Clicking timeline crashes Visual Studio 2019 using Nvidia nsight Visual studio Edition Version 2019....
Clicking timeline crashes Visual Studio 2019 version 16.2.3. Everything else works fine.
Nvidia nsight Visual studio Edition Version: 2019.3.0.19222
Visual Studio 2019 Professional Version 16.2.3
CUDA Version: 10.1.105
Window Version: 1903 (OS Build 18362.329)
Event log shows System.InvalidOperationException:
Application: devenv.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.InvalidOperationException
at System.Windows.Interop.HwndHost.BuildWindow(System.Runtime.InteropServices.HandleRef)
at System.Windows.Interop.HwndHost.BuildOrReparentWindow()
at System.Windows.Interop.HwndHost.OnSourceChanged(System.Object, System.Windows.SourceChangedEventArgs)
at System.Windows.SourceChangedEventArgs.InvokeEventHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean)
at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs)
at System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs)
at System.Windows.PresentationSource.UpdateSourceOfElement(System.Windows.DependencyObject, System.Windows.DependencyObject, System.Windows.DependencyObject)
at System.Windows.PresentationSource.OnVisualAncestorChanged(System.Windows.DependencyObject, System.Windows.Media.AncestorChangedEventArgs)
at System.Windows.UIElement.OnVisualAncestorChanged(System.Object, System.Windows.Media.AncestorChangedEventArgs)
at System.Windows.Media.Visual.ProcessAncestorChangedNotificationRecursive(System.Windows.DependencyObject, System.Windows.Media.AncestorChangedEventArgs)
at System.Windows.Media.Visual.FireOnVisualParentChanged(System.Windows.DependencyObject)
at System.Windows.Media.Visual.AddVisualChild(System.Windows.Media.Visual)
at System.Windows.FrameworkElement.set_TemplateChild(System.Windows.UIElement)
at System.Windows.Controls.ContentPresenter+UseContentTemplate.BuildVisualTree(System.Windows.FrameworkElement)
at System.Windows.StyleHelper.ApplyTemplateContent(System.Windows.UncommonField1<System.Collections.Specialized.HybridDictionary[]>, System.Windows.DependencyObject, System.Windows.FrameworkElementFactory, Int32, System.Collections.Specialized.HybridDictionary, System.Windows.FrameworkTemplate) at System.Windows.FrameworkTemplate.ApplyTemplateContent(System.Windows.UncommonField1<System.Collections.Specialized.HybridDictionary>, System.Windows.FrameworkElement)
at System.Windows.FrameworkElement.ApplyTemplate()
at System.Windows.FrameworkElement.MeasureCore(System.Windows.Size)
at System.Windows.UIElement.Measure(System.Windows.Size)
at System.Windows.Controls.Border.MeasureOverride(System.Windows.Size)
at System.Windows.Controls.Control.MeasureOverride(System.Windows.Size)
at System.Windows.Controls.DockPanel.MeasureOverride(System.Windows.Size)
at MS.Internal.Helper.MeasureElementWithSingleChild(System.Windows.UIElement, System.Windows.Size)
at System.Windows.Controls.ContentPresenter.MeasureOverride(System.Windows.Size)
at System.Windows.Controls.Grid.MeasureCell(Int32, Boolean)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32, System.Windows.Size, Boolean, Boolean, Boolean ByRef)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32, System.Windows.Size, Boolean, Boolean)
at System.Windows.Controls.Grid.MeasureOverride(System.Windows.Size)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(System.Object)
at System.Windows.Media.MediaContext+InvokeOnRenderCallback.DoWork()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(System.Object)
at System.Windows.Media.MediaContext.RenderMessageHandler(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
Thank you for your help,
Best Regards
Csaba
I have the same problem. Anything new on this?
This is probably due to a change we made in the Creators Update (1703) related to reparenting windows across a DPI awareness boundary, which we are looking into.
For the short term, please use Nsight Systems.
https://developer.nvidia.com/nsight-systems
If you check “Override high dpi scaling behavior” in the properties of the executable, it no longer crashes.
External Media
Another approach is to update the devenv.exe.config as shown below (shown running with PerMonitorV2)
<System.Windows.Forms.ApplicationConfigurationSection>
      <add key="DisableDpiChangedHighDpiImprovements" value="false"/>
      <add key="AnchorLayout.DisableHighDpiImprovements" value="true"/>
      <add key="DpiAwareness" value="PerMonitorV2"/>
    </System.Windows.Forms.ApplicationConfigurationSection>
Thank you, it solves the problem for me, I do not have the compatibility tab for devenv.exe, but I have changed the lines in devenv.exe.config from
to
and it worked.
Thanks again,
Csaba
Hello
I have the same problem for a while
just updated to 2019.4 but did not solve anything.
I start to miss Nsight a lot.
I just tried Csaba configuration
but I still get
Best Regards
Mâa
it work for me too
Thanks I am fighting with this for so long.
Mâa
Still an issue. 16.6.1 - clicking timeline causes an immediate crash of VS 2019.
DPI override is not available. devenv.exe.config already has the changes listed above.
Sig[0].Name=Application Name
Sig[0].Value=devenv.exe
Sig[1].Name=Application Version
Sig[1].Value=16.6.30128.74
Sig[2].Name=Application Timestamp
Sig[2].Value=5ed02509
Sig[3].Name=Fault Module Name
Sig[3].Value=KERNELBASE.dll
Sig[4].Name=Fault Module Version
Sig[4].Value=10.0.18362.815
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=67005c2a
Sig[6].Name=Exception Code
Sig[6].Value=e0434352
Sig[7].Name=Exception Offset
Sig[7].Value=00114402
I can confirm the issue but I think found a workaround.
Try to change this line also from
to
<add key="DisableDpiChangedHighDpiImprovements" value="true"/>
in devenv.exe.config.
It solved the crash for me.
Csaba``
Thanks, that stopped the crash.
I have the same problem,but the message is different
visual studio version: Microsoft Visual Studio Community 2019 Version 16.6.5
nsight version: 2020.1.1
HResult=0x80131509
Message=Hosted HWND must be a child window of the specified parent.
Source=PresentationFramework
StackTrace:
at System.Windows.Interop.HwndHost.BuildWindow(HandleRef hwndParent)
at System.Windows.Interop.HwndHost.OnSourceChanged(Object sender, SourceChangedEventArgs e)
at System.Windows.SourceChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.PresentationSource.UpdateSourceOfElement(DependencyObject doTarget, DependencyObject doAncestor, DependencyObject doOldParent)
at System.Windows.PresentationSource.OnVisualAncestorChanged(DependencyObject uie, AncestorChangedEventArgs e)
at System.Windows.UIElement.OnVisualAncestorChanged(Object sender, AncestorChangedEventArgs e)
at System.Windows.Media.Visual.ProcessAncestorChangedNotificationRecursive(DependencyObject e, AncestorChangedEventArgs args)
at System.Windows.Media.Visual.FireOnVisualParentChanged(DependencyObject oldParent)
at System.Windows.Media.Visual.AddVisualChild(Visual child)
at System.Windows.FrameworkElement.set_TemplateChild(UIElement value)
at System.Windows.Controls.ContentPresenter.UseContentTemplate.BuildVisualTree(FrameworkElement container)
at System.Windows.StyleHelper.ApplyTemplateContent(UncommonField1 dataField, DependencyObject container, FrameworkElementFactory templateRoot, Int32 lastChildIndex, HybridDictionary childIndexFromChildID, FrameworkTemplate frameworkTemplate) at System.Windows.FrameworkTemplate.ApplyTemplateContent(UncommonField1 templateDataField, FrameworkElement container)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at System.Windows.Controls.Border.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV, Boolean& hasDesiredSizeUChanged)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
This exception was originally thrown at this call stack:
[External Code]
I check “Override high dpi scaling behavior” ,but it still crash
