VS2019
NVIDIAR Nsight Visual Studio Edition Version 2019.4
WDDM
maxwell mx130
driver:442.23
cuda:10.2
and if i change the location of this window
,VS will crash
event viewer:
Application: devenv.exe
Framework version: v4.0.30319
Description: Process terminated due to an unhandled exception.
Abnormal information: System. NullReferenceException
In the System. Windows. Interop. HwndMouseInputProvider. HasCustomChrome (System. Windows. Interop. HwndSource, the RECT ByRef)
In the System. Windows. Interop. HwndMouseInputProvider. GetEffectiveClientRect (IntPtr)
In the System. Windows. Interop. HwndMouseInputProvider. PossiblyDeactivate (IntPtr, Boolean)
In the System. Windows. Interop. HwndMouseInputProvider. The Dispose ()
In the System. Windows. Interop. HwndMouseInputProvider. FilterMessage (IntPtr, MS. Internal. Interop. WindowMessage, IntPtr, IntPtr, Boolean ByRef)
In the System. Windows. Interop. HwndSource. InputFilterMessage (IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
In Ms. Win32. HwndWrapper. WndProc (IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
In Ms. Win32. HwndSubclass. DispatcherCallbackOperation System. (Object)
In the System. Windows. Threading. ExceptionWrapper. InternalRealCall (System. The Delegate, System. Object, Int32)
In the System. Windows. Threading. ExceptionWrapper. TryCatchWhen (System. Object, System. The Delegate, System. Object, Int32, System.Delegate)
In the System. Windows. Threading. Dispatcher. LegacyInvokeImpl (System. Windows. Threading. DispatcherPriority, System. TimeSpan. System.Delegate, System.Object, Int32)
In Ms. Win32. HwndSubclass. SubclassWndProc (IntPtr, Int32, IntPtr, IntPtr)
