Nsight installation problem windows 10 - Setup Wizard ended prematurely because of an error
Hi all,
I am unable to install NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162.
I am on windows 10.
The msi installer immediately opens up with the error:
...Setup Wizard ended prematurely because of an error...
I enabled logging for msi installer following this:
And finally, the msi produced a more detailed message:
=== Verbose logging started: 6/28/2017  21:46:30  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\WINDOWS\System32\msiexec.exe ===
MSI (c) (60:DC) [21:46:30:217]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (60:DC) [21:46:30:218]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (60:E0) [21:46:30:235]: Resetting cached policy values
MSI (c) (60:E0) [21:46:30:235]: Machine policy value 'Debug' is 0
MSI (c) (60:E0) [21:46:30:235]: ******* RunEngine:
           ******* Product: C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (60:E0) [21:46:30:236]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (60:E0) [21:46:30:255]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi' against software restriction policy
MSI (c) (60:E0) [21:46:30:257]: SOFTWARE RESTRICTION POLICY: C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi has a digital signature
MSI (c) (60:E0) [21:46:32:592]: SOFTWARE RESTRICTION POLICY: C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (60:E0) [21:46:32:596]: Cloaking enabled.
MSI (c) (60:E0) [21:46:32:596]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (60:E0) [21:46:32:598]: End dialog not enabled
MSI (c) (60:E0) [21:46:32:598]: Original package ==> C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi
MSI (c) (60:E0) [21:46:32:598]: Package we're running from ==> C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi
MSI (c) (60:E0) [21:46:32:601]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (60:E0) [21:46:32:602]: APPCOMPAT: looking for appcompat database entry with ProductCode '{9512F355-0967-49D8-AF15-DA7A797CCC7A}'.
MSI (c) (60:E0) [21:46:32:602]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (60:E0) [21:46:32:609]: MSCOREE not loaded loading copy from system32
MSI (c) (60:E0) [21:46:32:611]: Machine policy value 'TransformsSecure' is 0
MSI (c) (60:E0) [21:46:32:611]: User policy value 'TransformsAtSource' is 0
MSI (c) (60:E0) [21:46:32:612]: Machine policy value 'DisablePatch' is 0
MSI (c) (60:E0) [21:46:32:612]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (60:E0) [21:46:32:612]: Machine policy value 'DisableMsi' is 0
MSI (c) (60:E0) [21:46:32:612]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (60:E0) [21:46:32:612]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (60:E0) [21:46:32:612]: Running product '{9512F355-0967-49D8-AF15-DA7A797CCC7A}' with user privileges: It's not assigned.
MSI (c) (60:E0) [21:46:32:612]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (60:E0) [21:46:32:612]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (60:E0) [21:46:32:612]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (60:E0) [21:46:32:613]: APPCOMPAT: looking for appcompat database entry with ProductCode '{9512F355-0967-49D8-AF15-DA7A797CCC7A}'.
MSI (c) (60:E0) [21:46:32:613]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (60:E0) [21:46:32:613]: Transforms are not secure.
MSI (c) (60:E0) [21:46:32:613]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\HOLOFE~1\AppData\Local\Temp\MSI45cc0.LOG'.
MSI (c) (60:E0) [21:46:32:613]: Command Line: CURRENTDIRECTORY=C:\Users\holofermes\Downloads CLIENTUILEVEL=0 CLIENTPROCESSID=15968
MSI (c) (60:E0) [21:46:32:613]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{831169B7-9E89-4728-9911-DA81A1963272}'.
MSI (c) (60:E0) [21:46:32:613]: Product Code passed to Engine.Initialize:           ''
MSI (c) (60:E0) [21:46:32:613]: Product Code from property table before transforms: '{9512F355-0967-49D8-AF15-DA7A797CCC7A}'
MSI (c) (60:E0) [21:46:32:613]: Product Code from property table after transforms:  '{9512F355-0967-49D8-AF15-DA7A797CCC7A}'
MSI (c) (60:E0) [21:46:32:613]: Product not registered: beginning first-time install
MSI (c) (60:E0) [21:46:32:613]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (60:E0) [21:46:32:613]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (60:E0) [21:46:32:613]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (60:E0) [21:46:32:613]: Adding new sources is allowed.
MSI (c) (60:E0) [21:46:32:613]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (60:E0) [21:46:32:613]: Package name extracted from package path: 'NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi'
MSI (c) (60:E0) [21:46:32:613]: Package to be registered: 'NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi'
MSI (c) (60:E0) [21:46:32:613]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (60:E0) [21:46:32:613]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (60:E0) [21:46:32:613]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (60:E0) [21:46:32:613]: Running product '{9512F355-0967-49D8-AF15-DA7A797CCC7A}' with user privileges: It's not assigned.
MSI (c) (60:E0) [21:46:32:613]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\holofermes\Downloads'.
MSI (c) (60:E0) [21:46:32:614]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (60:E0) [21:46:32:614]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '15968'.
MSI (c) (60:E0) [21:46:32:614]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (60:E0) [21:46:32:614]: TRANSFORMS property is now:
MSI (c) (60:E0) [21:46:32:614]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '405'.
MSI (c) (60:E0) [21:46:32:614]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming
MSI (c) (60:E0) [21:46:32:614]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\Favorites
MSI (c) (60:E0) [21:46:32:614]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (60:E0) [21:46:32:614]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\Documents
MSI (c) (60:E0) [21:46:32:614]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Local
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\Pictures
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (60:E0) [21:46:32:615]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (60:E0) [21:46:32:616]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (60:E0) [21:46:32:616]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (60:E0) [21:46:32:616]: SHELL32::SHGetFolderPath returned: C:\Users\holofermes\Desktop
MSI (c) (60:E0) [21:46:32:616]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (60:E0) [21:46:32:617]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (60:E0) [21:46:32:617]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (60:E0) [21:46:32:624]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (60:E0) [21:46:32:624]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
MSI (c) (60:E0) [21:46:32:624]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (60:E0) [21:46:32:625]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (60:E0) [21:46:32:625]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi'.
MSI (c) (60:E0) [21:46:32:625]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\holofermes\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.3.0.17162 (2).msi'.
MSI (c) (60:E0) [21:46:32:625]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (60:E0) [21:46:32:625]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\holofermes\Downloads\'.
MSI (c) (60:E0) [21:46:32:625]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\holofermes\Downloads\'.
MSI (c) (60:DC) [21:46:32:625]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 6/28/2017  21:46:32 ===
MSI (c) (60:E0) [21:46:32:631]: Note: 1: 2205 2:  3: PatchPackage
MSI (c) (60:E0) [21:46:32:631]: Machine policy value 'DisableRollback' is 0
MSI (c) (60:E0) [21:46:32:631]: User policy value 'DisableRollback' is 0
MSI (c) (60:E0) [21:46:32:632]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (60:E0) [21:46:32:632]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (c) (60:E0) [21:46:32:633]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (c) (60:E0) [21:46:32:633]: PROPERTY CHANGE: Adding SHIMFLAGS property. Its value is '512'.
MSI (c) (60:E0) [21:46:32:634]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (60:E0) [21:46:32:634]: Doing action: INSTALL
Action 21:46:32: INSTALL.
Action start 21:46:32: INSTALL.
MSI (c) (60:E0) [21:46:32:634]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (60:E0) [21:46:32:634]: Running UISequence
MSI (c) (60:E0) [21:46:32:634]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (60:E0) [21:46:32:634]: Doing action: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 21:46:32: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 21:46:32: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (60:E0) [21:46:32:635]: PROPERTY CHANGE: Adding ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\'.
Action ended 21:46:32: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (60:E0) [21:46:32:635]: Doing action: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 21:46:32: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 21:46:32: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (60:E0) [21:46:32:635]: PROPERTY CHANGE: Adding ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files (x86)\'.
Action ended 21:46:32: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (60:E0) [21:46:32:635]: Doing action: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 21:46:32: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 21:46:32: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (60:E0) [21:46:32:636]: PROPERTY CHANGE: Adding ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files\'.
Action ended 21:46:32: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (60:E0) [21:46:32:636]: Doing action: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 21:46:32: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 21:46:32: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (60:E0) [21:46:32:636]: PROPERTY CHANGE: Adding StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\'.
Action ended 21:46:32: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (60:E0) [21:46:32:636]: Doing action: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 21:46:32: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 21:46:32: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (60:E0) [21:46:32:637]: PROPERTY CHANGE: Adding DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Users\Public\Desktop\'.
Action ended 21:46:32: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (60:E0) [21:46:32:637]: Doing action: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA
Action 21:46:32: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA.
Action start 21:46:32: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA.
MSI (c) (60:E0) [21:46:32:637]: PROPERTY CHANGE: Adding SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA property. Its value is 'C:\WINDOWS\SysWOW64\'.
Action ended 21:46:32: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA. Return value 1.
MSI (c) (60:E0) [21:46:32:637]: Doing action: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C
Action 21:46:32: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C.
Action start 21:46:32: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C.
MSI (c) (60:E0) [21:46:32:637]: PROPERTY CHANGE: Adding System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C property. Its value is 'C:\WINDOWS\system32\'.
Action ended 21:46:32: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C. Return value 1.
MSI (c) (60:E0) [21:46:32:637]: Doing action: FindRelatedProducts
Action 21:46:32: FindRelatedProducts. Searching for related applications
Action start 21:46:32: FindRelatedProducts.
FindRelatedProducts: Found application: {39F2CF8F-DE76-49F1-85D5-FC215853B709}
MSI (c) (60:E0) [21:46:32:638]: PROPERTY CHANGE: Adding PREVIOUSVERSIONSINSTALLED property. Its value is '{39F2CF8F-DE76-49F1-85D5-FC215853B709}'.
MSI (c) (60:E0) [21:46:32:638]: PROPERTY CHANGE: Adding MIGRATE property. Its value is '{39F2CF8F-DE76-49F1-85D5-FC215853B709}'.
Action ended 21:46:32: FindRelatedProducts. Return value 1.
MSI (c) (60:E0) [21:46:32:638]: Doing action: get_VISUALSTUDIO2017LOCATION
Action 21:46:32: get_VISUALSTUDIO2017LOCATION.
Action start 21:46:32: get_VISUALSTUDIO2017LOCATION.
MSI (c) (60:E0) [21:46:32:671]: Creating MSIHANDLE (1) of type 790542 for thread 5856
MSI (c) (60:A0) [21:46:32:671]: Invoking remote custom action. DLL: C:\Users\HOLOFE~1\AppData\Local\Temp\MSI6646.tmp, Entrypoint: InitializeVS2017Properties
MSI (c) (60:5C) [21:46:32:672]: Cloaking enabled.
MSI (c) (60:5C) [21:46:32:672]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (60:5C) [21:46:32:673]: Connected to service for CA interface.
MSI (c) (60!6C) [21:46:32:762]: Creating MSIHANDLE (2) of type 790531 for thread 15212
SFXCA: Extracting custom action to temporary directory: C:\Users\HOLOFE~1\AppData\Local\Temp\MSI6646.tmp-\
MSI (c) (60!6C) [21:46:32:763]: Closing MSIHANDLE (2) of type 790531 for thread 15212
MSI (c) (60!6C) [21:46:32:826]: Creating MSIHANDLE (3) of type 790531 for thread 15212
SFXCA: Binding to CLR version v4.0.30319
MSI (c) (60!6C) [21:46:32:827]: Closing MSIHANDLE (3) of type 790531 for thread 15212
MSI (c) (60!6C) [21:46:32:863]: Creating MSIHANDLE (4) of type 790531 for thread 15212
Calling custom action VSInstanceFinder!VSInstanceFinder.CustomActions.InitializeVS2017Properties
MSI (c) (60!6C) [21:46:32:866]: Closing MSIHANDLE (4) of type 790531 for thread 15212
MSI (c) (60!6C) [21:46:32:881]: Creating MSIHANDLE (5) of type 790531 for thread 15212
Exception thrown by custom action:
MSI (c) (60!6C) [21:46:32:882]: Closing MSIHANDLE (5) of type 790531 for thread 15212
MSI (c) (60!6C) [21:46:32:884]: Creating MSIHANDLE (6) of type 790531 for thread 15212
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'VSInstanceFinder.CustomActions' threw an exception. ---> System.IO.FileNotFoundException: The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
   at Microsoft.VisualStudio.Setup.Configuration.ISetupInstance2.GetDisplayName(Int32 lcid)
   at VSInstanceFinder.VSInstance..ctor(ISetupInstance instance)
   at VSInstanceFinder.VSInstanceContainer..ctor()
   at VSInstanceFinder.CustomActions..cctor()
   --- End of inner exception stack trace ---
   at VSInstanceFinder.CustomActions.InitializeVS2017Properties(Session session)
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object parameters, Object arguments)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture)
   at Microsoft.Deployment.WindowsInstaller.CustomActionProxy.InvokeCustomAction(Int32 sessionHandle, String entryPoint, IntPtr remotingDelegatePtr)
MSI (c) (60!6C) [21:46:32:885]: Closing MSIHANDLE (6) of type 790531 for thread 15212
CustomAction get_VISUALSTUDIO2017LOCATION returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (c) (60:A0) [21:46:32:894]: Closing MSIHANDLE (1) of type 790542 for thread 5856
Action ended 21:46:32: get_VISUALSTUDIO2017LOCATION. Return value 3.
MSI (c) (60:E0) [21:46:32:895]: Doing action: FatalErrorCustom
Action 21:46:32: FatalErrorCustom.
Action start 21:46:32: FatalErrorCustom.
Info 2898. For WixUI_Font_Normal textstyle, the system created a 'Tahoma' font, in 0 character set, of 13 pixels height.
Info 2898. For WixUI_Font_Bigger textstyle, the system created a 'Tahoma' font, in 0 character set, of 19 pixels height.
Action 21:46:32: FatalErrorCustom. Dialog created
MSI (c) (60:F0) [21:46:32:913]: Note: 1: 2731 2: 0
Action ended 21:46:34: FatalErrorCustom. Return value 2.
Action ended 21:46:34: INSTALL. Return value 3.
MSI (c) (60:E0) [21:46:34:144]: Destroying RemoteAPI object.
MSI (c) (60:5C) [21:46:34:145]: Custom Action Manager thread ending.
Property(C): DiskPrompt = NVIDIA Nsight Visual Studio Edition 5.3.0.17162 Installation
Property(C): UpgradeCode = {5C0261A2-00D2-45C8-8F45-71A1AF7586B3}
Property(C): ARPNOMODIFY = 1
Property(C): ARPNOREPAIR = 1
Property(C): ALLUSERS = 1
Property(C): HOSTREQUIREMENTSPASSED = false
Property(C): MONITORREQUIREMENTSPASSED = false
Property(C): DOTNETFRAMEWORK4EXISTS = false
Property(C): DOTNETFRAMEWORK4REQUIREMENTSPASS = false
Property(C): VISUALSTUDIO2010REQUIREMENTSPASS = false
Property(C): VISUALSTUDIO2012REQUIREMENTSPASS = false
Property(C): VISUALSTUDIO2013REQUIREMENTSPASS = false
Property(C): VISUALSTUDIO2015REQUIREMENTSPASS = false
Property(C): VISUALSTUDIO2017REQUIREMENTSPASS = false
Property(C): INSTALL_VS2017 = no
Property(C): UNINSTALL_VS2017 = no
It looks like it’s tripping over the “get_VISUALSTUDIO2017LOCATION” action maybe.
Anyway, any help would be appreciated.
I have the same problem. It is almost the same but the error shown in the log file is slightly different. Does nobody at NVidia have a solution?
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'VSInstanceFinder.CustomActions' threw an exception. ---> System.Runtime.InteropServices.COMException: Element not found. (Exception from HRESULT: 0x80070490)
   at Microsoft.VisualStudio.Setup.Configuration.ISetupInstance.GetInstallationVersion()
Action ended 11:13:45: get_VISUALSTUDIO2017LOCATION. Return value 3.
Hi holofernes,
Can you try it again with the latest release Nsight 5.4 build please?
You can download the build here https://developer.nvidia.com/nsight-visual-studio-edition-downloads?
Please tell us if you still encounter the issue.
Thanks,
Letitia
Still have the issue, the app install rolls back with no indication of why. I have vs2015, just re-installed VS2017 as well.
Sorry for delay.
Can you provide more information please?
  • VS2017 version, professional or enterprise version?
  • WIN10 version
  • Did the issue happen if VS2017 is uninstalled?
  • Can you please uninstall VS2017, driver and nsight, reboot the machine, then install VS2017 and nsight, try it again?
Thanks,
Letitia
Hello Letitia,
Thank you for your response. Here are the answers to your questions.
  • VS2017 Pro
  • Windows 10 Pro v1709 with all updates applied
  • Same error when VS2017 is completely uninstalled
  • Reinstall of VS2017 and still the same error
I have since given up and compile everything with nvcc for .cu or cl for .c but would love to be able to run the samples with VSxxxx so i can utilize the samples to learn more.
Hi aikeith,
Thanks for your feedback.
The issue is very weird, for we never met such problems and we cannot reproduce the issue locally.
Can you please try it again on other WIN10 machines? Better on a “clearer” machine, just install OS, driver, Visual Studio and nsight.
Thanks,
Letitia
Thank you for your reply Letitia.
Reinstalling everything on my primary development machine is not an option. I did do a clean install of windows 10 Fall Creators Update approx 3 months ago, so it has gone through a lot of updates (well not major ones anyways but it is windows).
Just to clarify, the ONLY thing that doesn’t install properly is the Visual Studio plugin. However if you select that with the install, the entire install fails. If i select everything except the plugin then the install works fine, i can compile with nvcc.
Would you happen to be able to offer just the VS plugin like in a VSIX package?
Thanks for your help.
Hi aikeith,
Which version of WIN10 OS are you using on your machine? 10.0.16299.125 or higher version?
Thanks,
Letitia
Letitia,
Yes, it is.
Windows 10 Pro
Version 1709
OS Build 16299.125
Thank you :-)
Hi aikeith,
Thanks for your information.
Thanks,
Letitia
Thanks Letitia,
The issue has always happened, i have never been able to install the VS plugin.
Tried again using the link you provided which ends with:
NVIDIA Nsight Visual Studio Edition 5.5.0.18014
NVIDIA Nsight Visual Studio Edition 5.5.0.18014 Setup Wizard ended
prematurely because of an error. Your system has not been modified. To
install this program at a later time, run Setup Wizard again. Click the Finish
button to ext the Setup Wizard.
Thanks,
aikeith
Hi aikeith,
Did the issue happen on other machines? or just on your machine?
Thanks,
Letitia
Just on my machine. I am giving up on this since re-install of the O/S is not an option.
thanks.
I am also seeing this issue. I’m running Windows 7 Enterprise x64.
Looks to me like it’s failing because it can’t figure out how to install into Visual Studio 2017 instances it found. One instance is “Visual Studio Professional 2017” and the other is “Visual Studio Build Tools 2017 (2)”.
Please note the application event log:
- System
  - Provider
   [ Name]  MsiInstaller
  - EventID 11708
   [ Qualifiers]  0
   Level 4
   Task 0
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2018-02-22T19:22:11.000000000Z
   EventRecordID 155770
   Channel Application
   Computer AAAAAA
  - Security
   [ UserID]  BBBBBB
- EventData
   Product: NVIDIA Nsight Visual Studio Edition 5.5.0.18014 -- Installation failed.
   (NULL)
   (NULL)
   (NULL)
   (NULL)
   (NULL)
   7B30314544434136392D333838342D343130412D423135412D3646433745304532433543457D
Binary data:
In Words
0000: 4531307B 36414344 38332D39 342D3438
0008: 2D413031 41353142 4346362D 45304537
0010: 43354332 7D45
In Bytes
0000: 7B 30 31 45 44 43 41 36   {01EDCA6
0008: 39 2D 33 38 38 34 2D 34   9-3884-4
0010: 31 30 41 2D 42 31 35 41   10A-B15A
0018: 2D 36 46 43 37 45 30 45   -6FC7E0E
0020: 32 43 35 43 45 7D         2C5CE}
Also this:
- System
  - Provider
  - EventID 1033
   [ Qualifiers]  0
   Level 4
   Task 0
  - TimeCreated
   EventRecordID 155771
   Channel Application
   Computer AAAAAAA
  - Security
   [ UserID]  BBBBBB
- EventData
   5.5.0.18014
   1033
   1603
   NVIDIA Corporation
   (NULL)
   7B30314544434136392D333838342D343130412D423135412D3646433745304532433543457D3030303032393637353639643930626338663136633936633233363934393536366637313030303030393034
Binary data:
In Words
0010: 43354332 30307D45 39323030 36353736
0018: 30396439 66386362 39633631 33326336
0020: 39343936 66363635 30303137 39303030
0028: 3430
In Bytes
0020: 32 43 35 43 45 7D 30 30   2C5CE}00
0028: 30 30 32 39 36 37 35 36   00296756
0030: 39 64 39 30 62 63 38 66   9d90bc8f
0038: 31 36 63 39 36 63 32 33   16c96c23
0040: 36 39 34 39 35 36 36 66   6949566f
0048: 37 31 30 30 30 30 30 39   71000009
0050: 30 34                     04
MSI log – verbose
=== Verbose logging started: 2/22/2018  13:48:48  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\windows\System32\msiexec.exe ===
MSI (c) (7C:34) [13:48:48:365]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (7C:8C) [13:48:48:373]: Resetting cached policy values
MSI (c) (7C:8C) [13:48:48:373]: Machine policy value 'Debug' is 0
MSI (c) (7C:8C) [13:48:48:373]: ******* RunEngine:
           ******* Product: C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi
           ******* Action:
MSI (c) (7C:8C) [13:48:48:374]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (7C:8C) [13:48:48:486]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi' against software restriction policy
MSI (c) (7C:8C) [13:48:48:486]: SOFTWARE RESTRICTION POLICY: C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi has a digital signature
MSI (c) (7C:8C) [13:48:51:045]: SOFTWARE RESTRICTION POLICY: C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (7C:8C) [13:48:51:051]: Cloaking enabled.
MSI (c) (7C:8C) [13:48:51:051]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (7C:8C) [13:48:51:054]: End dialog not enabled
MSI (c) (7C:8C) [13:48:51:054]: Original package ==> C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi
MSI (c) (7C:8C) [13:48:51:054]: Package we're running from ==> C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi
MSI (c) (7C:8C) [13:48:51:060]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (7C:8C) [13:48:51:061]: APPCOMPAT: looking for appcompat database entry with ProductCode '{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}'.
MSI (c) (7C:8C) [13:48:51:061]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (7C:8C) [13:48:51:065]: MSCOREE not loaded loading copy from system32
MSI (c) (7C:8C) [13:48:51:069]: Machine policy value 'TransformsSecure' is 0
MSI (c) (7C:8C) [13:48:51:069]: User policy value 'TransformsAtSource' is 0
MSI (c) (7C:8C) [13:48:51:069]: Machine policy value 'DisablePatch' is 0
MSI (c) (7C:8C) [13:48:51:070]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (7C:8C) [13:48:51:070]: Machine policy value 'DisableMsi' is 0
MSI (c) (7C:8C) [13:48:51:070]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (7C:8C) [13:48:51:070]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (7C:8C) [13:48:51:070]: Running product '{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}' with user privileges: It's not assigned.
MSI (c) (7C:8C) [13:48:51:070]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (7C:8C) [13:48:51:070]: Machine policy value 'DisableFlyWeightPatching' is 1
MSI (c) (7C:8C) [13:48:51:070]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (7C:8C) [13:48:51:070]: APPCOMPAT: looking for appcompat database entry with ProductCode '{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}'.
MSI (c) (7C:8C) [13:48:51:071]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (7C:8C) [13:48:51:071]: Transforms are not secure.
MSI (c) (7C:8C) [13:48:51:071]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\xxxxxx\AppData\Local\Temp\MSI36e69.LOG'.
MSI (c) (7C:8C) [13:48:51:071]: Command Line: CURRENTDIRECTORY=C:\Users\xxxxxx\Downloads CLIENTUILEVEL=0 CLIENTPROCESSID=18300
MSI (c) (7C:8C) [13:48:51:071]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{27677B56-CE53-42A9-8138-EC83B371F33B}'.
MSI (c) (7C:8C) [13:48:51:071]: Product Code passed to Engine.Initialize:           ''
MSI (c) (7C:8C) [13:48:51:071]: Product Code from property table before transforms: '{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}'
MSI (c) (7C:8C) [13:48:51:071]: Product Code from property table after transforms:  '{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}'
MSI (c) (7C:8C) [13:48:51:071]: Product not registered: beginning first-time install
MSI (c) (7C:8C) [13:48:51:071]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (7C:8C) [13:48:51:071]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (7C:8C) [13:48:51:071]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (7C:8C) [13:48:51:071]: Adding new sources is allowed.
MSI (c) (7C:8C) [13:48:51:071]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (7C:8C) [13:48:51:071]: Package name extracted from package path: 'NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi'
MSI (c) (7C:8C) [13:48:51:071]: Package to be registered: 'NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi'
MSI (c) (7C:8C) [13:48:51:072]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (7C:8C) [13:48:51:072]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (7C:8C) [13:48:51:072]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (7C:8C) [13:48:51:072]: Running product '{01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}' with user privileges: It's not assigned.
MSI (c) (7C:8C) [13:48:51:072]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\xxxxxx\Downloads'.
MSI (c) (7C:8C) [13:48:51:072]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (7C:8C) [13:48:51:072]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '18300'.
MSI (c) (7C:8C) [13:48:51:072]: TRANSFORMS property is now:
MSI (c) (7C:8C) [13:48:51:072]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '405'.
MSI (c) (7C:8C) [13:48:51:072]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming
MSI (c) (7C:8C) [13:48:51:073]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\Favorites
MSI (c) (7C:8C) [13:48:51:073]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (7C:8C) [13:48:51:073]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\Documents
MSI (c) (7C:8C) [13:48:51:074]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (7C:8C) [13:48:51:074]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (7C:8C) [13:48:51:074]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (7C:8C) [13:48:51:074]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (7C:8C) [13:48:51:075]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (7C:8C) [13:48:51:075]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Local
MSI (c) (7C:8C) [13:48:51:075]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\Pictures
MSI (c) (7C:8C) [13:48:51:076]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (7C:8C) [13:48:51:076]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (7C:8C) [13:48:51:077]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (7C:8C) [13:48:51:077]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (7C:8C) [13:48:51:077]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (7C:8C) [13:48:51:078]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (c) (7C:8C) [13:48:51:078]: SHELL32::SHGetFolderPath returned: C:\Users\xxxxxx\Desktop
MSI (c) (7C:8C) [13:48:51:079]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (7C:8C) [13:48:51:080]: SHELL32::SHGetFolderPath returned: C:\windows\Fonts
MSI (c) (7C:8C) [13:48:51:081]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 20
MSI (c) (7C:8C) [13:48:51:085]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (7C:8C) [13:48:51:085]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
MSI (c) (7C:8C) [13:48:51:085]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (7C:8C) [13:48:51:086]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (7C:8C) [13:48:51:086]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Windows User'.
MSI (c) (7C:8C) [13:48:51:086]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'xxxxx'.
MSI (c) (7C:8C) [13:48:51:086]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi'.
MSI (c) (7C:8C) [13:48:51:086]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi'.
MSI (c) (7C:8C) [13:48:51:086]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (7C:8C) [13:48:51:086]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\xxxxxx\Downloads.
MSI (c) (7C:8C) [13:48:51:086]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\xxxxxx\Downloads.
MSI (c) (7C:34) [13:48:51:086]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 2/22/2018  13:48:51 ===
MSI (c) (7C:8C) [13:48:51:092]: Note: 1: 2205 2:  3: PatchPackage
MSI (c) (7C:8C) [13:48:51:092]: Machine policy value 'DisableRollback' is 0
MSI (c) (7C:8C) [13:48:51:092]: User policy value 'DisableRollback' is 0
MSI (c) (7C:8C) [13:48:51:092]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (7C:8C) [13:48:51:093]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (7C:8C) [13:48:51:093]: Doing action: INSTALL
Action 13:48:51: INSTALL.
Action start 13:48:51: INSTALL.
MSI (c) (7C:8C) [13:48:51:093]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (7C:8C) [13:48:51:093]: Running UISequence
MSI (c) (7C:8C) [13:48:51:093]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (7C:8C) [13:48:51:093]: Doing action: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 13:48:51: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 13:48:51: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (7C:8C) [13:48:51:093]: PROPERTY CHANGE: Adding ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs.
Action ended 13:48:51: ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (7C:8C) [13:48:51:093]: Doing action: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 13:48:51: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 13:48:51: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (7C:8C) [13:48:51:093]: PROPERTY CHANGE: Adding ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files (x86).
Action ended 13:48:51: ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (7C:8C) [13:48:51:093]: Doing action: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 13:48:51: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 13:48:51: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (7C:8C) [13:48:51:093]: PROPERTY CHANGE: Adding ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Program Files.
Action ended 13:48:51: ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (7C:8C) [13:48:51:093]: Doing action: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 13:48:51: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 13:48:51: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (7C:8C) [13:48:51:094]: PROPERTY CHANGE: Adding StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu.
Action ended 13:48:51: StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (7C:8C) [13:48:51:094]: Doing action: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A
Action 13:48:51: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
Action start 13:48:51: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A.
MSI (c) (7C:8C) [13:48:51:094]: PROPERTY CHANGE: Adding DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A property. Its value is 'C:\Users\Public\Desktop.
Action ended 13:48:51: DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A. Return value 1.
MSI (c) (7C:8C) [13:48:51:095]: Doing action: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA
Action 13:48:51: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA.
Action start 13:48:51: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA.
MSI (c) (7C:8C) [13:48:51:095]: PROPERTY CHANGE: Adding SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA property. Its value is 'C:\windows\SysWOW64.
Action ended 13:48:51: SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA. Return value 1.
MSI (c) (7C:8C) [13:48:51:095]: Doing action: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C
Action 13:48:51: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C.
Action start 13:48:51: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C.
MSI (c) (7C:8C) [13:48:51:095]: PROPERTY CHANGE: Adding System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C property. Its value is 'C:\windows\system32.
Action ended 13:48:51: System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C. Return value 1.
MSI (c) (7C:8C) [13:48:51:095]: Doing action: FindRelatedProducts
Action 13:48:51: FindRelatedProducts. Searching for related applications
Action start 13:48:51: FindRelatedProducts.
FindRelatedProducts: Found application: {33A1FAD1-C15E-4B4F-8CD9-06CD577433AA}
MSI (c) (7C:8C) [13:48:51:096]: PROPERTY CHANGE: Adding PREVIOUSVERSIONSINSTALLED property. Its value is '{33A1FAD1-C15E-4B4F-8CD9-06CD577433AA}'.
MSI (c) (7C:8C) [13:48:51:096]: PROPERTY CHANGE: Adding MIGRATE property. Its value is '{33A1FAD1-C15E-4B4F-8CD9-06CD577433AA}'.
Action ended 13:48:51: FindRelatedProducts. Return value 1.
MSI (c) (7C:8C) [13:48:51:096]: Doing action: get_VISUALSTUDIO2017LOCATION
Action 13:48:51: get_VISUALSTUDIO2017LOCATION.
Action start 13:48:51: get_VISUALSTUDIO2017LOCATION.
MSI (c) (7C:8C) [13:48:51:098]: Creating MSIHANDLE (1) of type 790542 for thread 10636
MSI (c) (7C:34) [13:48:51:098]: Invoking remote custom action. DLL: C:\Users\xxxxxx\AppData\Local\Temp\MSI7923.tmp, Entrypoint: InitializeVS2017Properties
MSI (c) (7C:A8) [13:48:51:100]: Cloaking enabled.
MSI (c) (7C:A8) [13:48:51:100]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (7C:A8) [13:48:51:100]: Connected to service for CA interface.
MSI (c) (7C!0C) [13:48:51:212]: Creating MSIHANDLE (2) of type 790531 for thread 1292
SFXCA: Extracting custom action to temporary directory: C:\Users\xxxxxx\AppData\Local\Temp\MSI7923.tmp-\
MSI (c) (7C!0C) [13:48:51:213]: Closing MSIHANDLE (2) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:229]: Creating MSIHANDLE (3) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:231]: Closing MSIHANDLE (3) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:277]: Creating MSIHANDLE (4) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:280]: Closing MSIHANDLE (4) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:322]: Creating MSIHANDLE (5) of type 790531 for thread 1292
starting custom action FindAnyVS2017Location()
MSI (c) (7C!0C) [13:48:51:323]: Closing MSIHANDLE (5) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:326]: PROPERTY CHANGE: Adding VISUALSTUDIO2017INSTANCES property. Its value is '2'.
MSI (c) (7C!0C) [13:48:51:326]: PROPERTY CHANGE: Adding VISUALSTUDIO2017INSTANCECOUNT property. Its value is '2 instances'.
MSI (c) (7C!0C) [13:48:51:326]: Creating MSIHANDLE (6) of type 790531 for thread 1292
Considering VS2017 instance rooted at C:\Program Files (x86)\Microsoft Visual Studio017\BuildTools
MSI (c) (7C!0C) [13:48:51:327]: Closing MSIHANDLE (6) of type 790531 for thread 1292
MSI (c) (7C!0C) [13:48:51:327]: Creating MSIHANDLE (7) of type 790531 for thread 1292
Error: Expected to find "C:\Program Files (x86)\Microsoft Visual Studio017\BuildTools\Common7\IDE\devenv.com" but did not
MSI (c) (7C!0C) [13:48:51:327]: Closing MSIHANDLE (7) of type 790531 for thread 1292
MSI (c) (7C:34) [13:48:51:334]: Closing MSIHANDLE (1) of type 790542 for thread 10636
Action ended 13:48:51: get_VISUALSTUDIO2017LOCATION. Return value 3.
MSI (c) (7C:8C) [13:48:51:335]: Doing action: FatalErrorCustom
Action 13:48:51: FatalErrorCustom.
Action start 13:48:51: FatalErrorCustom.
Info 2898. For WixUI_Font_Normal textstyle, the system created a 'Tahoma' font, in 0 character set, of 16 pixels height.
Info 2898. For WixUI_Font_Bigger textstyle, the system created a 'Tahoma' font, in 0 character set, of 24 pixels height.
Action 13:48:51: FatalErrorCustom. Dialog created
MSI (c) (7C:BC) [13:48:51:345]: Note: 1: 2731 2: 0
Action ended 13:48:54: FatalErrorCustom. Return value 2.
Action ended 13:48:54: INSTALL. Return value 3.
MSI (c) (7C:8C) [13:48:54:883]: Destroying RemoteAPI object.
MSI (c) (7C:A8) [13:48:54:884]: Custom Action Manager thread ending.
Property(C): DiskPrompt = NVIDIA Nsight Visual Studio Edition 5.5.0.18014 Installation
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): SystemFolder = C:\windows\SysWOW64\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): System64Folder = C:\windows\system32\
Property(C): AppDataFolder = C:\Users\xxxxxx\AppData\Roaming\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): SourceDir = C:\Users\xxxxxx\Downloads\
Property(C): Privileged = 1
Property(C): Manufacturer = NVIDIA Corporation
Property(C): ProductCode = {01EDCA69-3884-410A-B15A-6FC7E0E2C5CE}
Property(C): ProductLanguage = 1033
Property(C): ProductName = NVIDIA Nsight Visual Studio Edition 5.5.0.18014
Property(C): ProductVersion = 5.5.0.18014
Property(C): PLATFORM = (VersionNT >= 601)
Property(C): HOSTALLOWED = true
Property(C): MONITORALLOWED = true
Property(C): VISUALSTUDIO2010 = VISUALSTUDIO2010KEY
Property(C): VS2017EXTENSIONSDIR = Extensions\NVIDIA\Nsight Visual Studio Edition.5\
Property(C): ARPPRODUCTICON = ProductIcon
Property(C): ARPHELPLINK = http://developer.nvidia.com
Property(C): ARPURLINFOABOUT = http://developer.nvidia.com
Property(C): UXTPRODUCTTRACKINGID = UA-59254929-1
Property(C): UXTPRODUCTNAME = Nsight
Property(C): UXTPRODUCTVERSIONCD = cd1
Property(C): UXTPRODUCTVERSIONCM = cm1
Property(C): UXTHOSTPLATFORMCD = cd2
Property(C): UXTHOSTPLATFORMCM = cm2
Property(C): UXTDOMAINCD = cd4
Property(C): UXTDOMAINCM = cm4
Property(C): UXTSESSIONCD = cd12
Property(C): UXTSESSIONCM = cm17
Property(C): UXTFEATURECD = cd13
Property(C): UXTFEATURECM = cm18
Property(C): UXTROLECD = cd30
Property(C): UXTROLECM = cm31
Property(C): SIPOPTINVALUE = True
Property(C): PrivacyPolicyURL = http://www.nvidia.com/object/privacy_policy.html
Property(C): DefaultUIFont = WixUI_Font_Normal
Property(C): InstallNsightURL = http://developer.nvidia.com/install-nsight-visual-studio-edition
Property(C): SIPUSERFILE = {4751b8b4-531d-4be6-919e-ffe9bf95dc01}.nvsettings
Property(C): SIPDEFAULTFILE = Vsip.Tracking.nvmodel.xaml
Property(C): INSTALLSUMMARY_FILENAME = Nsight_5.5.0.18014_InstallSummary.xml
Property(C): ErrorDialog = ErrorDlg
Property(C): SecureCustomProperties = DEVENV2010FILEEXISTS;DEVENV2012FILEEXISTS;DEVENV2013FILEEXISTS;DEVENV2015FILEEXISTS;DOTNETFRAMEWORK40CLIENT;DOTNETFRAMEWORK40FULL;DOTNETFRAMEWORK4EXISTS;DOTNETFRAMEWORK4KEY;DOTNETFRAMEWORK4REQUIREMENTSPASS;HOSTALLOWED;HOSTREQUIREMENTSPASSED;INSTALL_VS2017;KB971512KEY;MONITORALLOWED;MONITORREQUIREMENTSPASSED;MSDIA11064REGISTERED;MSDIA110REGISTERED;PREVIOUSVERSIONSINSTALLED;SIPOPTINVALUE;UNINSTALL_VS2017;UXTDOMAINCD;UXTDOMAINCM;UXTFEATURECD;UXTFEATURECM;UXTHOSTPLATFORMCD;UXTHOSTPLATFORMCM;UXTPRODUCTNAME;UXTPRODUCTTRACKINGID;UXTPRODUCTVERSION;UXTPRODUCTVERSIONCD;UXTPRODUCTVERSIONCM;UXTPRODUCTVERSIONREG;UXTROLECD;UXTROLECM;UXTSELECTEDFEATURES;UXTSESSIONCD;UXTSESSIONCM;VISUALSTUDIO2010;VISUALSTUDIO2010FOLDER;VISUALSTUDIO2010KEY;VISUALSTUDIO2010LOCATION;VISUALSTUDIO2010REQUIREMENTSPASS;VISUALSTUDIO2012FOLDER;VISUALSTUDIO2012KEY;VISUALSTUDIO2012LOCATION;VISUALSTUDIO2012REQUIREMENTSPASS;VISUALSTUDIO2013FOLDER;VISUALSTUDIO2013KEY;VISUALSTUDIO2013LOCATION;VISUALSTUDIO2013REQUIREMENTSPASS;VISUALSTUDIO2015FOLDER;VISUALSTUDIO2015KEY;VISUALSTUDIO2015LOCATION;VISUALSTUDIO2015REQUIREMENTSPASS;VISUALSTUDIO2017REQUIREMENTSPASS;VS2017EXTENSIONSDIR
Property(C): PREVIOUSVERSIONSINSTALLED = {33A1FAD1-C15E-4B4F-8CD9-06CD577433AA}
Property(C): System64Folder_amd64_VC.05F0B5F5_44A8_3793_976B_A4F17AECF92C = C:\windows\system32\
Property(C): DirectoryTable100_amd64.05F0B5F5_44A8_3793_976B_A4F17AECF92C = DirectoryTable
Property(C): SystemFolder_x86_VC.194841A2_D0F2_3B96_9F71_05BA91BEA0FA = C:\windows\SysWOW64\
Property(C): DirectoryTable100_x86.194841A2_D0F2_3B96_9F71_05BA91BEA0FA = DirectoryTable
Property(C): ProgramMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): ProgramFilesFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A = C:\Program Files (x86)\
Property(C): ProgramFiles64Folder.998C53D5_36AE_41E2_AF7B_38D475B8114A = C:\Program Files\
Property(C): StartMenuFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): DesktopFolder.998C53D5_36AE_41E2_AF7B_38D475B8114A = C:\Users\Public\Desktop\
Property(C): ARPPRODUCTICON.998C53D5_36AE_41E2_AF7B_38D475B8114A = ProductIcon
Property(C): ARPURLINFOABOUT.998C53D5_36AE_41E2_AF7B_38D475B8114A = http://developer.nvidia.com
Property(C): MsiLogFileLocation = C:\Users\xxxxxx\AppData\Local\Temp\MSI36e69.LOG
Property(C): PackageCode = {27677B56-CE53-42A9-8138-EC83B371F33B}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\Users\xxxxxx\Downloads
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 18300
Property(C): VersionDatabase = 405
Property(C): VersionMsi = 5.00
Property(C): VersionNT = 601
Property(C): VersionNT64 = 601
Property(C): WindowsBuild = 7601
Property(C): ServicePackLevel = 1
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): WindowsFolder = C:\windows\
Property(C): WindowsVolume = C:\
Property(C): RemoteAdminTS = 1
Property(C): TempFolder = C:\Users\xxxxxx\AppData\Local\Temp\
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): FavoritesFolder = C:\Users\xxxxxx\Favorites\
Property(C): NetHoodFolder = C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): PersonalFolder = C:\Users\xxxxxx\Documents\
Property(C): PrintHoodFolder = C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): RecentFolder = C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): SendToFolder = C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): LocalAppDataFolder = C:\Users\xxxxxx\AppData\Local\
Property(C): MyPicturesFolder = C:\Users\xxxxxx\Pictures\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): FontsFolder = C:\windows\Fonts\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): MsiAMD64 = 6
Property(C): Msix64 = 6
Property(C): Intel = 6
Property(C): PhysicalMemory = 16216
Property(C): VirtualMemory = 25190
Property(C): LogonUser = XXXXX
Property(C): UserSID = S-1-5-21-907112402-3766131179-2979934366-493207
Property(C): UserLanguageID = 1033
Property(C): ComputerName = U701N11X876
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 1920
Property(C): ScreenY = 1200
Property(C): CaptionHeight = 27
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 20
Property(C): TextInternalLeading = 4
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 13:48:54
Property(C): Date = 2/22/2018
Property(C): MsiNetAssemblySupport = 4.7.2558.0
Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
Property(C): RedirectedDllSupport = 2
Property(C): AdminUser = 1
Property(C): USERNAME = Windows User
Property(C): COMPANYNAME = xxxxx
Property(C): DATABASE = C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi
Property(C): OriginalDatabase = C:\Users\xxxxxx\Downloads\NVIDIA_Nsight_Visual_Studio_Edition_Win64_5.5.0.18014.msi
Property(C): SOURCEDIR = C:\Users\xxxxxx\Downloads\
Property(C): VersionHandler = 5.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): MIGRATE = {33A1FAD1-C15E-4B4F-8CD9-06CD577433AA}
Property(C): VISUALSTUDIO2017INSTANCES = 2
Property(C): VISUALSTUDIO2017INSTANCECOUNT = 2 instances
=== Logging stopped: 2/22/2018  13:48:54 ===
MSI (c) (7C:8C) [13:48:54:906]: Note: 1: 1708
MSI (c) (7C:8C) [13:48:54:906]: Product: NVIDIA Nsight Visual Studio Edition 5.5.0.18014 -- Installation failed.
MSI (c) (7C:8C) [13:48:54:907]: Windows Installer installed the product. Product Name: NVIDIA Nsight Visual Studio Edition 5.5.0.18014. Product Version: 5.5.0.18014. Product Language: 1033. Manufacturer: NVIDIA Corporation. Installation success or error status: 1603.
MSI (c) (7C:8C) [13:48:54:909]: Grabbed execution mutex.
MSI (c) (7C:8C) [13:48:54:909]: Cleaning up uninstalled install packages, if any exist
MSI (c) (7C:8C) [13:48:54:910]: MainEngineThread is returning 1603
=== Verbose logging stopped: 2/22/2018  13:48:54 ===
I had the same issue: I tried to reinstall CUDA 9.1 - however the visual studio integration component, which seems to call the nsight uninstaller that in turn crashed, was the problem.
What solved my problem:
  • uninstall every trace of Visual Studio - no the uninstaller does not do the job, get e.g. revo uninstaller and remove everything related to visual studio (build tools, extensions, … everything starting with ‘Visual’ - Visual C++ Redistributables may be fine though)
  • to be sure also remove all nvidia related stuff
  • install visual studio again, just the basic IDE - dont install any additional components
  • install nsight (or in my case CUDA)
  • install all the other visual studio components you might need
My Setup:
  • Windows 10 Pro
  • Visual Studio Professional 15.4.5 (I downgraded from 15.5.7 because there were multiple issues with that version)
good luck!
Hi thomas.veldhouse,
Could you please try uninstalling BuildTools, then install Nsight?
