EDITION property. Its value is 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions\NVIDIA\Nsight Visual Studio Edition'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding SUALSTUDIO2017FOLDER.EXTENSIONS.NVIDIA.NSIGHT.VISUAL.STUDIO.EDITION.6.0 property. Its value is 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions\NVIDIA\Nsight Visual Studio Edition\6.0'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLSTARTMENU.NVIDIA.CORPORATION property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLSTARTMENU property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation\Nsight Visual Studio Edition 6.0'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDATADIR.NVIDIA.CORPORATION property. Its value is 'C:\ProgramData\NVIDIA Corporation'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDATADIR.NSIGHT property. Its value is 'C:\ProgramData\NVIDIA Corporation\Nsight'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDATADIR.NSIGHT.VSIP property. Its value is 'C:\ProgramData\NVIDIA Corporation\Nsight\Vsip'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDATADIR.NSIGHT.VSIP.VERSION property. Its value is 'C:\ProgramData\NVIDIA Corporation\Nsight\Vsip\1.0'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDATADIR.NSIGHT.VSIP.VERSION.SETTINGS property. Its value is 'C:\ProgramData\NVIDIA Corporation\Nsight\Vsip\1.0\Settings'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDATADIR property. Its value is 'C:\ProgramData\NVIDIA Corporation\Nsight\Visual Studio'.
MSI (c) (F4:B8) [10:51:46:058]: PROPERTY CHANGE: Adding INSTALLDIR64.NVIDIA.CORPORATION property. Its value is 'C:\Program Files\NVIDIA Corporation'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding INSTALLDIR64.NSIGHT.VISUAL.STUDIO.EDITION.6.0 property. Its value is 'C:\Program Files\NVIDIA Corporation\Nsight Visual Studio Edition 6.0'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding E._PROGRAM64.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR property. Its value is 'C:\Program Files\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding INSTALLDIR64 property. Its value is 'C:\Program Files\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Host'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding NEXUS.MONITOR.CORE._PROGRAM32.NVIDIA.CORPORATION property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding ITOR.CORE._PROGRAM32.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding E._PROGRAM32.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding REDIST.VSDIASDK._PROGRAM32.REDIST property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\Redistributables'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding REDIST.VSDIASDK._PROGRAM32.REDIST.VSDIASDK property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\Redistributables\VsDiaSdk'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding ON.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.REDIST.VSDIASDK.11 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\Redistributables\VsDiaSdk\11'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding SIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.REDIST.VSDIASDK.11.X64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\Redistributables\VsDiaSdk\11\x64'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding GHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.REDIST.VSDIASDK.11.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\Redistributables\VsDiaSdk\11\Win32'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding GRAM32.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding X2.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.X86 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\x86'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding A.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.SAMPLE_CODE property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\Sample_Code'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding T.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.SAMPLE_CODE.SYNC_CONFIGURATION property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\Sample_Code\Sync_Configuration'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding RPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.SAMPLE_CODE.I2C property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\Sample_Code\i2c'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.SAMPLE_CODE.DISPLAYCONFIGURATION property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\Sample_Code\DisplayConfiguration'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.SAMPLE_CODE.DISPLAYCOLORCONTROL property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\Sample_Code\DisplayColorControl'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.SAMPLE_CODE.CUSTOMTIMING property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\Sample_Code\CustomTiming'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding X.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.DOCS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\docs'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.NVAPI.AMD64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\nvapi\amd64'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding RAM32.NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9'.
MSI (c) (F4:B8) [10:51:46:059]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\lib'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\lib\win64'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\lib\win32'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\headers'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\bin'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\bin\win64'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_9.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_9\bin\win32'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\lib'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\lib\win64'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\lib\win32'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\headers'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\bin'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\bin\win64'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_8.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_8\bin\win32'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\lib'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\lib\win64'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\lib\win32'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\headers'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\bin'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\bin\win64'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_7.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_7\bin\win32'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\lib'.
MSI (c) (F4:B8) [10:51:46:060]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\lib\win64'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\lib\win32'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\headers'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\bin'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\bin\win64'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_6.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_6\bin\win32'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\lib'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\lib\win64'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\lib\win32'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\headers'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\bin'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\bin\win64'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_5.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_5\bin\win32'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\lib'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\lib\win64'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\lib\win32'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\headers'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\bin'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\bin\win64'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_4.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_4\bin\win32'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\lib'.
MSI (c) (F4:B8) [10:51:46:061]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\lib\win64'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\lib\win32'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\headers'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\bin'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\bin\win64'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_3.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_3\bin\win32'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding NVIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.SAMPLES property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\samples'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding HT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.SAMPLES.HELLOVR_OPENGL property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\samples\hellovr_opengl'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\lib'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\lib\win64'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\lib\win32'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding ORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\headers'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding IA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\bin'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\bin\win64'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding PORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_2.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_2\bin\win32'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding VIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding A.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\lib'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\lib\win64'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\lib\win32'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding RPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\headers'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding A.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\bin'.
MSI (c) (F4:B8) [10:51:46:062]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\bin\win64'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_13.BIN.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_13\bin\win32'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding VIDIA.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_12'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding A.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12.LIB property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_12\lib'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12.LIB.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_12\lib\win64'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12.LIB.WIN32 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_12\lib\win32'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding RPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12.HEADERS property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_12\headers'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding A.CORPORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12.BIN property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation\Nsight Visual Studio Edition 6.0\Monitor\OpenVR\1_0_12\bin'.
MSI (c) (F4:B8) [10:51:46:063]: PROPERTY CHANGE: Adding ORATION.NSIGHT.VISUAL.STUDIO.EDITION.6.0.MONITOR.OPENVR.1_0_12.BIN.WIN64 property. Its value is 'C:\Program Files (x86)\NVIDIA Corporation
